Old 05-16-2008, 08:05 AM   #61 (permalink)
User, Registered
fpitas's Avatar
Originally Posted by insane View Post
Scotty, see post #44. ....it may just have been the cooler November air.
Maybe that's it for him, but mine does better when it's warm. It was almost undriveable when it was 20F outside this winter, even after it warmed up. When I'd pull away from lights or stop signs I had to rev it up and slip the clutch to move the car. Now that the weather is warm it's better, after the motor warms up it's barely noticeable.
Francis
Old 05-16-2008, 12:13 PM   #62 (permalink)
OSX Black hat
charliex's Avatar
Remember that its supposed to happen after the learn, thats the whole point of the learn, when it comes from the factory the calibration is nearly always off, so it 'learns' and then adjusts the fueling to cut down the HC emissions from the exhaust at idle, its done this way to save adding SAI.
Old 05-16-2008, 12:32 PM   #63 (permalink)
User, Registered
fpitas's Avatar
charliex, how does it determine when the motor is warm enough for normal operation? Does it use the O2 sensor past the cat?
Francis
Old 05-16-2008, 12:45 PM   #64 (permalink)
OSX Black hat
charliex's Avatar
There are a number of different parameters for it, coolant temp, o2 heater switch on time + current, air temp, etc.
Which leads to the why you get so much disparity over one car does it, and one car doesn't.
We might see SAI in future cars from Lotus which will help, but at a cost.
Old 05-20-2008, 09:05 AM   #65 (permalink)
High Roller
JUNGLISTluder's Avatar
Images: 6
Just to update....I warmed the car up for two minutes before driving and it was fine. Just a small hiccup at first, then off we went. This issue doesn't really seem to be an issue.
96 Ferrari F355 Berlinetta
06 Lotus Elise Supercharged - SOLD
88 BMW 528is
JUNGLISTluder is offline   Reply With Quote
Old 05-20-2008, 10:19 AM   #66 (permalink)
User, Registered
fpitas's Avatar
Meh. Still is a problem for me. Ran it 20 minutes day before yesterday, as soon as I slowed down it started doing it again. Of course, it wasn't over 70 outside (the magic temperature).
Francis
Old 05-20-2008, 10:31 AM   #67 (permalink)
OSX Black hat
charliex's Avatar
resetting the ecu is tough, you need to run the car,switch it off and then disconnect the battery before you hear the 'click' of the relays/pumps.
its easier if you get the car to throw a code, since if the reset works, it'll go away.
Old 05-23-2008, 04:38 AM   #68 (permalink)
Faze's Avatar
Same issue on 06 DBW car and I've put about 1000 miles on since install. I kept hoping it would learn out but no luck so far. Kind of embarrassing to drive the car around until it's warmed up.
2006 Lotus Elise - Starlight on black, black badges, HT, touring/sport/premium packages - HID, Katana SC, Clam-tilt
2009 Honda Ridgeline RTL
2006 Kawasaki KLX-250S
2008 KTM 450 EXC-R
Faze is offline   Reply With Quote
Old 06-26-2008, 10:33 PM   #69 (permalink)
Jean-Paul's Avatar
how is this going ? did you ifne any solution? or you have to learn ot live with that issue ??
I have the simplest tastes...
I am only satisfied with the best !!!
"Simplify & Add Lightness"
J.P
Jean-Paul is offline   Reply With Quote
Old 07-03-2008, 08:33 AM   #70 (permalink)
No, it's not a Ford Lotus
Johnny B's Avatar
My car bogged down when it was N/A and cold started.
It's a night and day difference after Charlie's S/C tune and RoninKatana. I can drive it immediately with no bogging issues.
Johnny B is offline   Reply With Quote
Old 08-11-2008, 04:53 AM   #71 (permalink)
User, Registered
fpitas's Avatar
For everybody with DBW and cold start problems: try Charlie's new tune (Ronin v2: New flash for Ronin SC 2006. I ran it over the weekend; cold start is better than stock now, and the bad off-idle hesitation I had is gone. Also, running in general seems better, and the throttle response is improved.
Francis
Old 08-20-2008, 07:19 PM   #72 (permalink)
zuoom's Avatar
for all those bogging issues, have you guys clean the MAF real good?
or use a new MAF?
it's a fairly common issue for the car to bog or stumble with the wonky MAF sensor in.
| CelicaSG.org - CSG |
zuoom is offline   Reply With Quote
Old 08-21-2008, 07:16 AM   #73 (permalink)
User, Registered
fpitas's Avatar
or use a new MAF?
We tried that on mine, no difference.
Francis
Old 11-18-2008, 04:57 AM   #74 (permalink)
Faze's Avatar
FYI, I just got the updated Katana flash from CharlieX and the cold start problem has gone away.
2008 KTM 450 EXC-R
Old 11-18-2008, 05:09 AM   #75 (permalink)
Shawn C's Avatar
Originally Posted by JUNGLISTluder View Post
Is it normal for my Katana Elise to run really rough until it is warmed up to ~160 degrees? When I first start the car, it will start right up, but when I touch the gas it wants to bog down. I have to really rev it up to keep the car from stalling until it is warmed up. Idling is fine, this is only when I'm pressing the gas. After it is warmed up, it drives very nice.
Thanks!
My BWR does the same thing.
http://www.youtube.com/jerusdc
Shawn C is offline   Reply With Quote
Old 11-18-2008, 07:14 AM   #76 (permalink)
High Roller
Images: 6
+1. Wish I could delete this thread now. haha.
88 BMW 528is
