Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
Old 10-20-2009, 11:15 PM   #201 (permalink)
2009 XP National Champion
fzust's Avatar
Originally Posted by masheen View Post
how did you have the car strapped on the mustang dyno? that is, where were the straps put? around suspension control arms? could that damage them?
I strapped the front the tow bar in the nose. The rear is suspension arms. I've had no trouble in the hundreds of dyno runs the car has seen. Its not a fragile as you might think.....
Old 10-22-2009, 11:27 PM   #202 (permalink)
fzust's Avatar
Finally got the front rotors drilled. Weight dropped from 9lbs 10oz to 8lbs 5 oz! Saved just 1lb 5 oz per rotor. Thus total saved is 5lbs 2oz total unsprung weight!
Old 10-23-2009, 12:08 PM   #203 (permalink)
06 elise
MNlotus's Avatar
this may be a dumb question, but does drilling the rotors like that affect the rotors negatively at all? you took alot of material off those rotors
2006 Lotus Elise-way too many mods to list (k24 swap planned. 300+whp)
http://www.youtube.com/watch?v=tjIcCsvhWvY
2003 Caterham Super Seven DeDion
http://www.youtube.com/watch?v=Z1ysO...e=channel_page
MNlotus is offline   Reply With Quote
Old 10-23-2009, 12:53 PM   #204 (permalink)
fzust's Avatar
We'll see! The problem I had before is that in AutoX there is not enough continuous braking to heat up the rotors. This indicates too much mass. Now that I have lightened them by 15%, hopefully they will heat up appropriately and not too much.
Old 10-23-2009, 12:56 PM   #205 (permalink)
Fred's Lotus has deviated so far from normal that the laws of physics no longer apply.
Hoosier tires won in 2009: 11 so far
Thank you Hoosier and NASA!
AZReason is offline   Reply With Quote
