Factory Shift Cables are Horrible...Need Help.
Does anyone know of an aftermarket company that makes a shift cable that won't melt after one session? Even with a heat sleeve on my shift cables my turbo melts the side-to-side shift cable after 10 laps. I'm tired of retiring after one session and spending $300 on a shift cable every time I do any sort of track-day event.
It's a Lotus
Call Sector 111.
They'll know. Welcome to Sector 111, home of Lotus Elise Aftermarket Performance Parts and Exhaust Accessories. or ForcedFed. Elise turbo
Lotus body work and experienced mechanic at Lotus Talk sponsor Specialty Car Craft. http://www.specialtycarcraft.com/ See more of Larry's Photoblog at http://www.larrysphotoblog.net/ |
I think the factory cables are fine when used within the parameters for which they were designed. You probably should be speaking to the company that designed your turbo kit, which sounds like it should have either come with A) better shielding, B) different cables.
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
#4 (permalink) | |
Check the studs and nuts from the header output flange to the turbo intake. My guess is that they have worked loose and you are getting pure exhaust forced onto the cables right where they apex. Been there, done it! Expect to pay about $900 for the pair. Also insulate the new ones with heat shield and it should be OK after that. The cables are stainless stranded wires that are encased in a nylon sheath. Once it gets hot enough the shifter cable wires actually melt through the sheath and create too much slack.
If the nuts are loose or missing, replace them with jetnuts. If you never used jetnuts before make note that they can only tightened down once. If you back them off they are useless and have to be replaced.
2006 Diasio D962R Arancio Borealis SOLD: 05 Elise, Benetec Carbon Fiber full body & rear wing, FF 275 turbo kit , Ikeya sequential shifter, Ohlins coilovers, Porterfield R-4, Sector 111 RTD brace & HNT pad, Yokohama A048, Caterham seats, Simpson 5 point belts, Moroso oil pan, Sector 111 Boomerang, AutoMeter CF Oil Pres-Boost-Vac gauges. No AC, heat, airbags. 1619 pounds "wet" |
#7 (permalink) | |
The kit is Forced Fed, and was installed at forced fed back in late 2005. When I called them after the first melt down they did say that it was an issue on track cars and to wrap it in some sort of heat protectant. The one that is melting is the side-to-side control cable that is closest to the exhaust and the turbo (which from what I hear is the usual suspect). I'm know I'm not the only person with this problem. Forced-Fed said that even some of the normally aspirated cars have been known to melt the cables in track situations. ![]() If I can't find an alternative cable, my next step is to wrap the cables in fiberglass or asbestos (if I can even still find it).
2005 Forced Fed 275 Elise. Starlight Black. |
#8 (permalink) |
I wrapped mine and no issues since.
#10 (permalink) |
Thermo-Tec makes a product "Thermo-Sleeve" available at Summit Racing. Velcro seam, so it goes on without having to take anything apart.
#11 (permalink) | |
| Display Modes | |
