#61 (permalink) |
User, Registered
Maybe that's it for him, but mine does better when it's warm. It was almost undriveable when it was 20F outside this winter, even after it warmed up. When I'd pull away from lights or stop signs I had to rev it up and slip the clutch to move the car. Now that the weather is warm it's better, after the motor warms up it's barely noticeable.
Francis 2006 Chrome Orange Elise: Base, Hardtop, LSD/TC, FF Engine Damper, Arqray Twin Muffler, Nitron SAs with 525/650 springs, Katana Supercharger, Smaay's fuel rail, Saikou Michi dual catch can, Eliseparts bumpsteer kit, BWR 7/8" Front Bar 2000 Black Integra Type R: Konis, Neuspeed Race Springs, Mugen 26mm Rear Bar, 16x8 SSR Integrals |
#62 (permalink) |
disproving HD MTBF daily
Remember that its supposed to happen after the learn, thats the whole point of the learn, when it comes from the factory the calibration is nearly always off, so it 'learns' and then adjusts the fueling to cut down the HC emissions from the exhaust at idle, its done this way to save adding SAI.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it. |
#63 (permalink) |
User, Registered
charliex, how does it determine when the motor is warm enough for normal operation? Does it use the O2 sensor past the cat?
#64 (permalink) |
There are a number of different parameters for it, coolant temp, o2 heater switch on time + current, air temp, etc.
Which leads to the why you get so much disparity over one car does it, and one car doesn't. We might see SAI in future cars from Lotus which will help, but at a cost.
#65 (permalink) |
High Roller
Just to update....I warmed the car up for two minutes before driving and it was fine. Just a small hiccup at first, then off we went. This issue doesn't really seem to be an issue.
06 Lotus Elise - AR/Blk, Touring, Premium, TC, HT, DRL Delete, X-Pel, TS Pro1 Exhaust, TS Pro1 Intake, BBmod, Saikou Michi OCC, 6000k HIDs, Stealth Bulbs, 07+ Letters, Re-grooved Bilsteins, LG Stone Guards, CR Engine Covers, S111 Folding Tow Hook, FF CF Spoiler, 17" PIAA FR-7s, CharlieX 06 ECU V2.0, Greddy/BOE Supercharger ![]() 88 BMW 528is - Blue/Llama Beige, M20 stroker motor, Alpina SW, 3.73 LSD, BavAuto Springs, Bilstein Sports, M3 SSK, 16x8 BBS, 225/245 tires, shadowline |
#66 (permalink) |
User, Registered
Meh. Still is a problem for me. Ran it 20 minutes day before yesterday, as soon as I slowed down it started doing it again. Of course, it wasn't over 70 outside (the magic temperature).
#67 (permalink) |
resetting the ecu is tough, you need to run the car,switch it off and then disconnect the battery before you hear the 'click' of the relays/pumps.
its easier if you get the car to throw a code, since if the reset works, it'll go away.
#68 (permalink) |
Same issue on 06 DBW car and I've put about 1000 miles on since install. I kept hoping it would learn out but no luck so far. Kind of embarrassing to drive the car around until it's warmed up.
-- 2006 Lotus Elise - Starlight on black, black badges, HT, touring/sport/premium packages - HID, Katana SC, Clam-tilt 2005 Volkswagen Touareg 1956 Vintage 550 RS Spyder Replica |
#69 (permalink) |
how is this going ? did you ifne any solution? or you have to learn ot live with that issue ??
I have the simplest tastes... I am only satisfied with the best !!! "Simplify & Add Lightness" J.P |
#71 (permalink) |
User, Registered
For everybody with DBW and cold start problems: try Charlie's new tune (Ronin v2: New flash for Ronin SC 2006. I ran it over the weekend; cold start is better than stock now, and the bad off-idle hesitation I had is gone. Also, running in general seems better, and the throttle response is improved.
#72 (permalink) |
for all those bogging issues, have you guys clean the MAF real good?
or use a new MAF? it's a fairly common issue for the car to bog or stumble with the wonky MAF sensor in.
| CelicaSG.org - CSG | |
#73 (permalink) |
User, Registered
We tried that on mine, no difference.
#74 (permalink) |
FYI, I just got the updated Katana flash from CharlieX and the cold start problem has gone away.
#75 (permalink) | |
My BWR does the same thing.
06 Exige Ph Black/Black, 2bular 7", Von Hep Rear Panel delete, Green Filter, Snorkel delete, Xenons, Scroth belts, Carbon Rear view mirror, Binnacle, Console, Cup Roof and Rear Diffuser. Sector Extinguisher, Nitron Singles, Sector Rotors, R4's, BWR front Sway Bar, Weapon R Header and De-Cat, BWR Super Charger PCA, PBOC, Chin DE Instructor.
#76 (permalink) |
High Roller
+1. Wish I could delete this thread now. haha.
| Display Modes | |
