Old 11-04-2008, 03:05 PM   #21 (permalink)
BANNED
Guys Frank's [ronin] chargecooler runs 5* above ambient with 23 psi. of boost all day, any day of the week, it's all in the hardware and placement of the exchangers.. check out MM
REGGIEPLUS is offline   Reply With Quote
Old 11-04-2008, 03:12 PM   #22 (permalink)
OSX Black hat
charliex's Avatar
I think its one of mine, pes don't Exige S OTS as far as i know.
Old 11-04-2008, 03:15 PM   #23 (permalink)
Originally Posted by Stale_Hotdog View Post
Wow! Very interested! any ETA on when you'll have production units for sale?
Production for the intercooler setup is very very near. I can probably have a few ready to roll within two weeks or so.
Originally Posted by Pestodude View Post
where exactly is the heat exchanger mounted? Stacked with the AC condenser and the radiator?
The heat exchanger is mounted in front of the fans. It uses an existant bolt hole, but you will use a bigger one for the mount. you do not have to disassemble the radiator/AC condensor to install. a big plus.
Mase,
You mentioned the car has a reflash. Was that one of Charlie's OTS flashes, PES, or standalone?
Nice work on the exhaust. Looks very clean
Best,
Phil
The test car has one of Charlies flashes. we may look into a smaller pulley upgrade now that we have the intake temperatures in order.
http://www.MaseEngineering.com
Website is up.
Mase is offline   Reply With Quote
Old 11-04-2008, 03:23 PM   #24 (permalink)
OSX Black hat
charliex's Avatar
I have a smaller pulley upgrade for the S thats in testing for people with dynos, proper air fuel gauges and aren't muppets.
Old 11-04-2008, 03:38 PM   #25 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Reggie,
Frank has a really cool setup- no doubt about it-, but he's also got more radiator surface than a Mac truck. He's even got a radiator in his boot. As I count (and I could be off a bit), he's got 4 radiators up front where three are used for charge cooling and 1 for cooling the engine, and 2 in the rear where one is used for charge cooling and the other is for oil cooling. This is just waaaaaay more than what *most* are willing to do...
Mase mentioned that he's trying to get performance increase without canibalizing the car much, if at all, which is the same goal that I, and I think most, are after.
Mase's solution seems really similar to Pro Alloy's setup that Sector111 carries. I know as well or better than most how much effort it takes to make a quality part and I'm excited to see another guy/company making some quality parts if that's what they turn out to be... I don't think you can even remotely compare Frank's setup to anything in this thread. Right, wrong, or indifferent...
To that end, it would be nice to see some of that before and after data before anyone gets too carried away...
Cheers,
Phil
Old 11-04-2008, 04:44 PM   #26 (permalink)
(Formerly PESTODUDE)
Illumiloti's Avatar
"The heat exchanger is mounted in front of the fans. It uses an existant bolt hole, but you will use a bigger one for the mount. you do not have to disassemble the radiator/AC condensor to install. a big plus."
But is it stacked against the other two heat exchangers? (with the chargecooler rad. on the bottom, AC in the middle, and the radiator on top).
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune.
Illumiloti is offline   Reply With Quote
Old 11-04-2008, 06:54 PM   #27 (permalink)
right seat driver
Brent Bauman's Avatar
Muppets
Brent Bauman is offline   Reply With Quote
Old 11-05-2008, 11:05 PM   #28 (permalink)
DENNAB
Stale_Hotdog's Avatar
Crap that rules me out as a beta tester.
Stale_Hotdog is offline   Reply With Quote
Old 11-07-2008, 11:58 AM   #29 (permalink)
No its not stacked. If we stacked them we would have had to disassemble the entire radiator/ac condensor system. as well as move fans. My heat exchanger mounts through the main air flow inlet. When i get back home (traveling as we speak) I will post a picture of how it is mounted.
Website is up.
Old 11-07-2008, 02:39 PM   #30 (permalink)
Illumiloti's Avatar
Pics would be great. I want to see how it mounts without blocking airflow to the radiator.
Randy
Old 11-08-2008, 11:28 PM   #31 (permalink)
without a Lotus
FLuXeXigeS's Avatar
Wink
Originally Posted by Brent Bauman View Post
Muppets
Muppets
Charlie care to explain?
-Coi- currently having Lotus withdrawals
Facebook | Twitter | Pics | Vids
eBay Store
FLuXeXigeS is offline   Reply With Quote
Old 11-10-2008, 09:47 PM   #32 (permalink)
Exige Prestige
Trendy Exige's Avatar
Wink
Its a British slang for an idiot or a tool...My ex-girlfriend from Manchester uses that term a lot when shes watching a UEFA soccer match.
Originally Posted by FLuXeXigeS View Post
Muppets
'07 Exige S (Storm Titanium) - Gotham 265, Arqray Titanium Double-Tip Exhaust w/ Arqray Sport Cat & Euro Grills, TWR Dry Carbon Cup Roof, LEA Dry Carbon Adjustable Wing, Prototype Composite Dry Carbon Front Spoiler, Reverie Dry Carbon Side Skirts & Dry Carbon Side Scoops, 17's Team Dynamics 1.2G Matte Black Wheels, Painted Bulkhead Panel, Painted Consoles, 6k HID w/ Raybrig JDM blinkers, Cup Car Airbox, RLS IC Pipes, Saikou Michi Catch Can, Rear Camera, Venture Shield Entire Front Clam etc.
Trendy Exige is offline   Reply With Quote
Old 11-11-2008, 12:11 AM   #33 (permalink)
without a Lotus
FLuXeXigeS's Avatar
^got it...
eBay Store
Old 11-11-2008, 02:02 AM   #34 (permalink)
spf4000's Avatar
Sweet. What kind of water pump setup are you using?
Where do I sign up?
spf4000 is offline   Reply With Quote
Old 11-13-2008, 06:14 AM   #35 (permalink)
Exige Prestige
Lightbulb
This seems promising and economically sound compared to others. I would like to see more test results before I include myself into a group buy.
Hopefully we can keep our existing intercooler pipes the same length and attach it with the water to air intercooler your offering.
Old 11-13-2008, 10:52 AM   #36 (permalink)
Prez: The K.G.B.
MickOpalak's Avatar
I'm daydreaming about replacing the intercooler on my Exige S with this and then replacing the blower with the twin screw one from that other thread. Can you say rock-steady 325 hp!!!
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - stripes - harnesses - Pagid pads - Green air filter
2002 Jaguar XKR convertible
2000 BMW 528i
President - Lotus Limited Southeast
http://autos.groups.yahoo.com/group/LLSE/
MickOpalak is offline   Reply With Quote
Old 11-13-2008, 11:16 AM   #37 (permalink)
EliseAtLeast's Avatar
Why daydream? Go for it hehe
'08 Honda S2000 CR (Rio Yellow Pearl)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'04 BMW 330 ci (White)
EliseAtLeast is offline   Reply With Quote
Old 11-13-2008, 11:19 AM   #38 (permalink)
OSX Black hat
charliex's Avatar
don't forget about building the motor then too
Old 11-17-2008, 09:06 PM   #39 (permalink)
There is a pic of how the heat exchanger is mounted.
Website is up.
Old 11-18-2008, 12:27 AM   #40 (permalink)
Exige Prestige
Oh wow!!! Thats tiny!!! I hope its sufficient enough.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
nobug
