Overview supercharge/turbocharge solutions ELISE
The options for engine upgrades, either supercharged of turbocharged, for our Elises/Exiges are growing fast! Which is a very good thing, but it also makes keeping an overview of all the various upgrades harder. Therefore I made a table in Excel (first picture below the text-body), based on the excellent list made by JasonD in post #52 in Forcefed Turbo vs. Sector 111 blower??? - Page 2 - LotusTalk - The Lotus Cars Community.
I added some other possible engine upgrades to this list, tried to include prices for as far I could find them and included the internet links where I found the various WHP/ft-lbs numbers. The list is not intended to list all possible upgrades, I try to limit the table to the more commonly used upgrades. Based on the useful comments in post #2 from CharlieX (thanks for that, Charlie), I added additional data into the overview for the estimated average ft-lbs during racing on the track (defined as 5500rpm-8000rpm) instead of only using the peak ft-lbs figures. The reason for using the average for the 5500rpm-8000rpm area is that basically the idea is you mostly are in this area on the track. Using the overview, I made the following graphs (we humans are visual oriented animals, also the reason why we bought our cars) for the Elise (for Exige: see post #8) to make the interpretation of the figures easier: Graph 1: WHP / ft-lbs (peak)-graph. Creates insight in how much power the upgrades make in both WHP and ft-lbs (peak). The upper right corner is where you want go for maximum power. Graph 2: WHP / ft-lbs (average race)-graph. Same type of graph as graph 1, only using average race ft-lbs instead of peak-lbs. Graph 3: Costs per extra WHP / ft-lbs (peak)-graph. Creates insight in how much US$ each additional WHP and ft-lbs will cost you. The lower left corner is where you wanna go for lowest price per additional WHP and ft-lbs. Graph 4: Costs per extra WHP / ft-lbs (average race)-graph . Same type of graph as graph 3, only using average race ft-lbs instead of peak-lbs. Please mind: 1. Re Graph 1&3: these are peak figures only, it may/may not say much about the underlying curve. See also post #2 underneath from CharlieX. 2. I made various assumptions, mostly regarding pricing, please see spreadsheet for further details. 3. I'm not a mechanic, I have no idea re streetability and durability. 4. In the graphs 2. and 4. I didn't alter the WHP-figures (yet), because it's my understanding these basically are the result of the torque. Conclusions: - Re two lower cost 1st Gen SC kits (BWR & S111): the BWR Stage I appears to have a slightly better bang for the buck that the S111 Katana. - Both 1st Gen SC kits when compared to the 2nd gen SC kits (VF SC kits with intercooler and the BOE TVS SC) get their asses kicked in terms of power output and also, to a lesser extent, in the $ you’ll need to cough up per extra WHP and ft-lbs. So if you have the extra money for it: it makes sense to buy a 2nd gen SC kits: more power and higher bang per buck. - Although the BOE TVS SC and VF lead the pack in terms of WHP and ft-lbs, also the costs are a bit higher because fuel pumps and upgraded clutches are required. Both BOE and VF Stage II still have, although is pretty minimal, a slight lead over the VF stage I in terms of $ per extra WHP and ft-lbs. Please note that if you install it yourself and therefore avoid the installation costs of the clutch and fuel pump, both the BOE TVS SC and VF stage II take a much bigger lead over the VF stage I. Open the spreadsheet in post #10 if you want to see the graphs based on the cost excl. labor. - The influence of changing the ft-lbs (peak) figures into ft-lbs (average) figures is almost nil. I.e. all kits lose approx. the same % when peak ft-lbs is adjusted into average race ft-lbs. Exceptions are the: FF275 kit: has a lot of torque already in the lower RPMs but loses ft-lbs when ft-lbs peak is adjusted into ft-lbs average race. VF Stage I : which almost doesn't lose any power when ft-lbs peak is adjusted into ft-lbs average race. One last note: see my post #47 for a remark re comparability of the kits: the BOE TVS kit now includes a A/F meter and tuneable EFI ECU, both components not present in any of the other kits. If you value these components then the graphs don't tell the whole story anymore. See post #47 for further explanations. I hope you guys find it handy in weighing your upgrade options! If you have any questions or suggestions to add other upgrades (including ref's), don't hesitate to post! You can find the file of the spreadsheet in post #9 for further abuse. Thanks Enrico
Enrico '06 Laser Blue/Magnolia Lotus Elise * BOE REV400 * DRS built low compression motor * Lots of other things '07 Graphite Grey/Tan BMW 335i w/JB3 tune, Helix IC and BMS DCI Last edited by E.D.; 03-17-2009 at 07:27 AM. Reason: Update for new kits |
| Sponsored Links | |||
Advertisement | |||
OSX Black hat
![]() Join Date: Feb 2005
Nicely done, but just be wary of peak HP numbers, i just did a tune that adds 10ft lbs of tq and around the same in HP across most of the powerband, but the peak hp is almost identical -/+1 HP difference
i usually sample at 500RPM and do a graph from that instead.
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon! |
Yea, I thought of doing something similar (like in the spirit of the weight saved / dollar thread), but realized how misleading a number like peak WHP could be... there's just so much more to an engine upgrade like a supercharger or turbo than a single number can represent. Still, interesting data to look at, I really expected the '08 SC to have the lowest $/WHP number.
#4 (permalink) | |
New and Improved!
I'm sending you my ECU on Monday overnight FEDEX...Looking forward to driving your 06 Katana tune!!! It's going in tomorrow... Thanks for the chart...the links are a nice touch!
2006 Elise - Chili Red - VF Supercharged and Intercooled Stg 3 - Custom tuned by CharlieX - 2.9" Pulley - Walbro 255 - RC 550cc's - Black Badges - Red Inserts - Grey RAC Monolites - Toyo R888's - South Bend SS-TZ - Fidanza Flywheel - FF CF front spoiler - Craftsquare CF Mirrors - Reverie CF Diffuser - 5" 2bular Ultra - PPE 4-1 FI Header w/ Decat - VonHep Rear Panel - Innovate XD-16/LC-1 - Mr.C Radar Mount - Clutch Travel Mod - Shifter Bolt Mod - re-ENFORCER - A/C Panel Mod - Odessey PC625 Last edited by Matt in Houston; 11-16-2007 at 05:59 PM. |
Thank you very much. This is exactly what i have been looking for EXACTLY, I kinda wanna go witht he KAT sc mod 1, thats more then enough power.
71 Elan S4 Sprint red/copper. Webers. Dave Bean Exhaust. Plates: EMAPEEL. |
#7 (permalink) | |
Enrico Note: no longer included in table, turned out to go lean after a while.
Enrico '06 Laser Blue/Magnolia Lotus Elise * BOE REV400 * DRS built low compression motor * Lots of other things '07 Graphite Grey/Tan BMW 335i w/JB3 tune, Helix IC and BMS DCI Last edited by E.D.; 03-17-2009 at 07:25 AM. |
#8 (permalink) |
EXIGE
In this post you'll find basically the same info, but this time for the Exige instead of the Elise.
Enrico '06 Laser Blue/Magnolia Lotus Elise * BOE REV400 * DRS built low compression motor * Lots of other things '07 Graphite Grey/Tan BMW 335i w/JB3 tune, Helix IC and BMS DCI Last edited by E.D.; 12-01-2007 at 02:15 PM. |
#9 (permalink) |
The spreadsheet.
#11 (permalink) |
OSX Black hat
If use Alt+PrtSc with the application it should capture only the window you're got activated.
#12 (permalink) |
Thanks for the tip! I didn't know that.
Enrico '06 Laser Blue/Magnolia Lotus Elise * BOE REV400 * DRS built low compression motor * Lots of other things '07 Graphite Grey/Tan BMW 335i w/JB3 tune, Helix IC and BMS DCI |
#13 (permalink) |
No source, as stated in the column 'remarks and references' it is just an estimation: 240HP/220HP * the average dyno'd WHP for the Exige S. When you open up the spreadsheet in post #9 you can see the formula.
#15 (permalink) |
Whoooooo.
I made a post which has r'ved the holy status of a sticky. !!!To celebrate, I'm gonna get sooooo drunk tonight!
#16 (permalink) |
congrats! ill be out drinking tonight as well, ill cheers to you when i do.
[Ovarian Odorist] 11:12 pm: why did you ever get into your business rob...you have such great potential in the adult porn industry.. |
#17 (permalink) |
Updated Elise overview spreadsheet/graphs with Bemani figures.
Now waiting for first stage II BWR / S111 dyno's....
#18 (permalink) |
You forgot FF275 w/gt28rs upgrade...270whp 195tq...I'll get a dyno sheet up sometime.
ENGTUNING.COM ENGTUNING.COM/BLOG Professional dyno tuning and fabrication in northern California....Specializing in Honda/Acura and Lotus |
#19 (permalink) |
I would gladly add that one...
#20 (permalink) |
Big head man
Also, I would add that at no extra cost (other than dyno time), a FF 275 kit with a standalone ECU can be configured to have a second map with race gas producing much better numbers. On 100 octane gas, my car produces 252 whp and 221 ft/lbs of torque. I only plan to use this map on autocross days (100 octane is $8/ gallon) but I wanted to point out that option.
My car both sucks and blows. Now with added all natural smoky goodness!
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
