(Formerly PESTODUDE)
Different torque on lug nuts hot vs cold
Someone told me I should torque the lug nuts to different torques when the wheels are hot. IE: after a session. Is this true?
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune. |
What is the correct torque? (cold)
British Car Restoration
Vibrations !!
The slight temp change would have nothing to do with it. The rationale may be that the torque has changed because of vibration and loading. It's more important that threads are lubricated, so the torque readings are valid. Temp will have a big effect on tire pressures, mostly because of the water vapor in the air. I use N2 in my tires, a hold-over from karting days.
Got it. thanks!
#7 (permalink) | |
Unattractive Nuisance
thx
05 elise (PES chip, SSRs, shift tower mods, Multivex; HID low beams); 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "Political language is designed to make lies sound truthful and murder respectable." G. Orwell. 6. "A bore is a man who deprives you of solitude without providing you with company." - Gian Vincenzo Gravina |
#8 (permalink) |
Torque values are more consistent for a lubricated thread. Though the torque specified for a lubricated thread is usually lower than that specified for a dry thread.
I believe the torque specs for wheel lug bolts are for dry. |
#9 (permalink) |
The torque values for lubricated and non-lubricated threads are greatly different. For lug nuts/bolts, torque values are pretty much always specified for non-lubricated threads. As long as you keep the threads clean and in good repair (i.e.. no rust, etc.), the dry torque values should be used (with non-lubricated threads of course) - there is no real advantage to using lubrication on the threads (and lots of disadvantages). The only real advantage of lubricating the threads is that they will be less likely to corrode in place - which isn't a real problem anyway...
#10 (permalink) |
registered nipple
Randy,
i never torque my lugs when things are hot after coming off the track. i wait for them to cool and do it right before i go out for my session. the reason i was told to do this is because when things are hot, they expand, if you torque them down when there is possible expansion, there may be more torque than you wanted on those items (lugs in this case) now that they have contracted after being cooled down. maybe i am misinformed, but thats how I do it, and why.
2008-2009 SCCA AZ Regional "Driver of the Year" 1986 Swift DB-1 Sold 2008 HSR-West FF 3rd generation Champion 2008 "The Series" FF 3rd generation Champion 1987 Porsche Spec 944 2008-2009 season SCCA AZ regional Champion |
