Old 09-23-2008, 03:22 PM   #41 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
Originally Posted by sleepe View Post
So...is your fuel tank breather line "open" now?
Did you route the tank breather line away from the firewall?
-Robert
It is right near the fuel filler with a breather filter on it.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
Old 09-23-2008, 03:50 PM   #42 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
It's easy enough to keep the venting sollenoid hooked up to avoid that vapor loss. Here's a pic of how it looks:
Best,
Phil
Old 09-25-2008, 11:28 AM   #43 (permalink)
Bender Rodríguez's Avatar
Are you planning to reattach the Carbon Canister?
I see you capped-off the inlet point at the TB.
I removed mine for a few months to determine the performance
benefits, but replaced it after realizing my mpg had decreased due to
a free-venting system. I left the fuel tank breather line open, so it vented to the atmosphere. I think this caused so much vapor loss that it decreased my mpg.
BUT, throttle response was marginally more crisp and the engine seemed more alive in every gear.
any thoughts....
-Robert
Yeah I'm going to get a universal fuel tank breather (motorcycle type Probably) there real cheap.
Bender Rodríguez is offline   Reply With Quote
Old 09-25-2008, 11:30 AM   #44 (permalink)
Originally Posted by ZJChaser View Post
Any specs on the engine build? Its not a stock bottom end is it?
Pistons, Sleeves, rods, bearings (all monkeywrench) and thats it, I'm cheap. I think my whole turbo setup even paying for the fab work was like $3500
Old 09-25-2008, 11:32 AM   #45 (permalink)
So here are a couple new pics, almost done!!!
Old 02-22-2009, 05:18 PM   #46 (permalink)
So fast forward a little bit and I finally got around to rebuilding my motor. Went with Crower rods
Mahle pistons (9:1)
Monkeywrench valves
Circuit worx oil pump gears
and the rest is stock.
With the motor/trans out I went with John (MaineLotus) firewall shield mod.
Old 02-24-2009, 09:05 AM   #47 (permalink)
some pics
Old 02-24-2009, 09:24 AM   #48 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Looks like you're having a blast...
Just curious, why do many of you turbo guys run your waste gate to air rather than the exhaust system? I always ran mine into the exhaust stream to keep things just a little civil... Isn't the waste gate going to be crazy loud? I'm not trying to be critical ,jsut wondering if it's a preference or a convenience?
Props to all the one-off work!
Later,
Phil
Old 02-24-2009, 10:39 AM   #49 (permalink)
Later,
Phil
No it's a good point. For me I'm running high HP, high boost, so it's not too often that your really holding the throttle enough for 18+ psi that the wastegate will open at, and when you are things are going by really quick the sound never seems to bother me. If was running less boost (like say 10 psi or lower) I probably wouldn't dump it straight to atmosphere. And phil thanks again for all you help, there are not allot of people to turn to to ask questions so i do appreciate it.
Old 02-24-2009, 10:40 AM   #50 (permalink)
And more truth to what Phil is talking about
Old 02-24-2009, 11:07 AM   #51 (permalink)
Parts scattered about...
MaineLotus's Avatar
Acetone will disolve the blue ThermoTec logos, if you're inclined to remove them.
My car is modified.
MaineLotus is offline   Reply With Quote
Old 02-24-2009, 12:40 PM   #52 (permalink)
Thanks for the tip. I love the mod this was a great idea on your part. I know from every performance car I've ever had once you start adding boost and modifying fuel/ spark the engine bay always gets substantially hotter than stock. Just one of those things.
Old 03-08-2009, 12:19 PM   #53 (permalink)
So why did you opt to rebuild the motor? Can one get 350 whp out of the stock motor setup with proper tuning?
blutegra1992 is offline   Reply With Quote
Old 03-08-2009, 06:00 PM   #54 (permalink)
Yeah I think it's good for about 350 if you drive it conservatively. I'm gong for about 400whp and the compression is just to high for the amount of boost I plan on running, plus there are some know failures on things like valves, oil pump gears and pistons even in the low 300's.
Old 04-03-2009, 12:48 PM   #55 (permalink)
So a few updates. I got the intake manifold back from the powder coater, it looks allot better in sunlight with the metal flake. With the engine all back together I'll had left to do was mount the ecu, harness, and the new fuel pressure regulator. Hopefully in the next two weeks or so I'll have it back in the car and running. The last small mod I did was an aftermarket steering wheel (Special hanks to Kverges for helping me find an adapter to work on the Lotus!). It's not a real fancy wheel but it looks good next to the speaker grills.
Old 04-03-2009, 02:41 PM   #56 (permalink)
Lawy'du's Avatar
excellent work sir and thanks for the pics!! +1000 for doing it yourself
03 Infiniti G35, Vortech Supercharged by Relentless Autosports, Custom dual HKS carbon ti exhaust, 19" Gunmetal Volk GT-C's, Kinnetix SSV, Greddy Catch can, BC Sports coilovers, SPL A-arms, SPC rear arms, TS front, CF fenders, etc.
Lawy'du is offline   Reply With Quote
Old 04-03-2009, 04:15 PM   #57 (permalink)
shadowhusky's Avatar
Everything looks great. I'd like to stop by one day as soon as it actually warms up to check it out.
2005 Elise, Aubergine, Touring Pack, Sport Pack, Hardtop, Quicksilver Exhaust, Cup Air Box, Tilting Clam, Mesh Grills all around - ( fabricated, not purchased ) 55w 6000k HID's, Painted Engine Covers, Center Console, A/C Surround, Polished Shifter Arm, Ball,and E-Brake Handle, Multivex Mirrors.
2008 Jeep Liberty, Jeep Green Metallic
2002 VW Jetta TDI, Metallic Blue, Daily Driver, 155,000 miles and going strong
shadowhusky is offline   Reply With Quote
Old 04-03-2009, 05:24 PM   #58 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Running the hydra?
Old 04-04-2009, 07:00 AM   #59 (permalink)
Thanks
Yeah that would be great, but I warn you f you stay to long you could end up with a wrench in your hand.
Running the hydra?
Yeah the Hydra was a good choice for me I have quite a bit of experience tuning vehicles at work.
Old 04-04-2009, 07:04 AM   #60 (permalink)
With some sunlight
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
INA
