#321 (permalink) |
Meow!!
Jesus Jim!
13.10 at 112mph clutch babying it with a 2.66 60 foot? Wow! Two Sunday's ago I went with my 3.4" Katana and managed to get this (on General UHP extreme summer "street" tires) with very shallow staging and a near perfect launch (3rd gear's still a non-syncro'd beotch though): 60': 1.781 330': 5.270 660': 8.172 @ 86.86 mph 1000': 10.629 1320': 12.697 @ 112.10 mph That's with me weighing in at 2030 lbs. at the line. Track conditions were 54 degrees, 29.98 pressure, 63% humidity and 800' elevation. I'm running the leg buster ACT XTSS clutch that's rated for 275 ft/lbs. If you got the same 60' that I did your time would be at LEAST a 12.22 second time (13.100 - (2.660 - 1.781) = 12.221) with a higher trap speed. You're hitting the 8500 rpm 115-116mph wall there... Can you post your entire timeslip? I'd especially love to see your 1/8 mile trap speed... it really picks up speed in the last 660'... Do you have a guestimation on what your "track weight" was? What were the track conditions? (I just looked up Jupiter - Palm Beach International Raceway @ 33478 and saw it was 8' above sea level and the 6pm weather was 73 degrees, 30.02 pressure and 56% humidity. That's just about the same correction factor that I had a couple of week's ago... My 19 degree colder temperature just about balances out your 792 elevation difference...) ![]() What monitoring do you have (A/F, temps?). I'm dying to see what she'll do with our stock 11.5 compression pistons... Finally... when are you going to dyno her? ![]() Hmmm I wonder what a stock Katana flash would do with the TVS... Hmmm.
d.a..v...i....d David Thomas Stewart - davidtstewart@gmail.com TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs. Lotus cars aren't made, they're hand built from dreams. If you must choose between two evils, pick the one you've never tried before. Last edited by darkSol : 12-07-2008 at 12:21 AM. |
#325 (permalink) |
2007 Exige S
Well you folks are crazy for drag racing these cars
I tried this on a stock clutch at only 255 wHP and three runs pretty much killed the clutch and I upgraded to Toda clutch/flywheel. Before the stock clutch was deemed dead, I was able to pull a 12.2 @ 112. or was it 111, close to that. But my tranny has suffered somewhat from it so haven't wanted to go again -- just want some road course time now (I need it). Post drag strip, stock clutch started slipping a lot in all gears and I was only at 188 tq. Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#326 (permalink) |
Mods are good for you
Well it was road test day...
Did some country driving tonight. Need to add a pinch of fuel to the map <4K cause it's a little lean. Going to download the logs and make the adjustments tomorrow. I punched it down a couple of times. The 2nd punch was a transition to 3nd gear and the rear end broke loose...scared the hell out of me. Never had that happen in 3rd gear, tires are almost new. Thought my car had great torque before with 245/160...this is insane power!! I miss the s/c whine too like Jim said, but more than happy to trade for this wickedness ![]()
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
#327 (permalink) |
Blue Wheel Pimp
any IATs or EGTs being logged?
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development |
#329 (permalink) | |||
330' 6.115 660' 8.982 87.48 mph 1000' 11.135 1/4 13.165 111.91 mph Not sure, I haven't removed any weight to speak of. Quote:
Dyno next Friday if my clutch is okay. I need a test drive.
2005 Elise Storm Titanium |
#330 (permalink) | |
Dynamic Racing Solutions
![]() Join Date: Oct 2006
Kris
Motorsport Components and Expert Service. Complete Lotus maintenance, installations, track preparation and specialty services. |
#331 (permalink) |
Dave and Jim,
I would like to see some data logs from your ECUs. Please email them to me when you get a chance. Curious to see the IATs and how the ECU is correcting for the new blower in general. There is built in margin of error in every map based on how the correction tabels are set up. thanks, Kris
#332 (permalink) | |
Plug Whisperer
![]() I asked if she would mind running the laptop during our Sunday night cruise and she agreed My wife rocks ![]() So it should be fixed now and in yours and Jim's inbox as of a few minutes ago... Cheers, Phil
#334 (permalink) |
Yall have sure sold me!
I would possibly be interested in a group buy discount, although mine would be an upgrade (already have a BWR s/c). This would be the second group buy for me in the past few months! Rick
2005 Solar Yellow Elise touring package, star shield, hard top, soft top, ACT HDSS clutch, Saikou Michi catch cans, LED tail lights and VF II, 288 whp ( )2001 Green Toyota Tacoma, 4 x 4 2008 Red 5455 Massey Ferguson, 6 x 6, cab, ipod, GPS navigation, regular beer holder 2001 Yellow Cat D3G-LGP, custom made beer holder |
#336 (permalink) |
uprated fuel pump form elise-shop
I don't know this fuel pump is fitted for toyota-engined Elise and Exige.
Uprated Fuelpump (Elise S1, Exige S1, 340R) [FPES1] - 399.00*EUR : Elise-Shop :: Innovative products :: Worldwide delivery :: Fast service --------------------------------------- Designed specifically to remove the need for a secondary pump and swirlpot when supporting high output engines, This unit is a direct replacement for the standard unit and is 100% compatible, the resistance of the sender unit, all external pipes and connections remain standard, only the sender arm and the two quick connect retainer tabs on the fuel pipe connector spigots need to be swapped over to the new unit. Remember, this is a brand new unit not just a pump and is supported with a 12 month warranty. It is perfect choice for standard engined cars as well as it offers future-proofing against later power upgrades. Although the unit looks very similar, it is a modern unit and is far superior in design, the unit utilises a educter pump to transfer fuel from the tank to the reservoir can, unlike the old unit that used one section of the pump itself for this task. The pump itself is a vane type and is more efficient than the original centrifugal pump especially at the higher pressures needed for the Honda powered cars. Further, this unit is modular in design and can be fitted with very high output pumps for those wishing to play with 250-450BHP! The pump will supply at least: 120 lt/hr at 45 psi, and 100 lt/hr at 58 psi Allowing 15% flow loss, this is sufficient to support up to: 300 BHP for NA Rover engines based on a BSFC of .5, and 260 BHP for NA Honda engines based on a BSFC of .45. For S/C cars and those over 250bhp a variety of pumps may be fitted into the unit depending upon output, units may be returned to us for modification or can be supplied pre-fitted. please ask for details and prices. When compared to the standard Lotus supplied AC Delco unit these units have the following advantages: -Units are modular and may be fitted with other pumps, ALL of which are superior in design and output and will not suffer from output decay quickly, as do the OE pumps due to their poor seal design. Units have an advanced educter pump powered by the main pump to transfer fuel. Despite their higher output, the pumps draw less power than the OE pumps, indicating just how inefficient the OE pumps are but more importantly removing any need to uprate the wiring harness. The standard pump is quieter and even Walbro fitted units are quiet due to the superior vibration absorbing suspended pump sleeve design. ------------------------------------------
2007 Elise / Laser Blue / Toybox48 wheel / Larini Sports Exhaust / Larini Sports Cat / Ohlins 2-way Suspension / liquidcaddy cupholder / Stock harness bar / 4 point seat belt / white double line stripe / 3.3kg Fire Extinguisher / Engine Room LED Light / Engine Hood grill modification / V-Shield(like Starshield)/C-One Final Drive(4.529->4.8)/ACT XTSS clutch Kit/Fidanza Aluminum Flywheel(7.5lbs) |
#337 (permalink) |
2007 Exige S
Don't take this the wrong way but why would one want to spend $500 US on a lower lph unit rather than just getting one of these Walbro 255 lph pumps for $125?
Somewhat confused? Rob.
#338 (permalink) | |
Yahoo! Got my Rotus!
I had plumbed an external on my 550 spyder replica and found it just another point of failure for fittings. I took a gasoline bath more than once, and carried a big fire extinguisher with me at all times ![]()
David Avery 05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE 08 BMW 135i Stock visit Spyderclub.com |
#340 (permalink) |
Blue Wheel Pimp
I have walbro 255 internal that fits right in place of the stock pump.
