Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
Old 06-25-2008, 02:09 PM   #61 (permalink)
2009 XP National Champion
fzust's Avatar
I'm not sure that exhaust is CARB legal. When will the kit be CARB approved!
Nice!
Phil
When it is on the dyno you can look down the pipe and watch the turbine glow bright orange! However, turbo is gone tomorrow!
Old 06-25-2008, 02:10 PM   #62 (permalink)
fzust's Avatar
OEM starter button....
Old 06-25-2008, 02:17 PM   #63 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Maybe if your exhaust wasn't so restrictive the turbo wouldn't build up so much heat
Gone? Why? Bigger mo-betta turbo?
Old 06-25-2008, 02:18 PM   #64 (permalink)
fzust's Avatar
Front Penske's with stacked Hypercoil setup. Because the Lotus uses very long non-standard springs. This has stacked 4" long, 2" ID springs. Many different rates are available to be able to fine-tune the suspension. Only 2 oz heavier than single spring. Additionally a quicker steering rack has been fitted to help auto-x responsiveness.
In the second picture You see the custom lower ball joint that lowers the lower control arm. This has the effect of raising the front roll center which helps overall handling and turn in.
Old 06-25-2008, 02:20 PM   #65 (permalink)
Randy Chase's Avatar
Images: 761
Holy crap you have been busy.
Lexus GX-470 tow vehicle.
Old 06-25-2008, 02:27 PM   #66 (permalink)
You are running a custom steering rack or the Nitron rack?
smashfactory is offline   Reply With Quote
Old 06-25-2008, 02:29 PM   #67 (permalink)
fzust's Avatar
Here are 3 pictures on the wing. The wing plates on top are exchangeable for different height plates to adjust the wing elevation. The mounts are 12 layers of carbon fiber with matching pieces underneath. Notice the beautiful aluminum re-inforcements underneath to connect the wing load to the rear frame.
Old 06-25-2008, 02:33 PM   #68 (permalink)
fzust's Avatar
Last pic is straight on from the rear. Just for gratuitous meaty tire shot.
Old 06-25-2008, 02:34 PM   #69 (permalink)
fzust's Avatar
Lotussport rack which is about 15% quicker than stock.
Old 06-25-2008, 02:42 PM   #70 (permalink)
fzust's Avatar
Twin-Screw. Finally. The turbo is awesome, but I think I am giving up 1/2 to 1 full second per course because of throttle response. For time attack this would be fine. For auto-x I need power RIGHT NOW! I will give up HP to gain throttle response.
Old 06-25-2008, 03:00 PM   #71 (permalink)
fzust's Avatar
Part of the reason you cut the weight is so you can put it back where you want it. Here is the ballast loaded in the passenger foot well. Laugh if you want at the ammo box, but it allows me to pull weight out quickly and easily. Everything is bolted to the floor. Tape is to keep the handles from rattling.
Notice the classy, lightweight shift boot to protect the cables! Also a battery kill switch moved temporarily to "dash" area.
Old 06-25-2008, 03:01 PM   #72 (permalink)
Scott Bowman's Avatar
Images: 21
Fred, very impressive car and some innovative engineering solutions! Maybe I missed it somewhere, but where's the battery? Stock location in rear clam or has it been relocated (and, I assume, downsized a bit)?
2006 Elise British Racing Green; LSS, LSD-TC, 2bular exhaust, Blackwatch Racing front bar, BWR Supercharger, Tillett Seats
Scott Bowman is offline   Reply With Quote
Old 06-25-2008, 03:03 PM   #73 (permalink)
fzust's Avatar
EFI ECU + WBO2 controller + relays.
Old 06-25-2008, 03:08 PM   #74 (permalink)
fzust's Avatar
HeHe. Oh yes long gone from stock location! It is now up front under the right access panel on the floorpan where the A/C used to be. I am using a PC680 Odyssey. I will try to get a pic of that later.
Old 06-25-2008, 03:09 PM   #75 (permalink)
fzust's Avatar
Last but not least one of my favorite pieces of equipment. Needs to be hard-wired since I yanked the cigarrette socket....
Old 06-25-2008, 03:20 PM   #76 (permalink)
fzust's Avatar
Also, as a testament to the strength of these motors. I have been running 14psi of boost on a stock motor except for stiffer valve springs and headstuds. I run a moroso oilpan and an accusump. I use 108 Octane Leaded race fuel. Last night I did a leakdown and had less than 10% leakage on any cylinder after 2+ years of this abuse. Knock on wood....
Old 06-25-2008, 03:40 PM   #77 (permalink)
On behalf of the community I would like to thank you for all the pics.
Very motivating!!!
IMO I am a little tired of all the aesthetic posts.
Keep up the good work.
Old 06-25-2008, 07:12 PM   #78 (permalink)
jim-clayton's Avatar
Quite impressive. I had no idea .... I thought you just stuck a big wing on your car.
Looks like a lot of hard work and engineering.
2005 Elise Storm Titanium
Old 06-25-2008, 08:26 PM   #79 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Fred,
Is that a euro diffuser? It looks OEM, but no exhaust hole...
-P
Old 06-25-2008, 09:32 PM   #80 (permalink)
fzust's Avatar
Yep, a ton of work! Car go fast. Me likey!
