#101 (permalink) |
Plug Whisperer
You see, all that worry over nothing
![]() Cheers, Phil
#102 (permalink) | |
Meow!!
#103 (permalink) |
2007 Exige S
LOL, but it'll set me back a week -- oh well, I have plenty of "cleanup" work to do on the car between now and when it arrives. Think I'll still be able to make the Infineon event in early Nov...heck I've still got Hoosiers that look brand new along with my race pads.
Found out a few more "issues" around my clutch pilot bearing -- supposed to be grease on the shaft, there is none -- supposed to be grease on the fork pivot, there is none (dry as a bone) ... hmmmm ... might explain why my clutch kept dragging. Better rush out and get my fuel gravity test equipment -- just having a hard time getting the gas station attendant to open up their tanks so I can test it before I pump -- I mean I'm sure my tune is only good for a specific gravity of .754 plus or minus .01 - could spell disaster. Now that's what I call "tuning on the edge"? ![]()
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#104 (permalink) | |
I'm saying that lean mixtures can increase heat and cause detonation. Ever run karts and lean them out and stick a piston? Sure, you can have too much boost and detonate too. Same thing, heat. The range of VP fuel gravity you might find at the track ranges from .722 to .800, quite a difference. For example, a car that was tuned on a fuel with .800 and switched to a .722, will be almost 10% leaner. That's why people read plugs and have widebands. I was just trying to pass on some info. But since you don't seem to appreciate it or believe it, you can learn the hard way. Remember.you're the one who posted the thread and seemed to want some input. |
#105 (permalink) |
2007 Exige S
No that is not correct -- 100 octane race fuel will range from .790 to .800. 91 octane will range from .722 to .760 -- pending ambient temp, humidty, elevation, etc..
Karts for the most part are 2 stroke and rev to 13,000 - 15,000 rpm. And yes I have stuck a piston -- twice, errr...three times. On Karts you get an audioable lean pop during shifts. I've run 98 - 110 octane in a Kart with very little difference in jetting, plug burn and piston check after a chop all was fine -- measuring air density and temp with a race quality weather station -- I had an EGT on my Kart also, 1250 was the sweet spot. Not to mention you mix 6-8oz of OIL in a with the 1 gallon of race gas in a two stroke. These are worlds apart from a 4 stroke 4 cylinder supercharged gasoline engines. If the 100 octane was "bad gas" that day, then every pushed EVO, STi, and whatever else car was out there would have detonated also ... but they didn't. So are you suggesting I bring a gravity tester along whenever I go to gas station? What exactly am I learning? That I can never trust any gasoline from anywhere ever and must gravity test every fill up and then retune the car every time? How is this helpful to me or anyone? I appreciate input from you and anyone, but this sounds more like unverifiable cop out and if logic dictates, it would be pointless for anyone to dyno tune their car -- because they would never know what the specific gravity was for the gas that day and the chances of finding the same gravity gas are pretty slim. Like I said, if a car is tune on the edge like that, then we better all pack our bags and go home.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 09-22-2008 at 09:09 PM. |
#106 (permalink) | |
#107 (permalink) |
2007 Exige S
I understand your point Mike, but there is very little that can be realistically done about variance in fuel gravity. Buying fuel from the same source is NO guarantee of the gravity.
No gas or tune in the world could have reduced the IAT that a 2.5 pully and 62 were producing. A dyno does NOT duplicate the environment of a track even with multiple back to back pulls after heat soak has set in. What will have a better chance at saving motor #2 is real time data logging as I drive the car (either on track or on the street). With my EGT and IAT hooked into my IQ3 dash (and alarm points set) and monitored carefully, I think this is by far a more realistic approach to working with the contents of the gasoline I pump into the car. I may get a wideband in eventually, but I preffer EGT and IAT as widebands do flucuate in quality and durability and do need frequent recalibration and/or replacement. Regardless of who actually produces the gasoline (even VP) there is NO guarantee that you get what you want in terms of specific gravity. I ran a Kart race and got almost DQ'd because my gasoline mix was not legal, turns out the fuel supplier made a mistake and had 110 in 98 cans -- fortunately almost everyone suffered the DQ and hence why the new cans were tested. As I understand it EFI can and does adjust for such variances -- but it can only adjust so far. For reference, Thunderhill provide Sunoco racing fuel 91 unleaded, 100 unleaded, 110 Leaded and now 112 leaded. link to specific gravity their 100 unleaded is a little low but certainly within tolerances.
#108 (permalink) | |
Dynamic Racing Solutions
![]() Join Date: Oct 2006
If you do not have a wideband Lambda already I highly advise that you use one. The EFI is able to read AEM, Innovate LC1, DynoJet, AFX, and NGK so you have options. This will allow the ECU to have more valid authority over the mixtures. I agree onboard EGTs would be helpful as well. If your dash will support a data stream directly from the ECU we should look into that to save you on redundant wiring and sensors. I've been kind of behind on keeping up with all your findings, but just wanted to shoot over some brief comments nonetheless. Kris |
#109 (permalink) | |
2007 Exige S
Kris, I believe the kit does indeed come with a wideband -- well it certainly looks like it does because I have a wire that is labeled "lambda" that was going into what does look like a wideband sensor that went into my exhaust pre-cat. Looking at the FF kit here in the upper right that looks like a wideband to me. Should I be sending this away to validate it's accuracy?
Hmmm...maybe I don't have a wideband ... Quote:
RacePak have told me they use CanBus ... but it wasn't clear if it is compatible or if they have a module that will make it compatible. I do have a universal box for the IQ3, but that is to monitor analog type voltage changes from existing sensors, not a digital line -- which I think is what the CanBus is?? But I will maintain, that if I have to monitor a fuels specific gravity every time I fill up the tank, then having anything beyond stock is gonna be way to much work for me -- implications for that are that I'll go back to 100% stock (aka no EFI). I don't mind taking calculated risks, but if the risk is so closely tied to the specific gravity of fuel that could vary greatly at each fill up, then yeah, it's a risk not worth taking at all. I'm willing to bet that not many people here with modified engines even have a specific gravity testing unit.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 09-24-2008 at 12:14 AM. |
#110 (permalink) | |
I agree that it would be silly to have to worry about specific gravity tests just to run your car. Your engine should not be in a state of tune where this will "make or break it". I think the guy who was sharing his knowledge about the fuels was just trying to be helpful. The bottom line we need to make sure you have a safe map that is not on the edge. We can discuss that in more detail later. Kris |
#111 (permalink) |
2007 Exige S
Cleaned up the head today while waiting for my 2nd new short block to arrive.
Couple of the valve caps did come off, thanks for the warning Phil. Exhaust ports took some serious cleaning, ugh they were gunked up with burnt oil. Valves appear to be fine and no damage anywhere. I was searching the manual and couldn't find any references to using any type of sealant on the head surface -- so I'm just planning to use a new head gasket which does have a thin layer of black "stuff" (technical term) bonded to the metal gasket. Rob.
#112 (permalink) | |
Plug Whisperer
Sorry for being MIA over the past week... had one or two fires to put out at work ![]() Looks like you're on the road to progress... No special sealer for the HG. Just put it on and go... You may want to paint the block if you want to keep it looking good as that bare aluminum will build up surface deposits in short order and will look like your old engine... Nit picky, since you can't see much of the engine, but "I'm just say'in" ![]() Best, Phil
#113 (permalink) |
2007 Exige S
Pimp my ride
-- Gray, Lotus Green, or Blue or Red... choices ... dang, maybe I should paint the valve cover while I'm at it ... Well the old engine did have that issue with the original water spray that was just dumping water (not spraying it) on the engine/tires followed by my rapid departure into the dirt at 100+ at ButtonWillow.
#114 (permalink) |
2007 Exige S
Engine assembly...
Update pics of engine assembly
It's finally going back together ... I think the most time consuming part is cleaning everything. Rob
#115 (permalink) |
2007 Exige S
#116 (permalink) |
Plug Whisperer
#117 (permalink) |
Have I missed something in this thread? Have you determined what may have been the major factor in your engine failure? I saw you mentioned the 2.5" pulley (I assume S/C pulley), I have also heard the rings (stock) hold well until about 275 crank HP then they start to go.
What do ya'll think?
2005 Bordeaux Met #21 (HT, Touring, Quicksilver ext, TRM F1 wheels, Stan Stud, HID lights, BWR S/C,Filled motor mounts, catch can, no camber shims, Tillett saddles) 2004 Audi S4 Sedan (Tip, GAIC Chip, AWE Cat-back, Team Dyanmics Pro 1.2 wheels, H-sport sway bars) 2002 F-350 (Powerstroke, 4x4, Banks power pack, 6th alternator) Couple nice bicycles, way too many snow skis. |
#118 (permalink) |
2007 Exige S
2.5" pully causing excessive heat which in turn caused detonation. You can see the obvious copious amounts of detontation on the pistons from the pics I posted. Those metalic sprinkles on the pistons is aluminum that gets "detached" and redistributed when detonation starts in.
It's not the rings, they hold up just fine. It's the heat that the 2.5" pully generated from the M62. It's a suicide kit on a stock motor IMHO. Hope to post more pics today with the motor running -- fingers crossed.
#120 (permalink) |
2007 Exige S
Found some more install issues with FF "Power Package" - connector to EFI lambda from the pre-cat narrow band O2 sensor -- one of the gold male connector prongs was NOT locked into place in the 4 prong connector. End result was the prong being pushed back when connecting the narrow band O2 sensor. Turns out it was the white/black signal wire the EFI uses ... not good. So there probably was NO AFR adjustment happening at all.
Completion schedule: 1. Moroso pan Monday night 2. Throttle Body Tuesday night 3. Cat/Muffler and fluids (coolant/oil) in Wednesday night 4. RLS IC Thursday night (need to modify IC bracket) 5. Prime and test start Friday night some more pics Notice that the RC 550 injectors really don't fit -- the connectors will never "lock" in place as they press against the head. If anyone has any idea where the two wires go in my pics, please let me know -- I have no idea why FF cut these and left them dangling with NO protection on the ends (aka they could have be touch chassis/ground). They feed into whatever the device is behind the wires. Thanks, Rob.
