Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
Old 06-24-2008, 10:09 AM   #41 (permalink)
2009 XP National Champion
fzust's Avatar
I have a box showing up from PES tomorrow. Any guesses?
Old 06-24-2008, 10:32 AM   #42 (permalink)
No, it's only an N/A
RichS's Avatar
Wow. Congratulations on the win!
Useful links to vendors removed at Nadeem's request.
"Nice avatar by the way, I doubt Colin Chapman would have followed the herd as I have seen many here do. --Nadeem"
RichS is online now   Reply With Quote
Old 06-24-2008, 10:40 AM   #43 (permalink)
fzust's Avatar
Thanks! Setup is really getting there.... Lots of suspension work etc. Penskes.....
Old 06-24-2008, 10:52 AM   #44 (permalink)
TWRD & Blip advertising
knucklehead's Avatar
Penskes FTW! Literally.
Jacob
Join Lotuscar.ning.com for LA Lotus social events
05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels
knucklehead is offline   Reply With Quote
Old 06-24-2008, 10:54 AM   #45 (permalink)
without a Lotus
FLuXeXigeS's Avatar
your penskes...actually your set entire set up rocks...
-Coi- currently having Lotus withdrawals
Facebook | Twitter | Pics | Vids
eBay Store
FLuXeXigeS is offline   Reply With Quote
Old 06-24-2008, 04:11 PM   #46 (permalink)
Aeternum Vale
Carpe | Viam's Avatar
Has the windshield remained stock? Or has it been swapped for a lighter alternative? .. and any more pictures?
Carpe Viam "Seize the Road"
Carpe | Viam is offline   Reply With Quote
Old 06-24-2008, 05:35 PM   #47 (permalink)
anglophile in exile
Aedo's Avatar
Images: 88
Those times are just fantastic - you must have completely demoralised the other competitors!
Oh - and the car looks awsome too!!!
Aedo is online now   Reply With Quote
Old 06-25-2008, 07:20 AM   #48 (permalink)
fzust's Avatar
I just removed the windshield and replaced it with 1/8" lexan. This is 1/3 lighter than the speed glass and 1/2 the price. It is a Monte Carlo windshield cut to fit. I need to take more pics. I should have some of the new box of goodies today or tomorrow!
Old 06-25-2008, 07:26 AM   #49 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Nice Fred, but your picture taking skills are terrible... I thought you were going to give us some nice eye candy... a couple shots here and there is simply not acceptable. This thread should be chalked full of pics! Where's the turbo setup? What other suspension changes have you made? Need pics
Cheers,
Phil
Old 06-25-2008, 08:37 AM   #50 (permalink)
fzust's Avatar
OK, Phil, I consider myself called out. Here are some pics:
1. General view from the rear/side. The thermally coated stainless ForcedFed exhaust manifold. Note I tried to keep everything quick removeable. The shock cansiters are clip in brackets for easy removal. The Vent can is hose-clamped in a low-CG place. The 4 pins on the frame are the locating points for the removable clam. The removeable clam is the BEST thing I ever did. For the readers at home it is NOT a solution for your street car, like the tilting clam.
Old 06-25-2008, 08:40 AM   #51 (permalink)
fzust's Avatar
Closeup of the FF turbo header. Very well constructed piece.
Old 06-25-2008, 08:43 AM   #52 (permalink)
fzust's Avatar
Notice my lightweight exhaust. This is a ceramic coated stainless pipe. The NGK WBO2 sensor has particularly good resistance to leaded fuel. I use one per season. The EFI standalone runs in closed loop mode even in WOT. This provides very exact A/F under all conditions. The copper plate is a heat sink to help protect the WBO2 from the excessive heat it sees so close to the turbo. Also notice the grey coating inside the exhaust. Lead residue.
Old 06-25-2008, 08:50 AM   #53 (permalink)
fzust's Avatar
One of my other favorite parts. The quick-removeable undertray. I am fortunate that I have worked on my car with a great race car fabricator outside of Phoenix. He has about 30 years working for grand-am and other teams. He maintains vintage race cars etc. This part was his doing. The rear diffuser and middle tray are held in place with only 6 CAM-LOCK quarter turn fasteners. Again, this required alot of changes from stock to work. but the result is that it only takes 30 seconds to take off the rear clam or both undertrays. The undertrays are now separate from the clam, so removing 1 does not require removing the other.
Old 06-25-2008, 08:56 AM   #54 (permalink)
fzust's Avatar
In this picture you can see the change to the rear upright to help fix the suspension geometry. As we found, once the car is lowered to a point, the roll centers get all messed up. Here we lowered the attachment point of the upper control arm to lower the rear roll center. Additionally, you can see the top-half of the "stacked" springs on the Penske shocks. The valving in the Penske's is very similar to the valving in the Penske's we sell! Just a bit higher in the rears to handle the stiffer springs.
That's it for now. I have more to post later on, including the front suspension, electrical etc.
Old 06-25-2008, 09:00 AM   #55 (permalink)
Phantom's Avatar
Images: 1
Fred, the car is awesome!
Is there any video available of it running and/or moving?
Grab Life by the Wheel
Phantom is offline   Reply With Quote
Old 06-25-2008, 09:23 AM   #56 (permalink)
fzust's Avatar
I have a vid somewhere at nationals last year, but it sucked then by way of comparison. I'll see if I can get some at the San Diego regional.
Old 06-25-2008, 11:51 AM   #57 (permalink)
I agree that the rear uprights need work from there OE form. Eliseparts offers a solution, but perhaps a little too minimal given the price. I think it changed the geometry my only 40mm.n (IIRC)
Will BWR offering a similiar solution?
More pics please.
smashfactory is offline   Reply With Quote
Old 06-25-2008, 12:17 PM   #58 (permalink)
fzust's Avatar
More pics please.
As of right now, we are not offering this as a solution as there is a machining involved etc etc. I looked at the Eliseparts solution and had similar conclusions: 1. Very expensive. 2. Not enough change. 3. Won't fit the stock brakes! Ours is purely custom for race only blah blah blah at this point. I can make recommendations if someone does want to go that way. I'll have more pics of the front this afternoon.
Old 06-25-2008, 12:30 PM   #59 (permalink)
Aeternum Vale
Is it normal to be drooling this much or to be this giddy? Perhaps I need to see a doctor immediatly
Can't wait to see the rest of the build, vids, pics etc.
Old 06-25-2008, 02:00 PM   #60 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
I'm not sure that exhaust is CARB legal. When will the kit be CARB approved!
Nice!
Phil
