Low boost, running out of ideas...
I decided to start a new thread as my issue doesn't seem to pertain to the bypass.
Background: I live in Denver 5,200 feet above sea level 2005 Elise 10,xxx miles BWR SC 1,500 miles on the install Problem: Max boost @ 8,200rpm ~5 (I've previously seen 7psi) Here's what I've done so far: Replaced the Supercharger belt / and tried a shorter belt Replaced Belt Tensioner Compression test 175 across all cylinders (loss at 5000 feet of altitude= .8617) Removed SC to inspect bypass valve / the valve operates and seals properly Upon removal found transmission mount bolt had sheared. Replaced transmission mounting bolt with grade 8 bolt Replaced intake manifold gasket Swapped ECU with CharlieX tuned ECU Conclusion: I've run out of ideas as to what it may be... The car achieves 5 psi easily, be tween 4500 and 5000rpm. At cam changeover it drops and then creeps back to right around 5 psi. One passenger did mention while driving with me that during one run I let the car bounce off the limiter and they said they said they saw 6.5-7psi briefly. I can't understand why the pressure would increase on the limiter but it may have? I'm grabbing at straws at this point. The car is mostly used at the track, perhaps a hard downshift may have "stretched" a valve??? (Wouldn't the compression test have shown it) Maybe I have a really dirty air filter or some kind of blockage in the air box (maybe I should try a run with the airbox removed). What am I missing? |
#2 (permalink) | |
User Restricted By ΑDMIΝ
2) Do you have access to a OBD-II scanner with live data? If so, what flow are you getting through your MAF at full load?
#3 (permalink) | |
I don't have access to an OBD-II scanner. Do you (or anyone here) have a recommendation for a inexpensive scanner that would work for this purpose? Does anyone make a smaller pulley for the BWR SC, I'm tempted to just try to spin it a little faster and see what happens. |
#4 (permalink) | |
![]() This one from Sears can read and reset diagnostic codes, as well as display real time OBD-II data: There may be cheaper ones out there that provide the same functionality...
Hydrocarbons Rule
Have you tried anouther boost gauge by any chance?
Have you looked for cracks in the manifold? Have you checked to insure your throttle body opens all the way? Have you checked the fuel injector seals? Air box or Filter restriction as you mentioned is also a possible problem... I haven't seen your other thread, so I'm starting out with no prior knowledge of what you've done to date hence all the questions...
2006 Exige; BWR Supercharger, Adj Sway Bar, Ohlins Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Clutch, Custom Exhaust, Black Volk Racing CE28N's w/ Toyo R1R's, 2 piece rotors, Pagid Blue Pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Panels), Dry Carbon rear Diffuser, Harness Bar, BWR Gauge Mount, OMP Superquadro steering wheel, LETSLA Short Shifter, V2arms, Rear Tow Link Brace, RLS Battery Bracket, BOE Tow Bar, Stickers. Last edited by Dragon : 08-17-2009 at 06:27 AM. |
Crazy Car Guy
![]() Join Date: Apr 2008
What time of year did you check the boost previously? Was it at the same altitude?
www.VisionFunction.com - Site Under Construnction - Stay Tuned |
#7 (permalink) | |
The manifold looked to be in good shape I did investigate the throttle cable was fully opening the throttle body I did not check the injector seals. I will try that. |
#8 (permalink) | |
The time of year/outside temperature is something I've been thinking about... The previous reading was done on a cool (50 deg) spring evening. The latest readings have been captured on warm (80 deg) summer afternoons. I would assume the heat would lower the efficiency of the blower but could 30-40 degrees of ambient air temperature make a 2psi difference? |
#9 (permalink) | |
2009 XP National Champion
![]() Join Date: Oct 2003
#10 (permalink) |
Just an idea to see if all the vaccuum lines on the air box are ok, plug the line going to the servo on the air box which should send all vaccuum to to only the bypass valve. this will cause the flap on the bottom of the airbox to stay open but it will rule out bypass valve disorder from air leak in the lines on the airbox. the line to plg is the orange silicone one.
05 elise graphite sport touring BWR s/c Charliex tune 90 eclipse gsx 420 whp sold ![]() 04 civic si |
#11 (permalink) | |
NOT ßANNED!
CAN OBDII Code Reader AL309 from etoolcart.com cost me $85 shipped. If your Elise isn't in pieces you could drive it up here and we could check it out, I'm just south of Denver.. You're in CS if I recall correctly?
#12 (permalink) | |
My wife's out of town this weekend and I'm watching the 1 year old so it would be difficult to get down to South Denver. |
#14 (permalink) |
Plug Whisperer
Don't get so hung up on what your gauge says. Dyno it. If the power is fine, then boost is also fine...
If it's low on power and low on boost, etc- it's mechnical- Plan and simple. You may drain the oil on the blower and see if it looks like black sludge. If so, perhaps the shaft coupler is destroying itself. This has happened to others... That's a stretch though... Again, dyno it is your best bet... TP
#15 (permalink) | |
#16 (permalink) |
Plug Whisperer
I'm not trying to be overly doubtful of you, but it would be one heck of a vacuum leak to bleed off enough air to impact whp... Again, it's just hard to diagnose without before and after dynos...
Later, TP
#17 (permalink) |
The leak was small enough to slow up the building of pressure and caused a nice drop during the cam change. It was really apparent if your were on the throttle for a bit, built up pressure despite the leak, and then lifted off the throttle. The engine kind of bucked. At first we thought it was a stuck blow off valve or an issue with the tune. All that disappeared after the leak was fixed.
#19 (permalink) | |
The car did a 14.6 at 95mph (consistent 3 passes) which seems to me to indicate a loss in performance? I don't have any other baselines for BWR/Katana cars 1/4 mile times at 5,000feet but I was anticipating more... |
#20 (permalink) |
NOT ßANNED!
Did you have your car on the dyno since the ~173whp run?
