Old 06-13-2009, 03:07 AM   #161 (permalink)
RichardNHCooper's Avatar
Charlie the gremlin killer
Well my weird misfire while turning right turned out to be a wheel sensor, traction control. ECU combined fault. After a reset of the ECU as Charlie instructed me to do, all is fixed. Charlie really knows these cars. A great big thanks.
2006 111R Elise,VF stg 1 supercharged,HIDs,Harness bar, LETSLA,Nitrons, Ferodo DS 2500,FF engine damper. Saikou Michi catch cans.Toyota MWR Transmission Lotus 6-spd 3.9:1 LSD Uprated clutch.
RichardNHCooper is offline   Reply With Quote
Old 06-20-2009, 11:30 PM   #162 (permalink)
sleepe's Avatar
Has anyone gotten the revised vf2 tune yet; the reflash that should remedy the rich condition code and catalyst below efficiency code?
-Robert
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is offline   Reply With Quote
Old 06-21-2009, 06:37 AM   #163 (permalink)
Crazy Car Guy
-Robert
Revised tune not availabe yet. I will post when it is ready.
Jermaine~
www.VisionFunction.com - Site Under Construnction - Stay Tuned
Jermaine@VF is offline   Reply With Quote
Old 06-21-2009, 07:23 AM   #164 (permalink)
xziteme's Avatar
Jermaine~
I was finally able to take it to the track last weekend. The stage I was flawless...plenty of torque to power out with and it reduced the need to downshift on most turns. Also, no P0172 codes and no cel light...not even once!
I guess the VF tune (unrevised) likes it better when you're really working the engine. I seems less happy if you're driving around and staying under 4K rpm most of the time. It will tell you (ie: cel light) to step on it and hit that second cam more often.
xziteme is offline   Reply With Quote
Old 06-21-2009, 07:10 PM   #165 (permalink)
sleepe's Avatar
That is true, the vf2 tune is better suited to track driving, where the rpms are kept well above 4500. But, the tune is very docile slogging around town. The problem comes when you are cruising at ~3000+ rpms and want to accelerate immediately...the motor hesitates and bogs down until the rpms rise to ~4200-4500...it almost feels like a turbo spooling up, but not very linear/smooth
I'll be going to the NJMP track later this summer.
What HPDE group are you in? Could you keep up with higher hp cars on the straights?
-Robert
Old 06-26-2009, 09:58 AM   #166 (permalink)
xziteme's Avatar
Interesting, I never encountered that problem.
On a side note...I had occassional stalling when coming to a stop. After I re-tightened all the clamps to the piping, my stalling issues have improved.
I'm gonna try a work-around for the P0172 code while waiting for the revised tune from Jermaine. I noticed if you drive before the engine has properly warmed (160 deg oil temp), you get a P0172 more frequently. When I was at the track, I made sure my oil temp was properly warmed past 160 deg before going out and I never got a CEL light.
I'll experiment with this theory.
Old 06-27-2009, 12:11 AM   #167 (permalink)
sleepe's Avatar
that's not oil temp...it measures water temp
Old 06-27-2009, 10:09 AM   #168 (permalink)
xziteme's Avatar
I also have an oil temp gauge along with boost and a/f.
Anyways, I took it out for a drive along the freeway after letting the engine idle to properly warm it up to 160 deg OIL TEMP. 30 min later, I get the CEL light w/ the P0172 code. It always happens when cruising along the freeway. I'll just have to wait for Jermaine's revised tune.
Old 06-28-2009, 02:55 AM   #169 (permalink)
just curious,
how do you guys read the code? is there some kind of plug in gismo? by cel light i guess you mean the red light top middle of gauge?
when this comes on you plug in a reader into the ecu to check the code???
Drmike is offline   Reply With Quote
Old 06-28-2009, 07:27 AM   #170 (permalink)
stinkyonion's Avatar
Images: 2
Read the code with a OBD reader that plugs into OBD port under drivers side dash. Autozone will do for free or spend $80-800 for your own.
The CEL is the "check engine light". It is the red engine picture that lights up on your dash when you put key in ignition (and hopefully goes out after a couple of seconds).
2006 polar blue Elise, VF stage II, clam hinge, von Hep exhaust, HID, Zeitronix/Dashdaq (GPS, wideband O2, EGT, fuel+oil pressure), BWR fuel rail, moroso oil pan, HD SS clutch, RTV brace, green wire mod, harnesses, Oddysey 625, alpine pdx-5, jvc avx77 head unit, jl speakers, voltmeter on dash, custom gauge pod, etc.
stinkyonion is offline   Reply With Quote
Old 06-28-2009, 07:34 AM   #171 (permalink)
Images: 2
I had like a half second of latency after pressing gas pedal before accelearting. I had this for weeks after doing the install, thought it was normal. FVMC found minor vacuum leak when diagnosing separate clogged fuel line issue, now no latency whatsoever. Press the pedal and gogogo.
I saw someone earlier complain of latency, bet they have a vacuum leak.
Will add a post soon on the fuel filter install (not in this thread). It is like $5 from autozone and takes 5 minutes. Would have saved me $1500 and 3 weeks driving time, but is another story not belonging in this thread as is unrelated to VF2.
Old 06-28-2009, 04:53 PM   #172 (permalink)
thanks for the info.
So the little red light at top of tachometer thats just started flashing at me is?
Im just assuming low battery charge is the reason??
(sorry for the hijack)
Old 06-29-2009, 02:22 PM   #173 (permalink)
Haxord but mine
Westrock's Avatar
This shows the check engine light on
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
Old 07-15-2009, 10:17 PM   #174 (permalink)
sleepe's Avatar
vf2 air filter element: WhAT IS IT MADE OF?
Is the filter washable/reusable?
What is the outer diameter for the intake pipe?
-Robert
Old 07-15-2009, 10:21 PM   #175 (permalink)
sleepe's Avatar
Did you get dirty fuel?
-Robert
Old 07-16-2009, 09:52 AM   #176 (permalink)
xziteme's Avatar
To increase airflow to the intercooler and engine bay, I replaced my side grills with the extra-wide TWRD CF side scoops.
I also copied biodan's and Perry's idea (HOW MANY BLOWN ALTERNATORS???) and routed a 3" diam air duct from the side scoop to the alternator.
Old 07-16-2009, 10:33 AM   #177 (permalink)
06 S280
LordZ's Avatar
What numbers did you see on the temp drop across the IC from doing this?
LordZ is offline   Reply With Quote
Old 07-16-2009, 10:38 AM   #178 (permalink)
User, Registered
fpitas's Avatar
The big scoops are tempting. I have to wonder at what point increasing the scoop size loses more hp from drag than it gains from lower IC temp. I suppose in any event the lower intake temperature is a good idea for reliability.
Francis
Old 07-16-2009, 09:10 PM   #179 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
I'm also interested to know what your IAT is. Just want to know IAT for any VF kit.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 07-17-2009, 06:30 AM   #180 (permalink)
Haxord but mine
Westrock's Avatar
-Robert
Refer to the kit contents picture in the first post to see the included filter. It is a wire/cotton mesh. I do not use oil on it. Outside diameter of the intake pipe is 75.75mm
-David
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
