OhioLotus.com
Tri-Point Supercharger DIY Installation Notes
This sub-topic is dedicated to my 'do-it-yourself' installation of the Tri-Point Supercharger (kit form).
I have no connection with Tri-Point whatsoever. I did not receive any discount, compensation, or any other incentive to write this install review. It's written totally on my own and done for the benefit of ET members...nothing more. I'm going to call everything as I see it with the kit, good or bad. I paid $4500 + shipping for the kit. I'm not a master mechanic. I'm a weekend home garage tool-turning guy with average mechanical abilities. I have an extensive electronics background however, that might come in a handy with the Xede. What I'm trying to say is, if you're an average mechanic or better, then you should be able to do this install too. What's in the kit... Last edited by Dave : 04-12-2008 at 08:08 AM. |
OhioLotus.com
So here are a few close up pictures. Weight of the Greddy blower is 20lbs, and the entire kit weighs in at 27lbs. Of course, that's not the actual weight gain, as some items will be swapped out. The installation guide is 11 pages, has loads of illustrations, and seems geared toward the layperson...I'm impressed so far.
OhioLotus.com
And the Xede. I'll be swapping out my updated 5750 crossover ECU for a non-learning 5750 to avoid conflict with the piggy. Note: The chip does learn, it just doesn't remember anything after you switch off the key so nothing's permanent. Also note, the non-learning chip is not included in the kit price above. This Xede has similar parameters to Frank's car, as we share most of the same mods, ie headers, FF intake, catless, etc.
OhioLotus.com
Quick update on the progress...what I've had time to do so far:
Removed boot lid, wheel/liner, diffuser, rearmost under tray, engine covers. Nitrous system pulled - I'll miss that. ![]() Throttle body (Thor) removed and sent to shop for porting with the SC manifold, back today. Spark plugs gapped and replaced with cooler ones (included in kit). Dismounted fuse boxes and ECU...swapped chip with non-learning. Next: Remove stock intake manifold and move alternator with brackets supplied. |
#8 (permalink) |
Meow!!
Great writeup so far Dave!
Hey, would Tri-Point mind if the installation instructions were scanned/posted up here...or is there anyone from Tri-Point online here that could post a PDF? (looks like a simple Word doc)... Did you have a before dyno done/available? Without NO2 of course... ![]() Oh... more pictures! Need more info! Nah... I'm not pumped... BTW, I'm literally checking this post several times a day for updates... ![]() Thanks! ![]()
#9 (permalink) |
why not SC and NOS?
speaking of NOS... they have an energy drink now... lol
KG Exige Delivered 5-9-2006 POLL:check for scratches "in" your headlights Excessive tire wear? It may be your alignment My Example Hiro's Example codymac's Example to be installed: stebel horn, fumoto valve current mods: arqray twin muffler, itg intake, 3M film full wrap and full rockers by X-Perts, rear lotus letters removed, locking gas cap, CF Mirror Covers, CF Side Scoops, black lotus nose/wheel badges future mods:wheels, forced induction |
#10 (permalink) |
Fed Elise #242, Now Turbo
When I inquired with Tripoint, they said that engine management is done with the Xede and a non-learning ECU chip. So, I assume Tripoint offers a non-learning chip with the kit, and you just didn't need it since you have your own version of non-learning chip, right? If so, is there any difference between their non-learning chip and yours? Did you share the code with them, or did they create it on their own?
Also, I still don't understand why a non-learning chip is required if the piggyback is properly tuned. |
#11 (permalink) | |
Meow!!
![]() It would definitely save time and money!
#12 (permalink) | |
it doesn't matter which piggy-back ecu is put on.. the lotus ecu will fight it by "learning" with this non learning ecu chip it shouldn't fight the tuning.. so I'm assuming the greddy emanage ultimate will work as well if the non learning chip is put into the lotus ecu.. for me, I'm waiting for littlerocket's apexi powerfc.. just retuning the celica gts engine with a intake shows gains of 20ft/lbs at 3500rpms..![]() |
#13 (permalink) | |||
OhioLotus.com
#14 (permalink) | ||
OhioLotus.com
#15 (permalink) | |
I guess that machined billet piece is the alternator bracket? What is the diameter of the SC pulley? Are you putting a boost gauge and where are you going to tap in manifold? Thanks.
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate |
#16 (permalink) | |
The manifold has a nipple that can be tee'd off for a boost gauge signal.. |
#17 (permalink) | |
#18 (permalink) |
maybe for the oem airbox? there is a nipple on the side of the oem manifold for the airbox.. either way, it can be tee'd off for a boost signal..
edit.. it seems it was there for the bypass valve.. but could be tee'd off for signal Last edited by choi0706 : 08-11-2006 at 11:04 AM. |
#19 (permalink) |
heh, I was one of the masses that suggest Dave open this thread for comments, lest his full time job turn into PM answerer.
So, subscribing now, and may I say ![]()
David Avery 09 Porsche 911 TT Cab | 05 Lotus Elise SOLD | 08 BMW 135i Stockvisit Spyderclub.com |
#20 (permalink) | |
Meow!!
That calculates to 7 lbs. left over + 9 lb. supercharger difference = a 16 lb. weight increase - or LESS... (not counting removing the stock spark plugs, injectors and the like that get replaced with the 27lb. kit)... Just wondering... I'd LOVE it if came in under 15lbs. Can you imagine a 50whp increase for 15lbs? Hey Dave, weigh everything that comes off the car as well... if I wasn't here in Kansas City I'd be over at your house, helping you wrench! ![]()
