#161 (permalink) |
Gah, I love what you've done with this car!
2005 Saffron Elise :: Pro-1 Exhaust, Cup Car Airbox w/ TRD filter, Manly Engine Mounts, Shift-I, Bollock, 1/4-turn fasteners, Esta C/F Decklid, de-stuffification, other stuff... |
#162 (permalink) | |
Denuo Volatilis
2005 Federal Elise | Touring | Storm Titanium ...73,000 miles and aging beautifully... 2000 New Beetle | Turbo | Reflex Silver ...107,000 miles of steadfast service... |
#165 (permalink) |
2009 XP National Champion
![]() Join Date: Oct 2003
This is the S/C setup. Frank's car makes more power, but is a lowered compression turbo setup. We have different goals. This car is for auto-xing which needs ZR-1 kind of power delivery across a wide RPM band, since the acceleration zones are so short. However to optimize for this I kept the stock 11.5:1 compression and run VP C-12 leaded race fuel.
#166 (permalink) |
I can't believe I missed this thread until now. That thing is absolutely INSANE! (the car not the driver.... ok, the driver is a close 2nd)
I feel bad for the other XP competitors. It's not even fair when you show up with this thing. You mentioned a few posts up that you took it to the drag strip. Did you ever make it? Curious what the times were.
2005 Graphite Grey Elise - 1893 lbs Setup by Ralph @ V2 Motorsports ![]() Nitron DA, Lotus Sport Swaybar, Braille B2015, S111 RTVBrace, V2arms, V2linx, V2mounts, Panel Delete w/ Larini 8" |
#167 (permalink) | |
As far as the XP competition, I am not the best driver out there, so it helps keep things even. It is funny though because XP is kind of the catch-all class, so if somebody shows up with the wrong set of minor mods, they get bumped into XP and then it is a bit of a bloodbath. The drag strip didn't happen because the car won't pass tech for about 100 reasons.
#168 (permalink) |
And just wait until the Noble/Rossion is classed in XP. Should be fun.
#169 (permalink) |
is this a TVS or mp62 setup?
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
#170 (permalink) |
It is using a Lysholm 1.6L twin-screw. It is a one-off. Closer to the TVS, but that is a 1.2L blower vs. MP62 which is 1.0L.
#171 (permalink) |
Finally, after taking the transmission off the 3rd time, I remembered my camera. Here are some pics of my uber-trick 5.5" twin-disc button clutch and flywheel. This clutch, ring gear, and flywheels weighs about 11 lbs vs 28lbs for my old "lightweight flywheel and ACT race clutch. So that is 17lbs of ROTATIONAL MASS taken off of the driveline.
#174 (permalink) |
Dunno. I've had issues with the 3rd and 5th gear synchros breaking which is really weird since I don't use anything above 2nd. We suspect maybe the Royal purple gear lube has too much viscosity and is engaging the synchros when it shouldn't. That sounds like reaching, because it is, but there isn't a better theory. Sounds like a set of dogs in my future....
#175 (permalink) | |
Now I have the BWR 5.5 custom button flywheel & ring gear, 2 disc cintered bronze clutch from quartermaster. Important thing to note is not just the 17lb savings but that it also is concentrated in a much smaller diameter which reduces angular momentum.
#178 (permalink) |
Meow!!
17 lbs... drool... hmmm...
![]() What's street drivability like? I'm used to my Fidanza and ACT XTSS leg breaker ![]()
#179 (permalink) | |
#180 (permalink) |
Not only does it rev sickly fast. It helps braking on course. Since we rarely downshift in autox, the braking is done with the engine engaged to the drive train. With a S/C you have alot of inertia and you end up using part of the brakes to slow the engine! Now that is far less an issue....
