Old 05-19-2009, 05:40 AM   #81 (permalink)
Bender Rodríguez's Avatar
Ok, so I figured since I was redoing the shifter cables and external transmission linkage, why not get one of those over sized clownish intercoolers, and a new intake pipe. So I did.
Bender Rodríguez is offline   Reply With Quote
Old 05-22-2009, 05:11 AM   #82 (permalink)
So a couple more pics of the new IC, Intake, and shift cables
Old 05-22-2009, 05:17 AM   #83 (permalink)
Parts scattered about...
MaineLotus's Avatar
I like the shiny bits, looks nice. Do you think you'll have enough airflow into the intercooler sitting at a closed angle? Are you adding fans?
My car is modified.
MaineLotus is offline   Reply With Quote
Old 05-24-2009, 08:12 AM   #84 (permalink)
Thanks. I think I will add at least one fan although there is more than enough room for two. I also plan to cut off the ear like on your car and add some ducting to help. It's really tough to get a decent working A/A intercooler on our car, I may be naive but I'm optimistic to see what the intake temps are.
Old 05-24-2009, 08:26 AM   #85 (permalink)
MaineLotus's Avatar
I wonder if shrouds would work good here, both directing incoming air into the intercooler and redirecting hot air away from the engine and down to the exhaust area.
My car is modified.
Old 07-27-2009, 08:39 PM   #86 (permalink)
Nice Setup! Any more pictures?
KID 510 is offline   Reply With Quote
Old 07-30-2009, 04:40 PM   #87 (permalink)
OK so no posts in a while. I basically just spent the day getting a basemap up to 12psi (wastegate spring no BC yet). I'm very very very happy with the power. Its really fast! I haven't driven more than 50 miles, but I'm getting allot of pressure in the crankcase. The excess pressure made the valve cover leak and the il drain valve. I went with Mahle pistons and since you don't hone the bores I guess that could be the culprit. Any opinions??? I'm going to open up the crankcase and go with a catch can does anyone know the thread size of the PCV valve to the cover?
So I had my friend drive the car while I tuned the ecu. He's a big autocross guy. He was really impressed with the power but in his opinion since the power output changes so drastically in what would be the middle of you turn it's not ideal for autocross. The car really just needs a little more straight away. It's great on the street and on twisty roads.
Here are a couple picture from today in the current state she is ugly, but fun. I would say the equivalent of dating a fat chick. Fun to ride but you don't want o be caught in public.
Old 07-30-2009, 04:41 PM   #88 (permalink)
Pics
Old 07-30-2009, 05:29 PM   #89 (permalink)
Very nice.
Slightly OT but where did you get that driver's seat? It looks wide in the shoulders and that's what I've been looking for.
2005 Saffron Elise :: Pro-1 Exhaust, Cup Car Airbox w/ TRD filter, Manly Engine Mounts, Shift-I, Bollock, 1/4-turn fasteners, Esta C/F Decklid, de-stuffification, other stuff...
cobrabyte is offline   Reply With Quote
Old 07-30-2009, 06:58 PM   #90 (permalink)
ggelise's Avatar
Hey man what do you think of this setup:
Apparently it does a good job balancing pressure both at the top and bottom of the engine while producing a slight vacuum it the case which is apparently desirable. I know nothing about this so soliciting advice.
ggelise is offline   Reply With Quote
Old 07-30-2009, 07:59 PM   #91 (permalink)
Drunk on alcohol
25psi_Elise_Killer's Avatar
If their is any sort of wiggle room, you should fab some sort of heat shield for the manifold. That manifold will glow red hot when you got WOT and i'm sure the intercooler is not going to like that...
'06 Evo IX Stage 1E Tuned by Road Race Engineering(Stock:turbo,intake,internals,ECU) Walbro 255lph fuel pump,RC Engineering1000cc Injectors, AVO exhaust,RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband,Zeitronix Ethanol Content Analyzer, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com
25psi_Elise_Killer is offline   Reply With Quote
Old 07-31-2009, 02:42 AM   #92 (permalink)
MaineLotus's Avatar
Did you go back to the C64 gearbox, doesn't look like the E153 there.
My car is modified.
Old 07-31-2009, 05:07 AM   #93 (permalink)
Originally Posted by cobrabyte View Post
Very nice.
I picked it up on fleabay, it's hit or miss over there. The one thing that sucks is I had to cut the Bride bracket to get it to fit in and now there is no room for the center console, but still It's real comfortable.
Nope still the E153. Works good (minus the fact I haven't got the spedo or tach working yet) I'm real curious to get the car weighed and find out the total and the distribution w/ the new box. Shifting is a little weird. It goes smooth in and out of gear but I think the way we cut the 153 gear selector to fit the lotus external linkage may not be as accurate as when they manufacture it, so the shifter sits a little to the right. I’m going to play with the cables a little see if I can improve the feel.
I'm going to use header wrap It's sitting on my shelf, I've got allot of final detail to touch up.
Old 07-31-2009, 05:13 AM   #94 (permalink)
Here is a close pic of the trans. It’s the only one I've painted orange.
Old 08-02-2009, 07:53 PM   #95 (permalink)
Got my new decals on (thanks sweet daddy!) Also Quick removal undertray mod done by my fabricator Ryan Thompson. The two rear most undertrays now drop down with 7 1/4turn fasteners.
Old 08-03-2009, 07:09 AM   #96 (permalink)
Added header wrap that should help with heat
Old 08-03-2009, 07:48 AM   #97 (permalink)
Drunk on alcohol
Looks great!!! Have you done a boost leak test yet since the car is still somewhat apart?
Old 08-03-2009, 09:05 AM   #98 (permalink)
No not yet. I haven't even done a compression test. I'm pretty sure there fine but I should check.
Old 08-19-2009, 11:14 PM   #99 (permalink)
So a little update. I finally got the new trans shifting very smooth and I'm loving it. It's probably much more a street setup at this point although I don't see a reason why I couldn't autocross it, but I probably wouldn't see as much benefit out of the setup. Still it's a blast everyone who drives it loves it. Right now I'm up to 15psi and it's really too much for the tires. I'm hoping to get it dyno'd early next week provided I get some more street time with someone else driving. The hydras a little too complicated to drive and tune, so if anyone local wants to come drive while I tune it would be very appreciated. If nothing else it's sure to be fun. Here are some pics from today.
Old 08-19-2009, 11:21 PM   #100 (permalink)
NOT ßANNED!
Demonized's Avatar
If you were in Colorado I'd take you up on that.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
INA
