WOW! REV 400 with 2Bular and 75mm Pulley
I just installed the smaller 75mm (12 psi) pulley (used to have 82mm @10psi) and 2Bular SC header and de-cat with BOE Silent touch exhaust on my REV 400 Elise.
I am absolutely blown away with the performance increase! its honestly like night and day difference. It pulls SO much harder and cleaner, torque and HP has increased dramatically, so happy with the upgrade. Yesterday out ran a modified 700HP 911 Turbo 3rd gear roll on! he said he gave it all it had. The exhause setup i had before was Larini de-cat, stock headers and stage 2 muffler it was crazy loud but restrictive, upgraded to the 2Bular SC headers, 2Bular de-cat and BOE Silent touch muffler is much quieter inside the car, still a great sound though and much better flow. The 2 extra psi obviously helped with the smaller pulley, im my opinion this is how it should be. Im sure its not as good on internals compared to the 10psi if you track it every week etc and clutch if your drag racing but I DONT CARE!, im careful with how a treat the trans and clutch and if it eventually goes pop that its just something i will have to make better. This power is like a drug!! im just laughing out loud now when i drive this BEAST!! Thanks to Phil @ BOE, Thanks to Jim @ 2Bular!!
06 Elise, BOE REV400 TVS Supercharger 75mm pulley. 2Bular SC Headers, 2Bular De-Cat, BOE Silent Touch Muffler, ACT HD/SS Clutch, Lightweight Flywheel, PLX Wideband O2 Sensor, S111 tie-rod brace, S111 G-Pan, S111 Heel Toe Pedals, CF Side Scoops, Difflow 5 Element JR Diffuser, Front lip spoiler, Rota Torque, Toyo R888. Throttle body heater delete, LSS Suspension, BWR adjustable sway bar. Manley Motor Mounts. CL RC5+Brake Pads. BOE Catch Can. |
| Sponsored Links | |||
Advertisement | |||
No video of this win unfortunately, all I did was wind out 3rd, happened way to quick.
Yes stock internals, i think making aprox 375-385hp. Will dyno it at some time.
Thanks Pepper
is there any guide line for what boost a stock motor can run, and not kill long term reliability?
12PSI seems like its getting up there. But it also sounds fun.
Enjoying Lotus performance because of its nature, not because of its quantity it isn't that i'm not a people person, I'm just not a stupid people person! |
#7 (permalink) |
In my opinion it is at the limit ofthe stock pistons at 11.5:1 CR. I'm not tracking it all the time maybe 1-2 a year if i was tracking it all the time i would probably run at 10psi. If you run it a little on the safe rich side and run a little conservative on the timing it will help.
Rods and bottom end can handle it, clutch and trans are borderline, we will see. I'm not doing drag launches and slamming gears, that helps a little. But I don't care because its so crazy fast. As far a price I think the Rev 400 kit is $6-7 k I can't remember plus another $2k in exhaust and pulley, catch can so close to $10k.
#8 (permalink) |
Regarding wheel HP probably 310 a 320 ish based on butt dyno, maybe a little more?
#10 (permalink) |
there are several permutations of the tune (apparently up to and including Pulley as we see here) for the various Rev kits depending on your intake, exhausts, presence of a cat or not, and motor build, even general usage requirements. I think i recall reading a thread where phill mentioned he'll wire the IC fans up a little differently if it's a track focused car vs. street. (Well, the rev400 comes with Phil's 3" diameter intake, so there's no option there that i'm aware of)
If you personally don't need the programming cable (in that a shop is doing all the work for you) then you can also potentially get some discount on the kit without the cable as well. I think running any car with decent extra power oughta have a fuel solution because it's been said by several people that fuel starve is MUCH harder on the motor than on N/A engines. And you are going to run through a tank of gas MUCH faster on track than with n/a power... meaning you might not realize how low your fuel gets until it's too late.
2006 Aspen White Elise. LSS, LSD, Traction control, LS Toe Link Brace, LS Ohlins DA, Rota 15/16's, BOE surge tanks and Sector 111 Gpan2, Red leather, JL speakers all around with Acapulco MP54, CF dash top, gas shock opening rear deck, multi-vex mirros and replaced rear-view mirror with kit off this forum. Last edited by ewalberg; 10-30-2012 at 10:07 AM. |
#11 (permalink) |
Saved
I would love some video of the exhaust note, and driving!
Will your accomplishments be worth remembering once you have passed? 11B The greatest gift ever given, was our Salvation, the release from the bonds of addictions, and sins. To rise above the petty things that hold us down. |
#13 (permalink) | |
Gamera -The Atomic Turtle
How much work is it to swap pulleys? I'm assuming a new tune from Phil also? Or are you still on your old tune?
Lotus Elise #134 - June/2004 build date - BOE REV400 installed on stock motor w/stock cat/mani 336.4bhp, passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, etc. 0-60 = under 4 seconds. Build thread : http://www.lotustalk.com/forums/f160...seline-114302/ |
#14 (permalink) | |
However personally I think you may be pushing it a little with the stock cat at the higher boost / air flow level, dont know how much it can flow? just my opinion. I would think a 200cel cat would be a good idea. Before the upgrade from standard red pulley @ 10psi (82mm I think?) the stock clutch did fine!. Now after i upgraded to the 12 psi 75mm pulley, header, de-cat, silent touch muffler system it now slips the crap out of it in 3rd and 4th!! Having my new ACT clutch and lightweight flywheel installed next week. I think the 2Bular Header also made a HUGE difference, the stock 1.5" header is way too restrictive for this kind of flow. Just my opinion.
#15 (permalink) |
sure - i would be doing the manifold and cat delete also. Your car must be wild because mine is really good. So - you backed up your tune before you started, via your Koldfire cable & laptop, did the pulley swap, and reflashed after resetting the ecu? I have the cable also.
#16 (permalink) |
winding it out in 3rd running a rev400 is a magical thing. Turns just about any car in your rear view mirror into a teensy-weensy dot.
#17 (permalink) | |
San |
#19 (permalink) |
Haxord but mine
11.5:1 is still well within safety of a forced induction. Many people would say anything below 11 is just being wasteful.
-David 2006 Storm Ti Exige + VF TVS BOE Nikasil 10.5:1 + Vision Function TVS Vision Function MP62 Based Supercharger Install Thread Turn Signals Blink Fast? Stereo Harness Info |
#20 (permalink) |
i respect this line of thought. I'm going to stand pat with my stock pulley and 10? pounds of boost? Still makes 292 to the wheels with the cat. Stick with the way Phil and Andrew delivered the car..
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
