Old 07-14-2008, 01:17 PM   #81 (permalink)
OSX Black hat
charliex's Avatar
Unfortunately doing a proper MAF to MAP conversion requires a lot more work than just applying a rescaling/remap function. (not convinced the maf is pegged yet)
Old 07-15-2008, 08:10 AM   #82 (permalink)
Bender Rodríguez's Avatar
This really leads to my question concerning the setup on Franks car. If I understand correctly you've added additional fuel/ timing tables based on a coarse set range of MAP values? I'm guessing like 2 or 3 MAP settings total switches to some different unused portion of the factory memory where you've added the tables, and effectively adding another dimension to the factory logic. Is that correct? Other than that the only other thing I could think of is some kind of a post logic correction value.
Bender Rodríguez is offline   Reply With Quote
Old 07-15-2008, 09:46 AM   #83 (permalink)
OSX Black hat
charliex's Avatar
Nope we're still running off the MAF sensor at the moment, if we switch to MAP all of the maps in the ecu would be recalibrated for a MAP sensor instead, the extra TMAP sensor is curently being used for intercooler temperature.
Old 07-15-2008, 09:42 PM   #84 (permalink)
(Anti)Social Psychologist
jlitman's Avatar
You're probably getting pretty close to 5 volts...
Can you rescale the MAF voltage? That's probably a whole lot easier than converting to speed density, which I'm guessing would mean starting from scratch...
Here's pics of the final product
jlitman is offline   Reply With Quote
Old 07-15-2008, 09:56 PM   #85 (permalink)
Future 2ZZ-GZE member...
GTsRasta's Avatar
He needs those red wheels now...
Originally Posted by scottyb View Post
Maybe you should put a disclaimer in your sig saying that you don't have a Lotus nor have tried any of the products you are constantly posting about.
03 Celica GT-S, 6 Speed Manual, Carbon Blue
Performance Mods: AEM Cold Air Intake, TWM Short Shifter
GTsRasta is offline   Reply With Quote
Old 07-16-2008, 04:20 AM   #86 (permalink)
You would have to modify the MAF sensor itself. The voltage it produces corresponds with a set value of air flow rescaling the ecu to think that same voltage is now a different amount of air wouldn't do the trick alone.
Old 07-16-2008, 05:00 AM   #87 (permalink)
Hydrocarbons Rule
Dragon's Avatar
Images: 2
The only real options if your maxing out the stock MAF are:
1. Use a MAP sensor.
2. Put the stock MAF in to the compressed air after the turbo and before the throttle body.
3. Put the stock MAF in to a larger intake pipe so it will see a smaller total %age of airflow.
4. Use a different MAF sensor from something else.
Pretty much any of them will require changing a lot of information and retuning. The easiest one would be #3 as you can calculate the % of extra airflow and know how much to offset by. In the long run option #1 would be more work, but the best option for performance. One thing that would help is to actually hook up a GM 3 bar all by itself, give it 5v input and ground and log the out put voltages along with all the other data log information from a few runs. Then you could compare the MAF voltages to the MAP voltages side by side and that would help a ton in setting up a good base tune for the MAP.
Dragon is offline   Reply With Quote
Old 07-16-2008, 09:21 AM   #88 (permalink)
OSX Black hat
charliex's Avatar
We already have the TMAP sensor installed for any logging that'd be needed, the TMAF is also in a larger tube, and we have the scooby TMAF on hand just in case.
but first figuring out whats actually happening before we go off changing stuff, i'm hoping to get back to the car next week.
Old 07-16-2008, 09:38 PM   #89 (permalink)
w00t
Tang0_au's Avatar
supra maf is a lot better scale on it for boosted apps ... slight re-calibration required, but wont reach 5.0v as quick ...
1zz Elise Blown by Rotrex:
Build Thread: http://www.aussieelises.com/forums/i...showtopic=9609
Tang0_au is offline   Reply With Quote
Old 07-16-2008, 10:17 PM   #90 (permalink)
Originally Posted by Casey@ForcedFed View Post
We've tried the 3076..3037...custom 3076/2871 setups and all of them delivered less than desirable power bands(at least for track use) and we eventually settled on the 2871 with a .64 in a t25 housing.
Have you tried the GT3071r's .64 before? I have found that the GT3071r spools up 500-750 RPM's sooner then the .64 2871r & the 3071r also has a stronger top end. This is on a 2.3L motor & 30-35 PSI of boost on both turbo's with the same HW. The 3076r was 1000 or so RPM's later then the 2871r, usually not developing 30-35PSI untill 5000-5500 RPM's.
Exige S summer 2010.... hopefully
Viggen is offline   Reply With Quote
Old 07-17-2008, 03:23 AM   #91 (permalink)
jlitman's Avatar
You've got all your bases covered then
Old 07-29-2008, 11:38 AM   #92 (permalink)
Abe
Abe's Avatar
Trannies Always want attention...
And now Ronin has to pay attention to his
Abe is offline   Reply With Quote
Old 07-29-2008, 11:45 AM   #93 (permalink)
choi0706's Avatar
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 07-29-2008, 12:10 PM   #94 (permalink)
(Formerly PESTODUDE)
Illumiloti's Avatar
Talked to Ronin at a stoplight in the valley on Sunday. Said he was making 380 hp and that he and Charlie were going back to the dyno on Monday for e re-tune. Then the light turned green while we were still talking. Woman behind him honked her horn. He hit the go peddle and was gone like he was shot out of a cannon. Unreal! This video was obviously after the Moday tune. Wonder what the got the hp up to. Ronin told me they were shooting for 450.
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune.
Illumiloti is offline   Reply With Quote
Old 07-29-2008, 12:17 PM   #95 (permalink)
Jack's Avatar
According to Frank, there's more tuning to do...right now (as of his tuning session on Monday at Tri-Point, before the tranny issue) he says the car is at the ~380 RWH/280TQ level.
Jack
'07 Exige Cup 255
'08 2-Eleven
Old 07-29-2008, 12:17 PM   #96 (permalink)
Race lines on the mind
Tracktimeplz's Avatar
Notice the smooth acceleration and how quick it is even in low RPM. Impressive
2003 Honda S2000 - Suzuka Blue
2005 Magnetic Blue Elise
Forcefed 275 turbo - Sold 05/20/09
Tracktimeplz is offline   Reply With Quote
Old 07-29-2008, 03:43 PM   #97 (permalink)
OSX Black hat
charliex's Avatar
It's quick.
Old 07-29-2008, 03:47 PM   #98 (permalink)
Illumiloti's Avatar
It's quick.
You think there's more there (tuning wise)?
Randy
Old 07-29-2008, 03:52 PM   #99 (permalink)
OSX Black hat
charliex's Avatar
Yes, at the end of the day we'd only just really gotten done with the fuelling and base stuff, then had started playing with the spark and VVtli settings,( boosted and some of the celica guys are passing on their experiences there too, which is very handy ), and then we stopped for the day.
the car ran well though, we didn't hit any technical snags except for setting up the apexi boost controller, which has 30+ pages for a boost controller..
Old 07-29-2008, 03:55 PM   #100 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Very Cool Charlie- I imagine tuning on that beast was a nice change in pace form the drab 'ol super charged cars
Best,
Phil
