Old 07-06-2009, 04:26 PM   #21 (permalink)
Haxord but mine
Westrock's Avatar
Looks like the pulley was rubbing pretty bad on the nose bracket. The wear is evident on the pulley itself and on the nose bracket in your pictures.
Ya I chronicled that in the install thread. The supercharger didnt come over far enough so the pulley intially rubbed like mad on the bracket.
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
Old 07-06-2009, 04:43 PM   #22 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Doh. Sorry for being captain obvious I would imagine that rubbing had a lot to do with that keyway issue. Did you end up resolving the issue with the rubbing?
The other options are that the there was no key in there to begin with or the pulley was very loose? Although you mentioned that the nut was tight, right? One thing that is near certainty is that the key didn't just fall apart due to "normal" wear and tear. I'm not implying that you did anything wrong, FWIW. I'm just protecting the key itself. It wasn't his fault
Best,
Phil
Old 07-07-2009, 12:31 PM   #23 (permalink)
Haxord but mine
Westrock's Avatar
Another picture of the pulley with all the dust removed.
-David
