#41 (permalink) |
Virginia Beach Car Guy
I would just like to know why people think this whole idea is so new. Forcefed has already done this and sells kits. Are people taking crazy pills?
Triumph Tr4a Race Car 1967 SOLD 1954 CJ 3b Willys 2002 Yukon Denali Daily Driver 2006 Exige. The only man in america to have a exige s then go back to a NA exige ![]() 1967 911S 1900lbs 220hp |
#43 (permalink) | |
Lateral-G Addict
08 SpaceGrey V8 "Arcadian, I've fought countless times, yet I've never met an adversary who could offer me what we Spartans call "A Beautiful Death." I can only hope, with all the world's warriors gathered against us, there might be one down there who's up to the task." Μολὼν λαβέ!! |
#44 (permalink) | ||
Future 2ZZ-GZE member...
2) Ronin's using a turbo similar in size to a Garrett GT30 series turbo for 400+ whp. Forcedfed maxed out their GT28 series turbo setup at 350 whp, and that's with water injection as well. 3) Wouldn't you like to see what supercar performance this guy can put down on a turbocharged 400+ whp Lotus now that he's bored with 300 supercharged whp? It's not like I said putting that much power in a Lotus would be an interesting idea back when if first signed on the site or anything... OH LOOK!!! I'M POSTING IN A THREAD THAT WILL HAVE A 400+ WHP LOTUS WHEN COMPLETED! ![]()
#45 (permalink) |
without a Lotus
yea i believe the GT28 turbo runs an internal wastegate, and its easy to max out, def not good for ~400whp
-Coi- currently having Lotus withdrawals ![]() Facebook | Twitter | Pics | Vids |
#46 (permalink) |
Lateral-G Addict
The point is that nothing there is revolutionary...it's been done on a thousand cars before, no big deal...no re-inventing the wheel.
What will be interesting to see is the cooling of the charge temps, which with an air/water intercooler, not the best design for cooling intake temps, with over 20lbs of boost. Air increases in temp about 10degrees for every psi in boost...so on a 90 degree day a 20psi turbo motor is blowing at least 300degrees IATs before the intercooler. Getting the IATs close to ambient, especially after several runs when much heat is produced, may be difficult for an air/water system....heatsoak is always knocking on the door. There are very few, if any, modern raceteams that use air/water intercoolers for their cars due to the inability for enough heat to be released...they all opt for large air/air intercoolers...but Frank's been known to add an additional heatexchanger or half-dozen to shed that heat, so all should be well. Worse comes to worse, a few feet of base-board heating radiator could be run under the car with a cooler filled with ice-cubes in the trunk....that should do it. Or water-injection can be used and the IATs can go below ambient, as they've done on thousands of cars, shattering the performance of an a/w intercooler. And think of how much money one can save installing one W/I kit vs a half-dozen heatexchangers and two water pumps, let alone the weight savings. Here's a pretty graph of the IAT drop with different levels of W/I.... ![]() No intercooler, unless it's filled with ice...which is not feasable on the roadcourse, can drop IATs under ambient...NONE. If the mixture goes to 50%methanol/50%water, IATs will drop even further....and then performance will mimic race-gas tunes....which will be pretty impressive on any GT turbo!!! More to come...
#47 (permalink) | |
1. We are currently using a 2871 and we make up to 395whp depending on boost levels. 2. We tested larger larger turbos(3076..3037..3076/2871 hybrid) back in 2005 and found that thay didn't deliver the appropriate powerband for what most people use these vehicles for. 3. We don't run water injection...tested it once and didn't find it needed. I can personally say 400whp in this chassis is downright insane and would not want anymore than that on a track. We have many pro drivers test our car and most of them prefer to run it at lower power levels(@340whp) as that seems to be the sweet spot as far as balance and power are concerned. |
#49 (permalink) |
Elise Fanatic
Water injection is nice when it is working properly. My experience with Aquamist on an E36 M3 is that it works, but is also yet another point of failure that was aggravating so I eventually just removed it. Not mention the insane noise the pump makes!
Pete 05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo |
#50 (permalink) |
Lateral-G Addict
Where did you have it mounted? Was it the Shurflo or the ERL pump?
On my Z06, it was in the front left quarterpanel, on the STI, it's in the right-rear quarterpanel...never heard it, not because it's not loud but because the exhaust pretty much drowns out everything on both cars. Be good, TomK
#51 (permalink) | |
Elise Fanatic
#52 (permalink) | |
I swore I read somewhere you hit 350 whp with water injection...my mistake.
#53 (permalink) |
OSX Black hat
It'll be our first proper stock ecu turbo without a piggyback or standalone, so its new in that sense, hopefully that in turn will help the people that've contacted me loooking for a turbo tune thats more off the shelf and doesn't require scratch tuning.
probably heading out wed nite/thursday to start tuning at LAPD, woke up with a migraine this am so i hope it clears before we hit the dyno, not a fun place to be with that. i agree with casey though 400HP is nuts.
#54 (permalink) | |
Is it true you added a MAP sensor to his car?
#55 (permalink) |
I am not saying that its not cool or that its not good to have a couple turbo options. I am just saying that this has been done before by Forcedfed.
Go for it I hope the goal of 400 HP is reached. It would be a monster. ![]()
#56 (permalink) |
OSX Black hat
sort of
its running a wide band for the pre 02 sensor too, has 100 octane map switchable by the throttle maps (when its off), remote tuning etc.
#57 (permalink) | |
Thank you. |
#58 (permalink) | |
Nothing witty to say
#60 (permalink) | |
without a Lotus
