Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
Old 09-21-2007, 05:28 PM   #1 (permalink)
CFRA_7's Avatar
Street & Track Pads -
My friend told me that he uses the same pads for street and track. He driver’s his car about 10K miles per year. He’s a pretty fast driver. Is this really doable? Any downside? What pads do people use that can do double duty like that?
CFRA_7 is offline   Reply With Quote
Old 09-21-2007, 06:09 PM   #2 (permalink)
Keep it simple and real
Lotusmotion's Avatar
The Lotus factory pads are quite suitable for track use...as well as the street. I just got 8,000 miles (including 8 track days) of wear out of mine.
There are many after-market replacement choice available.
'06 Exige - Ph. Black/Touring/Track/LSD/TC/SS. Mods: corner balanced - RTD brace - Manly's inserts - decambered - Pagid Blacks - Motul fluid - tow hooks - Schroth belts - extinguisher - AIM timer - Green Filter - Larini - oil temp & pressure gauges - AO48s & Rotas on track - T1Rs & OEM wheels on street - rear camera & monitor - Stebel horn - speakers upgraded, sub & iPod controller - DRL disable switch - aux. fuse panel - sill pockets - leather console - Bootie - roof scoop functional.
Lotusmotion is offline   Reply With Quote
Old 09-21-2007, 06:34 PM   #3 (permalink)
-30-
ace10's Avatar
Images: 35
are you hard on brakes at the track?
if you're not especially brutal on them then i'd say there are few common options.
Lotus OE
Pagid RS42 "Blue"
Porterfield R4
there are other options but these are some of the more common choices. i run a more agressive Pagid pad on the front, as i'm more heavily biased to the track. i'm just over 7K miles, got maybe 6 or 8 track days on OE's, now maybe 10 from the Pagids. i'm due for new fronts again after this weekend.
2007 Exige S, Storm Ti. Sport, Track and TC.Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons.
08 M-B ML320 cdi, 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 97 Bobcat 751C
The Red Pill Ignore Me *Be sure too save your IL before browsing away
ace10 is offline   Reply With Quote
Old 09-21-2007, 07:48 PM   #4 (permalink)
for track raybestos st43 big bite never fade rotors last 10-12k pads 6ish-k with 15+ track days @ 120-180miles per day, $260 a set. carl
carl is offline   Reply With Quote
Old 09-21-2007, 09:45 PM   #5 (permalink)
Like Carl said: Raysbestos ST43 or Carbotech XP8. Both are excellent. My current front Carbotechs have lasted since the CFRA's last LS track day which includes 1 more LS day, one more at Buttonwillow and 9 at Thunderhill. I still have at least one more track day before brakes get too low...
CountTracula is offline   Reply With Quote
Old 09-22-2007, 05:44 PM   #6 (permalink)
Jugga Jigga Wugga
EdHahn's Avatar
I use Porterfield R4 on the street - they are a race pad, but work pretty well at cold temps. I don't put that many miles on the car, so I can't say whether rotors life is significantly affected.
ed
Magnetic Blue/LSS Delivered: 1/13/05
EdHahn is offline   Reply With Quote
Old 09-22-2007, 07:31 PM   #7 (permalink)
i've used 3 sets of R4 race pads 2 on my old elise and 1 on the S. they ware the rotors the same as the ST43s if you track them but dont work as well on the track. as others have said if you do mostly street with a track day every now and then the factory pads are fine. carl
Old 09-22-2007, 07:56 PM   #8 (permalink)
cr_craig's Avatar
Both CountTracula and I had our factory pads crumble by the 2nd/3rd track day. So, I would suggest the Porterfields as a nice alternative.
Robert.
'07 Exige Cup 255, starlight black
cr_craig is offline   Reply With Quote
Old 09-23-2007, 05:00 AM   #9 (permalink)
Grand Poobah
Feffman's Avatar
Contact Matt Nicholson at Carbotech (www.CTBrakes.com). I'm betting their XP Panther Plus would work extremely well for the Elise/Exige.
Feff
MVP Track Time
Feffman is offline   Reply With Quote
Old 09-23-2007, 05:35 AM   #10 (permalink)
VO5
VO5's Avatar
I've been using the Carbotech XP8s for street and track with good results. They are noticeably better on the track than stock pads. They do squeal a bit and dust worse than stock.
VO5 is offline   Reply With Quote
