Old 04-29-2009, 09:41 PM   #1 (permalink)
Drunk on alcohol
25psi_Elise_Killer's Avatar
Video how to modify a turbocharger's internals
Good video on modifying a turbocharger's internals. Good if you need some extra umph while retaining a stock turbo's spool up characteristics with minimal lag. Very popular to do in the Subaru/Evo world...
Video takes a while to load, so be partient.
Blouch Turbo Inc.
'06 Evo IX Stage 1E Tuned by Road Race Engineering(Stock:turbo,intake,internals,ECU) Walbro 255lph fuel pump,RC Engineering1000cc Injectors, AVO exhaust,RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband,Zeitronix Ethanol Content Analyzer, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com
25psi_Elise_Killer is offline   Reply With Quote
Old 04-29-2009, 09:54 PM   #2 (permalink)
Drunk on alcohol
Another video, Turbo Rebuilding 101
Blouch Turbo Inc.
Old 05-01-2009, 01:27 AM   #3 (permalink)
Haxord but mine
Westrock's Avatar
Thats definently the proper way to upgrade the turbo, modifying both the compressor and turbine. But its still the same issue, that your pushing more power through the same hole.
For the all time spent modifying the stock turbo, how much more costly would it be to just simply upgrade to a turbo that has a more capabable compressor and a proportionant turbine housing to match.
I know there are circumstances where replacing the the turbo is not as feasable then upgrading the stock, like say in instances where the turbine housing is casted directly into the manifold (like the SRT-4) so that replacing the turbo mandates replacing the manifold as well. Or maybe like some of the mitsubishi's that were reverse rotation and thus it could be hard to replace with an off the shelf. But that turbo shown looked to be a standard 5 bolt turbo, they are not hard to come by.
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
Old 05-01-2009, 10:27 AM   #4 (permalink)
Drunk on alcohol
Ya a lot of Mitsubishi guys upgrade the existing turbos due to the reverse rotation (Evo 7-9, maybe older ones too) since they don't want to spend $$ on a new manifold and other hardware or a complete kit which can cost around $4K or higher. Whereas a brand new "modified OEM turbo" costs around $1700 and just bolts right on
However, Evo X's have normal rotating turbos and can bolt on an off the shelf Garett unit.
Wonder if Lotus guys are willing to try out a Evo X twin scroll turbo in their cars since used units are selling fairly cheap. I think even new Evo X turbos go for around $1k
