Innovative mounts: 60a vs 85a - LotusTalk - The Lotus Cars Community
Old 03-29-2011, 05:16 PM   #1 (permalink)
sleepe's Avatar
I've had all four 60A durometer mounts for about 6 months.
I love them, but have noticed engine rocking under hard acceleration to hard braking. The rocking is also pronounced on off<>on throttle transitions as well
as heel/toe down shifts.
Are the 85a significantly better/firmer than the 60a?
Will they impart more NVH? (not that this is an issue, just curious)
-Robert
car mods here
sleepe is offline   Reply With Quote
Old 03-29-2011, 10:02 PM   #2 (permalink)
Kneedragger
KazeSpec's Avatar
85A are significantly stiffer. on my RSX i was able to run just the 2 side mounts and the rear mount with 85A.
19-- Europa S2 62 Replica/Track Car Build
02 Suzuki GSX-R750 (daily/track) - current
03 Acura RSX Type S (daily/track) - sold
KazeSpec is offline   Reply With Quote
Old 03-29-2011, 10:37 PM   #3 (permalink)
Will Race For Bacon
apk919's Avatar
Images: 20
You can buy just the front and rear mounts in 85A durometer.
That said, I have four 60A mounts in my Exige and 60A front and rear mounts in my Isotope Green 2-Eleven. A significant improvement over stock.
The Yellow Hornet 2-Eleven now has 85A front and rear mounts. It hasn't been tracked yet... but there seems to be a noticeable increase in vibration. Obviously not a serious issue for a track car.
Come along for a ride: my videos
2007 Aspen White Lotus Exige S (street ride)
2010 Isotope Green Lotus 2-Eleven (track ride)
2008 Yellow Hornet Lotus 2-Eleven (track ride 2)
* 2011 Lotus Cup USA Race & Time Trial 2-11 Class Champion *
apk919 is online now   Reply With Quote
Old 03-30-2011, 12:33 PM   #4 (permalink)
sleepe's Avatar
Thanks for the input.
The 60A is a big improvement, but after you get accustomed to something you always want something better.
-Robert
car mods here
Old 03-30-2011, 12:38 PM   #5 (permalink)
Sector111
info@ Sector111's Avatar
The 85's add A LOT of vibration. We tested them on our Elise which is..or was a street friendly car at that point. We only recommend these for race cars: cars that will never see the street. throttle response was fantastic as was the shifting feel. HIGHLY recommended from a performance stand point on a track-only car. You've got to be pretty hardcore to put up with this on street
Sector111- Your Lotus Aftermarket Performance Leader
Track Trilogy of Terror - Protect Your Car Balanced Approach - Tune your car safely
info@ Sector111 is offline   Reply With Quote
Old 03-30-2011, 05:02 PM   #6 (permalink)
That sounds like a challenge to me....
2005 Krypton Green Elise
Innovative 60a engine mounts
Sector111 RTD Brace
Lotus Sport Suspension
DBA4000 rotors
Machined carpet buttons!
Savet is offline   Reply With Quote
Old 03-30-2011, 09:25 PM   #7 (permalink)
Kneedragger
KazeSpec's Avatar
Used to daily mine. Not too bad
Old 06-11-2011, 07:42 PM   #8 (permalink)
TenaciousX's Avatar
I installed the 85A's on my Exige a couple of weeks ago. I was amazed because I used to be able to see the shifter moving just revving the engine. Now, no noticeable movement just revving the engine and very little shifter movement at the track.
However, if you think there were little vibration noises on the stock 111, now it's 10x the rattling. The engine even sounds louder inside the car because it's vibrating the whole frame - imagine tapping a tuning fork then setting the handle on a table.
That being said, the annoying parts really only occur under 2500 rpm or so and is the worst at idle. It's PFM on the track and really changes the feel of the car.
Mine is a track/street/occasional DD. My 2 cents - if you can put up with a Stage II exhaust on a road trip, you'll have no problem with the 85A mounts.
I'll put up some notes from my install in the next few weeks (and how to combine the substiffy, gpan and racemounts install without killing yourself.)
2007 Exige S AW TP/TC 1/20/2007 - 3/25/2011 RIP
2008 Exige S240 Starlight Black
TenaciousX is offline   Reply With Quote
Old 06-11-2011, 07:53 PM   #9 (permalink)
cph
cph's Avatar
I have 85A on my 2-11 and there is loooooots of vibration in the lower RPMs .... But they work great .
I took some video of the engine during a track session and there is very little movement .
Gears are better .... sharper and everything is a little snappier.
cph is offline   Reply With Quote
Old 06-11-2011, 08:37 PM   #10 (permalink)
USA 1LT FA
Exigenesis's Avatar
Images: 13
I had Manly inserts on for about three months before I got tired of re-adjusting my drooping dual-tip Larini due to the engine movement. I put on Sector's RACEmounts (85a) and I'll never go back. My Elise was purely a street car and I briefly had second thoughts (and I consider myself moderately hard-core) during the break-in period - if such a thing exists for mounts, IDK. But after a few hundred miles, they "mellowed" out to absolute driving perfection; vibration increased quite a bit - using the rear-view mirror at a standstill was useless and like peering through the eyes of someone room-spinningly intoxicated - shifts were smoother and sharper, throttle response was telepathic, exhaust sounded better, food tasted better, colors were brighter, my quality of life improved at least 25%. It's the way these cars should come from the factory, IMHO.
2009 Exige S240 - Starlight Black, Magnolia interior w/ black leather console, Track Pack, Touring Pack, Traction Control, Starshield, Forge intercooler, TRD Airbox, Highflow Filter, Denso High Flow Fuel Pump, RC 550cc injectors, Odyssey Race Battery with S111 cutoff switch, PPE header/decat, Larini sport exhaust (dual tip), CEL eliminator, RPE kit, RACEmounts (85a), sport lights, painted shifter knob characters, '07 sills, carpet buttons, locking gas cap (Stant 11507 conversion)
Exigenesis is offline   Reply With Quote
Old 06-12-2011, 05:07 AM   #11 (permalink)
I have the 75A mounts on my street/track Exige, I'm very happy with them. I haven't tried the 85A's, but based on these (and other) reports, I think they're a good compromise for a street and track car.
-Ed
'08 Arctic Silver Exige S240
AustinP is offline   Reply With Quote
Old 02-15-2012, 11:56 AM   #12 (permalink)
sleepe's Avatar
It's alive!!!
Does anyone have the 60a's on the side mounts and stiffer ones on the rear and front locations? I was thinking I may try the 85's front and rear, but leave the 60A's on the side..?
Can the poly-inserts be pressed out of the innovative mounts and be replaced with a different poly insert?
-Robert
car mods here
Old 02-15-2012, 08:34 PM   #13 (permalink)
Kneedragger
KazeSpec's Avatar
Originally Posted by sleepe View Post
It's alive!!!
-Robert
Innovative can press in different durometer inserts for you
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
