Old 03-19-2009, 10:27 AM   #1041 (permalink)
OSX Black hat
charliex's Avatar
Exactly, dyno's are tuning tools , the dynapack than the dynojet moreso i think, the important numbers are the differences between the baseline run and the final runs, in the powerband, people that focus on peak HP are generally just doing it for marketing purposes thats all its really useful for, if you just simply must try to factor numbers between them for whatever reason, at least start with the torque readings, HP is already generated from the torque, and even though different dyno's calc torque in different ways, HP is going to be derived from the the torque figures.
i read in a post a while ago from the dynapack engineers that one reason they changed the methods used to calculate numbers was simply because of dicussions like that, even though they preferred the other way, it got so out of hand that the calcs were changed, i think thats one of the reasons you see different values for different versions of the dyno software, same for dynojets too, different versions give different readings and very importantly the dyno operator can set a different scale, its not the same from dyno to dyno.
but the dynojet has a whopping great roller turning.
i think the a word from the link from churches ( a dyno shop we've used in the past too ) sums it up best, "don't"
Old 03-19-2009, 10:49 AM   #1042 (permalink)
2007 Exige S
robains's Avatar
Back when I was racing full seasons, podium finishers would be required to have their cars dyno'd. It was kinda a joke as it got to the point where we all knew what dyno would be used and what it would typically read in variance from other dyno's. End result is that we'd tune the car for the dyno being used at each track -- the variance was that significant. wheel dyno's were used, not engine dyno's for obvious cost/time reasons.
One of our series rules was a 9.5:1 weight/HP ratio max.
Old 03-19-2009, 10:55 AM   #1043 (permalink)
OSX Black hat
charliex's Avatar
Indeed, there are so many factors you can alter on each dyno, I've seen operators change them run to run.
Dynojet are local to me in vegas, I go in from time to time, its really interesting to see and hear the stories they tell about this sort of thing and some of the photoshops / slogans they've got on the office walls, a lot of head shaking going on, Dynapack had similar stories when I went there.
I'd like an engine dyno, i just don't think my neighbours/HOA would be into it though
Old 03-19-2009, 01:43 PM   #1044 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
They'll let you have one if you give them a free tuning session whereby you say you can get more MPGs from their vehicle.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 03-19-2009, 04:06 PM   #1045 (permalink)
Eyelise's Avatar
I just installed a heater in my garage in anticipation of my TVS kit arriving soon. Phil don't disappoint me.
Eyelise is offline   Reply With Quote
Old 03-19-2009, 04:16 PM   #1046 (permalink)
Mods are good for you
Dave's Avatar
Trust me, it's worth the wait and you'll love it.
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 03-19-2009, 04:40 PM   #1047 (permalink)
2007 Exige S
robains's Avatar
Phil's good on delivery, I just received Phil's fuel delivery setup today -- can't wait to get it installed -- this alone should help make motor #3 last a lot longer -- you'll be yet another TVS owner I'll envy.
Old 03-19-2009, 07:32 PM   #1048 (permalink)
2zz exorcism complete
dstevens's Avatar
Images: 4
Dynapak & Dynojet results
It gets more interesting if you go beyond looking at peak figures and plot the curves against each other. One of my cars made more power at 4000-5000 rpm on a dynojet than a dynapak, but less at peak.
If you then plot the the difference you'll get a curve which shows a power relationship between speed and loss (mathmatical power, not engine power). I believe that the tire loss is a function of the square of the speed. Thus there is less loss on low speed low hp engines than the opposite, and therefore you can't use exactly the same correction factor between dynapak and dynojets.
-2ZZ +K24 +150hp +118tq +7mpg +LSD -30lbs -CoG +F.bias
dstevens is offline   Reply With Quote
Old 03-21-2009, 07:15 PM   #1049 (permalink)
E.D.'s Avatar
The BOE TVS kit ordered, thank you Phil!!!.....A/W intercooler will be added by Intermecanica....let the fun begin...I hope to post dyno soon after I come back from vacation April 20.
Enrico
'06 Laser Blue/Magnolia Lotus Elise * BOE TVS SC * EFI * Lots of other things
'07 Graphite Grey/Tan BMW 335i w/JB3 tune, Helix IC and BMS DCI
E.D. is offline   Reply With Quote
Old 03-22-2009, 07:01 AM   #1050 (permalink)
jim-clayton's Avatar
Congrats !
What are you going to be using for an intake? The IC connection.
2005 Elise Storm Titanium
Old 03-22-2009, 07:48 AM   #1051 (permalink)
E.D.'s Avatar
Originally Posted by jim-clayton View Post
Congrats !
I'll see if i can make a picture of the Katana Elise who already has this A/W IC setup although i'm not sure when I'm going to be at my garage.
I remember the intercooler (the 'iron box') is on the driver side with a standard air filter cone attached to it, the pump is on passenger side. It will run on water, alcohol or combination of the two. Sorry, can't recall details anymore, it has been some weeks ago. If you want I can give you phone# / email of my garage who installed it on the other elise and will also install it on my Elise. He can tell you the details.
Enrico
Old 03-22-2009, 08:15 AM   #1052 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Congrats BRO!
Old 03-22-2009, 10:20 AM   #1053 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Very Cool Guys. I'm actually machining on some of your bits 'n pieces today
I updated the website with a little more EFI info, and some other wiring diagrams and whatnot (that many already have) that may come in handy... I'll continue to add to the site to try and get some more handy info out there for this and whatever else???
Best,
Phil
Old 03-22-2009, 04:46 PM   #1054 (permalink)
avonnieda's Avatar
Hi Folks,
First post! I'm the proud new owner of a 2005 Elise, to replace my 2000 C5 Corvette, and I couldn't be happier about the decision!
Anyway, it was this thread that had a a major impact on the model I chose, as I had originally been looking at factory supercharged Elise's, so I've saved quite a bit of money by dodging that. Oh, and the fact that I live 20 minutes from Stilwell KS could come in handy in the near future! So thanks for all the great info in this thread, it was very helpful!
Best regards, glad to be part of the Lotus community!
-Adam vonNieda
avonnieda is offline   Reply With Quote
Old 03-22-2009, 04:55 PM   #1055 (permalink)
Meow!!
darkSol's Avatar
Adam, what color is it? Please don't say Graphite Gray
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 03-22-2009, 04:58 PM   #1056 (permalink)
ZAMMY
ok, it's your job to keep an eye on phil....after all, SOMEONE'S got to do it!
his supercharger oughta really turn your '05 on!
welcome.
sam
Old 03-22-2009, 05:02 PM   #1057 (permalink)
avonnieda's Avatar
Nope, I had to be different, it's Saffron Yellow
2005 Saffron Yellow Elise, desnorkeled - Hey, it's a start..
1997 Ducati 748
Old 03-22-2009, 05:26 PM   #1058 (permalink)
NOT ßANNED!
Demonized's Avatar
Old 03-23-2009, 08:13 AM   #1059 (permalink)
Porsche-Pro
perryeyges's Avatar
Phil,
The TVS was THE supercharger that Forcedfed wanted to use on my car but they were unable to source one at the time. I am VERY interested!
Do you think it would be advisable to loose my water to air intercooler? I would still have to keep the entire liquid system(hoses, pump, etc.) since I have a liquid cooled oil cooler in the same system. Is getting rid of the oil cooler altogether on this engine an option. I do live in a temperate area. SF Bay Area. I would love to loose the weight! My coolant pump is about 20lbs!
Call me if you get a chance(510)502-0172
perryeyges is offline   Reply With Quote
Old 03-23-2009, 08:20 AM   #1060 (permalink)
Meow!!
darkSol's Avatar
Frakking wahoo!!!! We have more color in KC!!!
(sorry triple StarBucks is kicking in )
d.a..v...i....d
