#61 (permalink) |
Blue Wheel Pimp
most likely down the side sills.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development |
#63 (permalink) |
Blue Wheel Pimp
I just ran new lines down the sides of mine. I replaced the 5/8" oil line with 3/4" hose for the water for my air to water.....its not fun running the lines but its doable.
#64 (permalink) |
2007 Exige S
Hopefully this isn't ancient history, I'm keeping an eye on this thread. Alternatively is also Sector 111's setup here
But on a side note, I "thought" it is not necessarily better to have air charge temps too cool as fuels atomizes better at a specific temp (read higher but not too high)? Different fuels will have a different optimal air charge temp, no? (non-direct injection) question, not a statement. Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#65 (permalink) | |
2.0-6262
i'd go with this for $1,200 rather than the cost of that Sector 111 which is rediculously priced. ![]()
Please PM if you need anything, i am working from home now. |
#67 (permalink) |
2007 Exige S
Dustin,
Hehe, that's what I'm using, only in black (or is it?) Where did you get the Euro style shocks for keeping the hood up? I noticed I have pre-drilled holes for this style shock -- but can seem to fine a source?I think that's the RLS - my RLS - Dustin's looks little different but about the same size. Rob
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 03-18-2009 at 10:33 AM. |
#68 (permalink) |
2.0-6262
not my car or anything, this is from a company we are a dealer of , i dont want to steal this thread's real attention so PM me if you have questions.
#69 (permalink) |
damn sure looks a lot like my custom set up, except we put my cooler mounted behind the passenger side vent with a fan behind it sucking air through the vent (with the bigger c/f vents of course). we thought this was an easier and just as efficient idea rather than taking the whole clam off which most dont like to do. heres a pic....
'07 Exige S Chrome orange way to many mods to list so heres a summary 10psi, 550cc injectors, EFI ECU, full bolt ons, custom PWR water to air intercooler setup, lots and lots of carbon fiber inside and outside, Pioneer N4 navi flip out with camera 247whp 163wtq mustang dyno |
#70 (permalink) |
Blue Wheel Pimp
you went with the little one.
This is my setup using a barrel: ![]()
#71 (permalink) |
Denuo Volatilis
...is it possible to run a liquid-to-air intercooler off of the spare cooling capacity of the new lotussport triple-pass radiator, and just keep the extant dual oil coolers in place?..or, i suppose conversely, use the OEM dual oil coolers to chill a liquid-to-air intercooler and cool the oil off of the triple-pass radiator as intended...
2005 Federal Elise | Touring | Storm Titanium ...73,000 miles and aging beautifully... 2000 New Beetle | Turbo | Reflex Silver ...107,000 miles of steadfast service... |
#72 (permalink) |
2007 Exige S
Nice folks, great job!!
Any chance you'll share your IAT track data with us? Cheers, Rob.
#73 (permalink) |
JabStrongFierce
Rob - I'll be using the same 4 units from PWR that AJ has very soon. Replacing the two front oil coolers, adding a center heat exchanger, replacing stock radiator with larger unit. I'll be at a Jack day soon too so will send you my EFI data once I dump it down to a laptop that day...
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning |
#74 (permalink) |
ya, i went with the 4" x 10" PWR barrel, it says good for 300hp which is good for me now, and i like the other little advantages of the smaller one such as weight, price, i was able to cut off about 6 inches of the piping from the hot side. i might in the future try a bigger one if i have more power, but right now i think this ones fine. O and thanks to Thomasio (RLS) for for making my pipes on both sides!! they look better (even until i get them coated) and weigh about 3 lbs less!
#76 (permalink) | |
NOT ßANNED!
Make a new thread with all technical information.. imo.edit; Blog › New Lotus Products | Mase Engineering | Tuning, Consulting, Product Development
#79 (permalink) |
2007 Exige S
Just a thought, has anyone run two smaller side inlet radiators, two pumps, and leave the roof scoop for air to pass over/thru the engine bay? Avoid running hose all the way up front and trying to find an efficient unused area for the single rad.
How much additional weight does this kit add? And price? Thanks, Rob.
