What spark plug for BWR supercharger?
I am installing a BWR Supercharger. I want to change the spark plug at the same time. So what spark plug should I use?
05 Lotus Elise 06 Infiniti FX35 |
Haxord but mine
When I installed the VF kit I went with one range cooler iridium plugs. Part number was NGK Iridium IX BKR7EIX-11. While it seemed safer, the engine was sluggish at idle. So using a trick I learned from previous forced induction cars I went back with the stock plugs, but I gapped them down 0.035" (from stock gap of like 0.050"). The engine idle'ed good again and I didnt worry about spark blowout, which becomes a bigger problem as boost and RPM increase.
-David 2006 Storm Ti Exige + VF Stage 2 Vision Function Supercharger Install Thread Stereo Harness Info | Exige with no wing?? |
Hydrocarbons Rule
NGK BKR7EIX-11's in my car with a BWR supercharger / PES tune. I've put 25,000km's on it so far running it like a rapped ape with no issues...
2006 Exige; BWR Supercharger, Adj Sway Bar, Ohlins Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Clutch, Custom Exhaust, Black Volk Racing CE28N's w/ Toyo R1R's, 2 piece rotors, Pagid Blue Pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Panels), Dry Carbon rear Diffuser, Harness Bar, BWR Gauge Mount, OMP Superquadro steering wheel, LETSLA Short Shifter, V2arms, Rear Tow Link Brace, RLS Battery Bracket, BOE Tow Bar, Stickers. Last edited by Dragon : 07-20-2009 at 08:29 AM. |
GR8 SCAPE
+1 for the NGK Iridium IX BKR7EIX-11.
I have the BWR SC with PES tune and these plugs have been great. No stumbling, smooth idle. Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
+1 on the NGK Iridiums, cost more than regular plugs but absolutely worth it. Just out of curiosity is it even possible to regap iridiums without causing damage.
I just plugged them in and the car ran/started fine albeit a slightly higher idle.
Ohlins double adjustable c/o | BWR front sway bar | Milled front steering arms | RTV brace | Hawk pads | R888's | 2qt Accusump | ACT clutch | Baffled oil pan | JS Stage 2 exhaust | Schroth Harnesses | Sector Harness bar | Odyssey PC680 w/custom cutoff switch | Sector trunk bag | Sector Fire extinguisher | SS brakelines | B/W front emblem and wheel center caps | Xenons | Tints | Tinted side LEDS | BWR Supercharger
#6 (permalink) | |
Haxord but mine
I usually push the spark plug against the concrete floor of my garage, since its hard but wont mar the surface cause its smooth.
#7 (permalink) |
Plug Whisperer
You should generally only change the plugs to a different heat range if the current heat range is posing a problem, i.e. appears to be too hot or too cold
. Standard gap for all the current blower systems available is sufficient. With Gap, bigger is better up until the point the spark cannot make the jump. Standard gap (the gap the plugs come with) isn't a problem-- even at 285whp and 8500rpms...Iridiums are nice for longevity but make no appreciable excess power than their cheap copper core cousins. If you're simply trying to determine the correct heat range for the car, buy the cheap copper versions (of the same brand) for testing/tuning purposes. Once the correct heat range is determined, go buy your expensive iridium plugs that will last 50-100K miles... FWIW- I still have copper plugs in my car and she runs okee-dokee ![]() Best, Phil
