Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
Old 09-27-2007, 01:45 AM   #1 (permalink)
No, I don't own a Le Car
9and3's Avatar
Snap-in Lap Belts Harnesses
Has anyone successfully installed snap-in lap belts as part of a 4/5/6 point harness? This would typically include snap-in brackets and eye bolts so the lap belts can be removed.
These are the brackets: http://www.schrothracing.com/product...ap-in-hardware
I'm told there is not enough room to do this kind of installation in our cars safely. It would be nice if someone could post pictures and prove this wrong. Thanks!
9and3
'07 Exige S, Performance Pack
9and3 is offline   Reply With Quote
Old 09-27-2007, 03:57 AM   #2 (permalink)
-30-
ace10's Avatar
Images: 35
that's what i'm using for my lap belts. they're clipped into eye bolts drilled through the frame on the floor at the base of the bulkhead. there are only two options for securing the lap belts... using the s111 piggy back arrangement or through the floor either using eye bolts/snaps ins or rallye clips.
you will loose a couple of detents worth of rearward travel on the driver's side if you use the eyebolts/sanps ins. personally, i think it's worth it. if you remove the lap belts while street driving, you regain all of the seat travel, provided you very, very carefully installed the eyebolts in the proper locations.
i used the schroth backer plates in conjunction with the eyebolts. the eyebolts will need to be the longer version, (longer than what is provided in the harness packaging)
http://www.schrothracing.com/product...rcement-plates
the basic 2"X4" shape of the plates were not entirely compatible with the flat bottom of the car. i ground down the rectangular shape in order to make better contact with the underside of the car.
2007 Exige S, Storm Ti. Sport, Track and TC.Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons.
08 M-B ML320 cdi, 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 97 Bobcat 751C
The Red Pill Ignore Me *Be sure too save your IL before browsing away
ace10 is offline   Reply With Quote
Old 09-27-2007, 03:59 AM   #3 (permalink)
-30-
ace10's Avatar
Images: 35
also see this thread:
http://www.elisetalk.com/forums/showthread.php?t=41320
for links to some of the better harness install threads.
Old 09-27-2007, 05:41 AM   #4 (permalink)
Jugga Jigga Wugga
EdHahn's Avatar
FWIW...
and
http://www.elisetalk.com/forums/showthread.php?t=41102
ed
Magnetic Blue/LSS Delivered: 1/13/05
EdHahn is offline   Reply With Quote
Old 09-27-2007, 07:05 AM   #5 (permalink)
-30-
ace10's Avatar
Images: 35
and just to piggy-back on ed's install. his was done by a professional race fab shop. his seats are not from lotus and the backet into which that eyebolt is fastened is not from lotus. it is all custom work.
Old 10-09-2007, 11:34 AM   #6 (permalink)
Shawn C's Avatar
Cant you just use the anti-sub bar from Sector and attach your belts to that? I have a 6 point sub belt sitting on my desk and I planned on installing them tonight...
http://www.youtube.com/jerusdc
Shawn C is offline   Reply With Quote
Old 10-09-2007, 11:45 AM   #7 (permalink)
-30-
ace10's Avatar
Images: 35
you certainly could use them, if you like the design.
