Taking my Exige S off the road
Mods - love LT but figuring out which section to post in can be overwhelming, so please move as you see fit.
Enjoying my Exige on the track but just no love for it on the road, so just bought a trailer, dropping the registration and insurance. Given the economy and since this is my backup track car I don't want to get too carried away, so resisting temptation. Not much done to date: Larini exhaust, S111 engine mounts, 6-pt Schroth, RT brace. Basics such as Pagids, Motul and track alignment. Rubber from r888 to R6 or hopefully full slicks now that I have the brace. Short term wishlist: Baffled oil pan (Moroso?) and/or Accusump,would love the tighter steering ratio rod, Ohlins. Longer term wishlist: CharlieX tune, and whatever cooling and braking mods may be required from the increase in power. So outside of the basics above: Safety: a full cage is always appealing. Weight: outside of AC, sound system, airbags, what else is obvious and easy? How heavy is the windshield and engine separator glass compared to lexan? Thanks in advance, this is the first time I strip a street car so all links, thoughts and advise are very welcome!!
'07 Radical SR3 1500 '07 Exige S '08 E92 M3 |
#2 (permalink) | |
perfututum futūtor
I'd do one of these before I did this
ΒÄŅNED
And don't forget to upgrade the rear toe links (if you haven't already done so)!
EDIT: Oh, yeah... replace the wheel bolts with proper studs and nuts...
#4 (permalink) | |
Good advice on the oil issue, and interesting link, thanks.
Studs - yes, want them but any concerns at all about them (yes I should do a search). Very best choice, and source?
Get the BWR drop forged studs. Best choice for sure and its comes with what you need so no guessing.
05 GG Elise-BWR S/C-Nitrons-Intake-Exhaust-Test Pipe-Cf Scoops-Cf Lip-Cf Diffuser-Piaa Wheels-And all the little stuff
#6 (permalink) | |
RTDbrace still good enough?
#7 (permalink) |
ΒÄŅNED
Yes, as far as I know. It's always a good area to inspect before a track day (torques, heim joint wear, etc.)
#9 (permalink) |
G-200 Driver
I've been thinking of doing the exact same thing. The only reason I take mine out on the road, is just to drive around and go nowhere in particular. What's the use ? I'd rather track it a couple times a month and drive it the way it was built to be driven.
#10 (permalink) |
really light stuff
![]() Join Date: Jul 2003
Rear glass is about 3 1/2 pounds. Replacement carbon fiber panel is about one pound:
Group Buy - Really Light Stuff CF Exige Rear Window
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
#12 (permalink) |
ΒÄŅNED
I believe the longer studs are only necessary if you're using wheel spacers...
#13 (permalink) |
I would caution you regarding dropping the insurance on the vehicle. Although insurance is generally worthless if a mishap occurs on the track, there is a lot of opportunity for your car to get damaged off the track.
Example 1: you are trailering your car and either a) you cause an accident that damages your trailered Exige, b) you have a trailer mishap that damages your Exige, or c) and uninsured motorist causes an accident that damages your Exige. In either of these cases you are likely screwed. Your auto policy (on the tow car) likely does not cover the car being towed. Example 2: your Exige is stolen from your house. Your home policy likely does not cover the stolen car. Check these out with your insurance agent. As an alternative, you may want to consider lowering the liability coverage as much as possible and increasing your deductible to a high amount.
2007 Carrera S 2007 Exige S 2007 CBR600RR |
#15 (permalink) | |
I was thinking about going with something along the lines of a storage / transit / paddock policy - essentially no liability and covers the car only when its not moving under its own power. I spoke to the folks at Heacock Classic about my Radical and they have pretty reasonable rates for this requirement.
#16 (permalink) | |
ΒÄŅNED
![]() EDIT: There's about 8 more threads on the longer studs, so 8 x 4 x 4 x 2 (on and off) is 256 extra full turns of the lug nuts! ![]()
* 2009 Lotus Challenge Series Rookie Of The Year * (Thanks Jim, Tom, Jack, Rob & Spring Mountain Motorsports Ranch!) My videos: http://www.youtube.com/user/apk919 Last edited by apk919 : 04-14-2009 at 11:37 AM. |
#17 (permalink) | |
![]() ![]() ![]() But yes seems like a lot of wasted motion. BTW how hard is it to remove them if one strips or breaks? New hub or recoverable?
