2009 XP National Champion
![]() Join Date: Oct 2003
Blackwatch XP Build-up i.e. 430HP 1630lb Beastie
What has 430HP/290lb-ft of torque but only weighs 1630lbs? It would be the Blackwatch XP "FrankenLotus". This is a car I started building with Robert's help a couple of years ago to compete in SCCA Solo in the XP or "Prepared Class X" After some discussion with a few folks that suggested that it would be good for the community to talk about how you get to this extreme level of prep from a stock lotus. I've attached a few starter pics and then based on interest/questions will describe the build up in detail.
More to follow:
#3 (permalink) | |
Elise Royalty
Frank is amazing ![]()
with future lotus driver
awwwe come on! you skipped over the how you made the fender flares!
Any pics of how you did that? in any case ![]() ![]() ![]()
Yes, it IS my real name. No, I don't look like him. I'm Polish. Polish barbarians are skinny nerds. 2006 BRG Lotus Elise (broken), 2009 Honda Fit (gas miser), 2007 Honda Odyssey (the wife's) |
#5 (permalink) | |
No, I suck. I'll explain though. Ted, the guru, bodyman in the pic there took some foam similar to the kind used for plants. You press it and it holds the shape of your impression. He glued 2" thick sheets of it to the fenders until he had a big block on each corner. Then by hand he shaped it. Then he bondoed it to give it strength. Next he wet-laid CF (4 layers)to the shape(with mold release on it). Next rip all of that off and trim the CF fenders, cut out the extra clam underneath to save weight, and bond to the body using an industrial adhesive. Then hours of sanding, filling, shaping etc etc etc. Total about 160hours! Still not done, it needs more primer, and paint!
#7 (permalink) |
Perry, You can't see it in these pics, but the opener is very elegant. You just take the lock button and run a thin rod down to the opener. Works great!
#8 (permalink) |
My new favorite feature is the super-duper quick removeable clam. It has the roll-bar cover integrated into the clam now. Here's how it works:
1. Remove the top - Now held in place by 2 rubber bands. 2. Remove the trunklid - This is held in place by 2 hood pins. 3. Lift. Notice the trunk is removed for weight savings. <object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/45exMvcd0dg"> </param> <embed src="http://www.youtube.com/v/45exMvcd0dg" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
#10 (permalink) | |
Porsche-Pro
#11 (permalink) | |
Agreed! The hinged clam will be awesome for the streetcar. My solution works great if you don't have a trunk and relocate your accusump and vacuum canister to where the fuel tank used to be. Fuel tank is now 3.25 gallons on the right side of the car.... Huge weight savings. Original tank was 25lbs. New tank is 5 lbs. I had to run the tank full to keep from having fuel starvation. 10 gallons at 6lbs/gallon = 60lbs vs. ~20lbs. Total savings of 60 lbs!
#12 (permalink) | |
Eric Jennings 2005 Elise 2004 S4 Avant 1995 M3 (RIP) |
#13 (permalink) |
We thought about it, but not cheaply. We may investigate again if demand warrants it. As I found out first hand, the flares cost a bunch and then the body-work to integrate is time consuming and costly.
#14 (permalink) | |
Porsche-Pro
I guess I could just pull out the stock tank and have it sectioned in 1/2...Just a bit more fuel would be nice for track days and some driving here and there. |
#15 (permalink) | |
#18 (permalink) |
Porsche-Pro
Yeah, I think aluminum and on the RH half would be good. Isn't the fuel level sender on the LH side? I guess you can just refit it over. Some baffling(./ \.) with small holes would be nice for starvation issues.
