Elise/Exige Racing Wide-body - Page 5 - LotusTalk - The Lotus Cars Community
post #81 of 150 (permalink) Old 10-19-2012, 07:45 PM Thread Starter
re: Power
I solved the pulley problems.
The final dyno numbers were 600hp and 400ft.lbs. from 6500 to 8500 flat at 25psi and a small leaf blower stuck in the intercooler for cooling airflow (not enough).
The smaller turbine housing is coming on Monday. Maybe I will have tiem to try it out.
A lot of the body panels are off the car, so not much to picture. We will put it back together next week and take some pics with windshield.... I hope.
Anton
ageshelin is offline
post #82 of 150 (permalink) Old 10-20-2012, 07:32 PM Thread Starter
re: dyno chart
Supposedly, this dyno reads 'low'.
The turbine housing is too large. I should have a new one on Monday... finally!
post #83 of 150 (permalink) Old 10-21-2012, 08:33 PM
shay2nak
shay2nak's Avatar
damn that is crazy power for this car.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #84 of 150 (permalink) Old 10-26-2012, 04:47 AM Thread Starter
Finally on the track
Finally I got the car aligned and set-up to shake down.
The car understeers... a fair amount.
It handles and brakes well.
600 whp is just about right... I thought the turbine housing was too large, but it feels OK on the track the car is so light.
I will take more pics.
Anton
post #85 of 150 (permalink) Old 10-26-2012, 01:08 PM
plastique999's Avatar
How much does it weigh again?
2011 Final Edition S260 Isotope Green
2005 Track Elise LotusCupUSA
2008 211 FS
plastique999 is offline
post #86 of 150 (permalink) Old 10-26-2012, 01:26 PM
doug_porsche's Avatar
Looks great!
How is the rear wing attached to the chassis? Looks like there is lots of leverage on the uprights.
Apexes are a lot like relationships. So tough to get right, so easy to see where they went wrong.
The secret to a long life is ------- not dying.
doug_porsche is offline
post #87 of 150 (permalink) Old 10-26-2012, 02:39 PM Thread Starter
The weight on un-calibrated scales came out to 1708lbs wet i.e. full of fuel, etc.
The shop uses the scales for corner balancing, so as long as they are all the same, it satisfies the purpose...
Anton
post #88 of 150 (permalink) Old 10-26-2012, 02:41 PM Thread Starter
re: Wing attachment
The reat sub-frame (a.k.a. crush structure) is all custom tube-frame. The uprights attach to that.
The wing is old regulation Trans-Am wing 72" wide.
Anton
Originally Posted by doug_porsche View Post
Looks great!
post #89 of 150 (permalink) Old 11-12-2012, 04:04 PM Thread Starter
Track Pic.
Evidence of some agricultural work I just pushed the car a bit and got 2 wheels off into the local mud pit....
Anton
post #90 of 150 (permalink) Old 11-12-2012, 06:19 PM
Inactive
dstevens's Avatar
Wings looks too high and for forward to help the underbody. Very hard to tell without CFD / wind tunnel, but I'd try it lower and further back.
2005 Elise with Honda engine
Please don't PM me - this forum is no longer usable and I do not monitor it.
It was fun while it lasted.
dstevens is offline
post #91 of 150 (permalink) Old 08-08-2013, 05:54 PM Thread Starter
re: Inconel
I took the exhaust wrap off to replace the turbo.....
Take a look at the pic.
The header is made of Inconel. It turned an interesting gun-metal green color. Otherwise, it feels shiny and smooth and as good as new. The collector is a Burns collector made from 321 (an aircraft exhaust stainless). It looks scaly and rusty! Both parts get very hot (bright red). Inconel is only 0.028 thick, the 321 collector is 16 gauge.
I think, I will be making all my headers from Inconel when I can afford it!
Anton
post #92 of 150 (permalink) Old 08-08-2013, 06:06 PM
The Enforcer
oldmansan's Avatar
My ZX10R Nassert Beet header/exhaust is Inconel/Titanium. I've been told that Inconel is a beeotch to work with.
San
oldmansan is online now
post #93 of 150 (permalink) Old 08-08-2013, 06:58 PM Thread Starter
re: Is Inconel hard to work
Well, not that hard. You have to use good sharp tooling. So a carbide cut-off wheel worked fine. We tried to cut it with old metal saw, it ground all the teeth off. Inconel work-hardens ie. becomes harder as you work it. Did not have to bend it, since I bought u-bends, anyway. Welding is not hard at all. Making the weld pretty is harder Titanium is much harder to weld...
It is just so $$$, more than Ti. Otherwise, it is nice and strong, so the piping is thin and light. Inconel stands higher temperatures and does not loose strength as fast as steel or Ti with temperature, so it can be made much lighter, especially for exhaust. All F1 and NASCAR exhaust is Inconel.
Anton
San
post #94 of 150 (permalink) Old 01-06-2014, 03:30 AM
Are you still willing to sell the wide body kit?
Thanks
alishawkat is offline
post #95 of 150 (permalink) Old 01-06-2014, 06:44 AM Thread Starter
re: Wide-body kits
I have molds and I can make more parts. Material is up to the customer i.e. fiberglass, carbon, carbon and kevlar....
It is a lot of work to make and install.
My fabrication shop is Caravaggiocorvettes.com. Call John for more details 905-761-5787.
Anton
post #96 of 150 (permalink) Old 02-12-2014, 06:34 PM Thread Starter
I am going racing, again! Canada Supercar Series
There is a new semi-pro race series starting here. It looks like they will let me in.
http://supercar.ca/
I need to run some stock trim pieces. See my post in WTB, please.
Also, if I have to run a stock diffuser, what is the best one?
Where is the site with all the Lotus manual pages and parts and prices? I need to install front lights. I have S1 front clam.
they allowed me my turbo Honda motor and a sequential tranny from Quaife. I will be running against race prepared Scuderia F430 and GT3's. Based on my testing, I should be competitive. Need to hit 1:24 at Mosport, consistently...
Anton
post #97 of 150 (permalink) Old 05-10-2014, 09:48 PM Thread Starter
New Quife sequential is in the car
New transmission is in the car.
Anton
post #98 of 150 (permalink) Old 05-10-2014, 10:01 PM
The Enforcer
oldmansan's Avatar
Anton
You mean Quaife, right?
You work at Caravaggio? I have a C6 Corvette so I've seen a lot of their work. Pretty pricey stuff.
San
post #99 of 150 (permalink) Old 05-12-2014, 02:28 AM
streetthrowback's Avatar
06 OCM elise r.i.p.
streetthrowback is offline
post #100 of 150 (permalink) Old 05-12-2014, 10:10 AM Thread Starter
re: My new tranny
It is a Quife Honda kit with Tyler's billet bell-housing (the rear case is Quaife). So besides a few bearings and seals, this is not a Honda tranny anymore. It fits into the same spot. The fit is tighter as the case is a little larger in diameter.... had to shave a few places.
I have known John Caravaggio (of same names Corvette shop), since 1992. He has done a lot of work for me and with me, including a LeMans C5...
The price is very little compared to the quality and workmanship. John does a lot of work for OEM's, also...
Anton
San
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
Human Verification
