#61 (permalink) |
Plug Whisperer
Has she ticked over yet?
#62 (permalink) |
Man it's just the project that never ends!!!
![]() Actually I'm getting close, the trans is rebuilt painted and in the car. So button up the install, work out some basemap issues and then to the dyno. Here is a couple of progress pics. |
#64 (permalink) |
G-200 Driver
I might actually be able to make it up there sometime this week.....I'll give you a call !
#70 (permalink) |
So a coupe of updates, while hooking up the engine electrical harness I did turbophil's split harness mod. You can see across the intake how running the sensors separate of the fuel injectors and deleting the unused circuits really cleaned up around the engine. Thanks Phil!
Hooked up the oil cooler plus lines, fuel lines, the exhaust, and turbo. It's going slow but I hope to have it up and running in less than a month. |
#72 (permalink) |
Great project! I'm really looking forward to how this turns out.
I might have to stop by on one of my trips back home to Michigan.
2005 Graphite Grey Elise - 1893 lbs Setup by Ralph @ V2 Motorsports ![]() Nitron DA, Lotus Sport Swaybar, Braille B2015, S111 RTVBrace, V2arms, V2linx, V2mounts, Panel Delete w/ Larini 8" |
#73 (permalink) |
are the axles new..ie brand new or did you rebuild them?
05 Lotus Elise R/K Supercharger, Stage II, Moroso Oil Pan, RTD Brace, High Volume All Aluminum Radiator, Stainless Steel Break Lines, Oil Catch Can, ACT Clutch, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, Cup Air Box, S111 front & rear tow hooks, upgraded tail lights-LED, Driving lights, LETSLA, ...
#74 (permalink) | |
Thanks! And feel free to stop by I always love shooting the **** Everything pictured is brand new. The stub, and intermediate shaft from the MR2 are carry over everything else was custom. |
#75 (permalink) |
G-200 Driver
New " TOE " links too !!!
#78 (permalink) | |
Yeah, I like the idea for the high horsepower application. I even wanted to try to help out take measurements, or fab up some parts to help with the project but Frank really wanted to do it his way. I posted some comments or suggestions to topic, but typically it turned to an argument. Your right though I did copy the idea of using an aluminum plate for the bell housing, it's much smarter than trying to drill and tap into the MR2 one unmodified. |
#79 (permalink) |
2/3 hp to the paws.
Have you given any thought to running a trans cooler versus looping the ports as pictured? Those boxes do like to get hot. Would be kind of cool to do one situated by the diffuser, and make a NACA duct/scoop for it.
#80 (permalink) | |
I'm also skeptical if it's necessary. A M/T can handle allot more heat than an auto and in the past we always used an upper limit of 300-310 deg F on an auto trans in trailer tow's and durability testing. I would like to see how hot the new trans gets in use. |
