#1142 (permalink) |
2007 Exige S
That's my guess at what Dave can do, those aren't my times. I figure I ran a 12.2 @ 112 a year or so ago @ 255 wHP and I'm not that great of a drag racer. So I figure with a better driver and 280-290 wHP and less weight Dave will post one of the 3 times I listed -- just a guess
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#1144 (permalink) |
Plug Whisperer
^ that was jim on his TVS I think... heck I can't remember????
#1146 (permalink) | |
My new and improved clutch is borderline. I should have gotten something stronger.
2005 Elise Storm Titanium |
#1147 (permalink) | |
Plug Whisperer
The good thing about being a one legger with a marginal clutch is that the tranny gets some relief ![]() Phil
#1149 (permalink) |
Dynamic Racing Solutions
![]() Join Date: Oct 2006
Someone need a Tilton double-disc set up from DRS to hold that TVS torque?
Motorsport Components and Expert Service. Complete Lotus maintenance, installations, track preparation and specialty services. |
#1150 (permalink) |
Plug Whisperer
Ya sure... just send it on over
#1151 (permalink) |
I just drove the Tilton double disc for the first time a few days ago. The pedal is noticeably stiffer but with still a lot of room for initial slip but one it grabs you know its time to go. I drove it for probably 50mi, some dyno, a lot of city street driving and some freeways too. Maybe only stalled it once or twice just getting used to it but other then that, no problems. Highly recommended.
EB Turbo
Guldstrand Motorsports Technician. Burbank, CA. PM for custom work and service quotes. |
#1152 (permalink) |
Meow!!
If I remember correctly Jim ran a 13.165 @ 111.91 mph with his clutch slipping all over the damn place... and a 2.548 second 60' time. Pretty damn impressive!
I need to be able to hit 8700rpm to avoid hitting 5th gear... then I should be able to pull a 11.75 @ 121.3 mph run... If I'm stuck at 8200rpm then I'll run 11.99 @ 114.5 mph. The shift is just at the wrong time... ![]() Here's the shift rpm vs. ET table: shift rpm / time slip 8000 = 12.10 @ 113.0 8100 = 12.05 @ 113.6 8200 = 11.99 @ 114.5 8300 = 11.93 @ 116.0 8400 = 11.88 @ 118.0 8500 = 11.83 @ 119.9 8600 = 11.79 @ 121.1 8700 = 11.75 @ 121.3 (no shift to 5th) 8800 = 11.72 @ 121.5 8900 = 11.69 @ 121.6 9000 = 11.66 @ 121.7 Yeah the XTSS clutch requires more "pedal power" but it holds everything... so far ![]()
#1153 (permalink) |
Plug Whisperer
Funny thing is Dark's tables are always deadnuts on with drag racing... Craziness!
I'd like to chime in on Dark's future run since I'm probably the guy that's going to have to fix the darn thing when he floats the valves to the moon I say we raise your rev limiter to 8,500 and not a rev more for one or two passes so you can hit 120ish--- but if you cheat me and raise it past 8500 and float the valves (stock head), you're fixing the engine on your own![]() ![]() ![]() ![]()
#1155 (permalink) | |
Live to Drive
Yeah... How much? ![]() Interesting note, a Twin Turbo Gallardo from Underground Racing (making 1500+whp) just blew this clutch at private runway... Yikes...
Be an alpha male. Drive a Lotus. |
#1157 (permalink) |
I have the same XT-SS getting installed on my TVS setup (TVS installation is scheduled to start upcoming Mon), i think that s/b OK based on the ACT ft-lbs max. figures.
Enrico '06 Laser Blue/Magnolia Lotus Elise * BOE TVS SC * EFI * Lots of other things '07 Graphite Grey/Tan BMW 335i w/JB3 tune, Helix IC and BMS DCI |
#1158 (permalink) |
2007 Exige S
I guess no one likes the Toda Racing stuff
-- but there again, I'm only running a miserable 250 wHP @ 164 TQ, but for what it's worth, when I was running the 2.5" pully @ 188 TQ the clutch didn't slip at all (in any gear) and is very street friendly.
#1159 (permalink) | |
The labor to replace / change is the killer. Then again, I would rather slip the clutch a little and not bang the tranny. I had no issues with the clutch slipping while on the road course at my last track event. I'm sure it won't stand up to any drag racing. ![]()
2005 Elise Storm Titanium Last edited by jim-clayton : 05-06-2009 at 10:48 AM. |
#1160 (permalink) | |
![]() EB Turbo
