#81 (permalink) |
I <3 chicken, I <3 liver
With lower IAT it would mean denser air and I'm guessing will lean out the A/F.
#82 (permalink) |
Hello all again,
Ive plotted some of our data from our testing between the stock intercooler and our Liquid to Air Kit. ![]() The top three, very consistant lines, Colors Dark Red, Blue, and Orange are back to back (meaning wide open throttle pull. then slowed back down and did it again, immediate) dyno pulls with our liquid to air intercooler setup. The not so consistant lines, colors light red, green, and light blue are from the stock Air to Air intercooler doing back to back dyno pulls. The liquid to air setup stays extremely consistant, and you are not susceptible to the heat soak issue as you are with the air to air setups. Price is $1695 Shipped anywhere in the main united states. If I have orders 5 or greater, I could knock off $100 dollars. I have two spoken for already. ![]() Everything needed is included for installation, down to the wiring harness, new aluminum intercooler pipes, high quality silicone couplers with upgraded t-bolt clamps. Regards, Mase |
#83 (permalink) | |
NOT ßANNED!
#85 (permalink) | |
I'll post up some track results in 100 degree track conditions possibly sunday or monday ![]() Regards, Mase |
#88 (permalink) | |
2007 Exige S
Thanks, Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#91 (permalink) |
Blue Wheel Pimp
Exige S Only
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development |
