Oil Leak Sprung BWR Oil Spraying
It looks like its coming out from that (is it a breather tube?) coming out of the front of the cam cover. I notice that it comes out of the cam cover as a metal tube then goes into a rubber tube that has a kink to get around the dip stick.
I was driving the car pretty hard and noticed this afterwards. Haven't noticed it before, then again I've only had the car for 1k miles and 600 of that was driving it home, figured that would be a good enough shake down run. Anyone had this problem? ![]() Anywhere else it could be leaking from? ![]()
06 Exige CO BWRized 05 Civic "Special Edition" 05 Elise CO, Trim shop interior and other things...SOLD Last edited by ACE51 : 05-17-2009 at 04:31 PM. |
the need for speed
Just a couple questions that may help. How many miles total on the motor? Did you do a compression check on the engine before the BWR install? Is the oil dipstick loose, or is the hose attached to the pipe loose? With the motor running, slowly and carefully remove the oil fill cap and tell us if there is any smoke coming out of the hole. If so would you say its a lot or a little.
'05 Elise, Storm Titanium, Gullwing top, custom pinstripes, LETSLA, stage II exh, BWR (sitting on coffee table) |
#3 (permalink) | |
PS: sweet gullwing top! Those are hard to find.
06 Exige CO BWRized 05 Civic "Special Edition" 05 Elise CO, Trim shop interior and other things...SOLD |
Form and Function
I have had a problem before and after BWR install with blow-by.
I was losing tons of oil....eventually the motor blew....so be sure to figure out what's wrong. I agree with the compression and leak down test.
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
the need for speed
PS: sweet gullwing top! Those are hard to find.[/quote]
Thank you, I looked and waited for a long time to get this combination. I hope you find something simple like a loose hose clamp or something. You should do a compression and leak down test either way to determine future engine/cylinder wear.
#7 (permalink) | |
thats scary! I just tightened up the clamps and will be more aware of the problem, wouldn't want that to happen.... then again I've always wanted to get a spare 2zz to bore, map, and blueprint, you know just as a spare ![]()
#8 (permalink) |
NOT ßANNED!
Take her by a shop and get a leakdown test done.
#9 (permalink) |
Hydrocarbons Rule
Clean it up with a little bit of brake cleaner and then look for where it's coming from... I would also concur that it is probably just loose hose clamps or the breather tube flange where it bolts to the cam cover.
Also not that this tube needs to be cut during the install so you may also want to check that the grommet is centered correctly over the cut area and not too close to one of the ends.
#10 (permalink) |
McLareghini Bugatterrari
I can't imagine how oil would get in that spot and only that spot... unless it was just a bit of spillage on the valve cover when somebody poured the oil into the filler opening.
xtn
#11 (permalink) |
I cleaned the car after I bought it and made sure it was clean back there, I checked the oil but never put any in, I definitely didn't spill any. never added oil either.
#12 (permalink) |
Ok, no smoke coming out of the cap when its running.
It looks like its just the breather tube, the way it was cut means you have to put the clamps on at an angle, so when you go to tighten the clamps you can't tighten them because they slip off. I'll get a longer hose tomorrow. I drove it around before hand and there was even oil on my clam somehow??? hope this is the problem. I pulled the panel off and changed the oil, figured it would be good to check since I just bought the car even though it only had 3k and a year on the oil in it. Oil looked fine. Here are two pics of the cut tube: ![]() ![]() Why is the breather tube cut? I guess this is for the supercharger install, looks like he could have left some straight tube to clamp down on if thats the case...
#13 (permalink) |
Crunchy Smurf
sounds like the clamps aren't able to hold 100% of the time, and pressurized oil is squirting out occasionally, like you've got your very own little oil geyser.
Looking back at your first pic, it doesn't look like the clamp is even tightened down, although maybe you were tinkering with that piece when you took the photo. I think you're right to get a longer hose if that allows the clamps to be fully engaged.
2006 Laser Blue Elise -aka, Blue Lightning 2.0, The Little Blue Car, my automobile soul mate ![]() Last edited by toedrag : 05-19-2009 at 05:16 AM. |
#14 (permalink) |
Incorrect cut
I had a BWR self instal (now VF stg1) but I am sure the tube was not cut in the correct position as there should be at least 1" of straight tube above and below to clamp onto. I could send you mine if you need one that does work if you are happy to pay for postage from Australia.
2006 111R Elise,VF stg 1 supercharged,HIDs,Harness bar, LETSLA,Nitrons, Ferodo DS 2500,FF engine damper. Saikou Michi catch cans.Toyota MWR Transmission Lotus 6-spd 3.9:1 LSD Uprated clutch. |
#15 (permalink) | |
Hydrocarbons Rule
A longer hose should however fix your problem... Just make sure it's something that doesn't react with oil. Some forms of rubber will swell or get soft over time if they come in contact with oil, your best bet is to use silicone hose.
#16 (permalink) | |
06 S280
#17 (permalink) |
Hydrocarbons Rule
Thanks for that... Some paint can handle it and some can't... I know the Chemtool I use is some pretty pissed off stuff...
#18 (permalink) | |
06 S280
np, didn't want him trying it and getting upset when his hands turned silver from the paint coming off. This is the main reason I now have a powdercoated valve cover... Live and learn. |
#20 (permalink) |
Hydrocarbons Rule
The valve cover is made of cast aluminum and then painted silver... The injector cover and spark plug covers are however plastic...
