Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
Old 09-21-2007, 05:32 PM   #1 (permalink)
CFRA_7's Avatar
Replace roters vs. new system
From reading the threads it seems that it cost’s around $1,400 to replace the front rotors. How long can I expect them to last? Would it be cheaper in the long run to upgrade the brakes to an after-market system for around $2,800 as opposed to buying those expensive rotors? Of course, you wouldn't upgrade until it's time to repalce the stock ones.
CFRA_7 is offline   Reply With Quote
Old 09-21-2007, 05:39 PM   #2 (permalink)
Registered Uzi
ritcci's Avatar
there has to be a very cheap replacement somewhere. isnt there???
05 Lotus Elise KG
76 Lancia Beta Scorpion
yay!
ritcci is offline   Reply With Quote
Old 09-21-2007, 05:59 PM   #3 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
front rotors do not cost that much. You can get a full set(of 4) of aluminium hat lighter weight better than stock rotors for that
The cheapest rotors I know of are ~$240/pair. The EBC Rotors. http://www.autopartswarehouse.com/pr...ory=brake_disc
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
Old 09-21-2007, 06:07 PM   #4 (permalink)
DBA 5000 rotors through Cantrell Motorsports seem to me to be the best long term deal. $300 per rotor, they're the same all the way around, and $177 for a replacement rotor. These appear to be more durable and of better quality than OEM. I didn't want to try EBC anything.
Peter Fanning
2008 Persian Blue Exige S240 - track, touring
2006 CO Exige - RIP
pfanning is offline   Reply With Quote
Old 09-21-2007, 06:17 PM   #5 (permalink)
Keep it simple and real
Lotusmotion's Avatar
Cross-referencing your posting about brake pads, at 8,000 miles and 8 track days, the stock rotors on my Exige look good and have plenty of life left in them. The Lotus mechanic advised me they are made from fairly soft metal, but I am not sure what the expected life is or what others are experiencing.
I would estimate the stock rotors are good for at least 15,000 miles if you track the car and a multiple of that if no track use (assuming routine care). After-market replacements for all four rotors can be had for far less than one grand and even as low as about $500.
'06 Exige - Ph. Black/Touring/Track/LSD/TC/SS. Mods: corner balanced - RTD brace - Manly's inserts - decambered - Pagid Blacks - Motul fluid - tow hooks - Schroth belts - extinguisher - AIM timer - Green Filter - Larini - oil temp & pressure gauges - AO48s & Rotas on track - T1Rs & OEM wheels on street - rear camera & monitor - Stebel horn - speakers upgraded, sub & iPod controller - DRL disable switch - aux. fuse panel - sill pockets - leather console - Bootie - roof scoop functional.
Lotusmotion is online now   Reply With Quote
Old 09-21-2007, 06:38 PM   #6 (permalink)
-30-
ace10's Avatar
Images: 35
EBC's are $480 for a set of four. one piece.
2007 Exige S, Storm Ti. Sport, Track and TC.Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons.
08 M-B ML320 cdi, 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 97 Bobcat 751C
The Red Pill Ignore Me *Be sure too save your IL before browsing away
ace10 is offline   Reply With Quote
Old 09-21-2007, 07:31 PM   #7 (permalink)
:panic:
John's Avatar
StopTech is looking to do a 2-piece OEM replacement - stay tuned.
05 "Elixige" w/ Stuff - FOR SALE
07 Mazda 3S - 4-wheeled commuter
99 YZF-600R - 2-wheeled commuter
John is offline   Reply With Quote
Old 09-24-2007, 07:53 AM   #8 (permalink)
Complete Lotus Junkie
mp3moose's Avatar
Are the EBC's any good?
mp3moose is offline   Reply With Quote
Old 09-24-2007, 07:58 AM   #9 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
I'm going to try out EvilTwin's bespoke group-buy rotors.
xtn
Old 09-24-2007, 08:02 AM   #10 (permalink)
mp3moose's Avatar
My car has been tracked just once on stock rotors and about 9000 miles total on the car and my rotors are gone.
Old 09-24-2007, 08:10 AM   #11 (permalink)
No, it's only an N/A
RichS's Avatar
Stop braking so much. Don't you know you have a momentum car?
Useful links to vendors removed at Nadeem's request.
"Nice avatar by the way, I doubt Colin Chapman would have followed the herd as I have seen many here do. --Nadeem"
RichS is offline   Reply With Quote
Old 09-24-2007, 08:12 AM   #12 (permalink)
-30-
ace10's Avatar
Images: 35
are you still on the original pads?
Old 09-24-2007, 08:22 AM   #13 (permalink)
mp3moose's Avatar
Put on new pads (stock) two weeks ago.
Old 09-24-2007, 08:26 AM   #14 (permalink)
I am looking to replace the rotor with APracing disc, maybe larger disc for my 15 inchs wheel (I will see next week what is the maximnum disc size).
I will machine the aluminum center myself.
But, I will use the stock caliper. The main thing is the disc weight, which should be heavy enought to take the heat and be able to run with pad able to run on street and track. In the next mouth, I will remove the disc to measure the disc weight.
I think that it is not required to change the caliper. Big caliper have the advantage of more pad for reduced wear, and sometime more rigid. But the heat and the brake torque capacity is not changed with big caliper when the brake pedal is not change (of course, if larger piston are used, and the master brake is not changed, the force will be higher for the same pedal pressure, but the pedal stroke will be longer).
elise/europa is online now   Reply With Quote
Old 09-24-2007, 08:28 AM   #15 (permalink)
BANNED
SweetDaddyD's Avatar
Images: 2
I've had a set of EBC rotors on my Bimmer for at least 5 years (4 of which I was running 18" wheels for) and they have been great. I've had good luck with their pads in the past too.
SweetDaddyD is offline   Reply With Quote
Old 09-24-2007, 08:29 AM   #16 (permalink)
-30-
ace10's Avatar
Images: 35
did you or someone measure the front rotor thickness? i'm having a hard time understanding how the rotors could be worn after only one set of OE pads. consumption should not be a one for one. i'm going to my third set or pads with a good bit of track usage (7K miles total, 15 to 18 track days) and i'm just approaching the point of thinking about replacing the rotors in the front. fronts are awaiting the delivery of their third set of pads.
Old 09-24-2007, 08:40 AM   #17 (permalink)
mp3moose's Avatar
I haven't messured them personally but Curry's auto in chantilly is doing all the work on the car. I trust mike (the manager) as he has an exige. Thus I am exploring a cheaper option to the stock 300+ per rotor.
Old 09-24-2007, 09:15 AM   #18 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
thats sounds more right. I burned up my 3rd set(1 stock, 2 R4) of pads around 9500 miles and needed rotors then.
Old 09-24-2007, 09:31 AM   #19 (permalink)
Elise Fanatic
sleepless's Avatar
I went with the DBA 5000's as well.
I also wouldn't put anything made by EBC on any of my cars; certainly not for track use!
Pete
05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo
sleepless is offline   Reply With Quote
Old 09-24-2007, 09:58 AM   #20 (permalink)
:panic:
John's Avatar
I used a set of DBA 2-piecers on my last car, and I found the metal to be a bit "softer" that I wanted. I switched to the StopTechs and got about ~33% more life out of them, using the same PFC01 pads.
