Temporarily removing BWR supercharger?
I am relocating overseas and may need to temporarily remove my BWR supercharger for inspection purposes. It will need to be reinstalled later on. I'd like to know how to do this myself so that the mechanics overseas won't mess up my car.
Has anyone done this before, and if so, can you share your experiences, etc? Thanks.
2006 Lotus Elise (BWR SC w/ CharlieX tune, Toyo R888, Moroso Oil Pan, Green Filter) 2003 Porsche Cayenne S 2002 Porsche Boxster S (ROW030, RA1, B&M) (sold) |
GR8 SCAPE
Having just finished the install of my SC, I'm thinking that a "temporary" removal is not an easy undertaking.
It's not like you can just unbolt the SC itself. All the SC components, injectors, ECU, belts, wiring, etc. that were changed in the SC install need to be put back to OEM state. You'd have to put the alternator back where it was or rig up some idler pulley system. I pretty sure a stock motor won't run with an ECU SC tune, or it will run very badly. I hope I'm wrong, but it doesn't seem like a simple task. Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
Haxord but mine
Why do you need to remove it to pass inspection? It looks pretty standard with the stock airbox, and ECU shouldn't throw any give away.
-David 2006 Storm Ti Exige + VF Stage 2 Vision Function Supercharger Install Thread Stereo Harness Info | Exige with no wing?? |
Thanks for the information. In this case I'll keep it on then.
Well I am relocating to a country where they are particularly anal about small car modifications and fuel consumption. I am just trying to figure out what is the easiest route to pass the fairly elaborate certification process there.
#5 (permalink) | |
This is my 5th Lotus ...
You have to find a stock ECU for inspection`s hours
2006 Fed Aspen White Elise LSS -SOLD- 2006 Fed Phantom Black Exige BWR/CharlieX tune 2006 Fed Storm Titanium Exige -SOLD- BMW E66 745i GREEKS do it better ![]() www.lotusclub.gr/forum |
