On-track Fuel Starvation
Well, long story short, I thought I might be having oil starvation - loss of power in hard left hand corners. It's confirmed to be fuel starvation - WITH A HALF of TANK of gas.
Are there others with the same reported issue? Thanks! t |
My other car's a mtn bike
Nope - only when the car is near empty. I haven't heard of anyone having the same problem as you. Have you checked the pump connection? It may have a loose one that is reacting to the g's. Good luck - hope it's easy to track down the problem. Post result, please.
Edited 7/13/08 Actually, I'm getting feul starved on very tight left turns, max g's with as much as 7 gallons of feul. Apparently the baffles tend to leak as the sealant fails so sustained g's will cause the pump to starve. Solution is to remove the tank, cut it open, weld the leaky baffle seams, reweld the tank shut. That or swap the tank and I'm not sure if the latest version solves the weak sealant issue. According to Lotus BH, if the car is still under warranty the tank is covered, however you have to guarantee that if they remove the tank and find that the tank is in proper order, the R&R labor is owner covered.
Sometimes you have to go in circles to move forward. 05 Elise Last edited by R'elise Me : 07-13-2008 at 08:41 PM. Reason: changed my mind! |
-30-
here a few threads on the topic:
http://www.elisetalk.com/forums/showthread.php?t=28403 http://www.elisetalk.com/forums/showthread.php?t=17571 http://www.elisetalk.com/forums/showthread.php?t=28642 http://www.elisetalk.com/forums/showthread.php?t=36828 http://www.elisetalk.com/forums/showthread.php?t=14461
2007 Exige S, Storm Ti. Sport, Track and TC.Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons. 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 94 Toyota FZJ80 Landcruiser, 97 Bobcat 751C The Red Pill Ignore Me *Be sure too save your IL before browsing away
#4 (permalink) | |
I have escalated this to the factory. The reply was " we have not experienced this problem before, we will look into it". Yeah right. They are now offering a Tank Bag (approx 70 litres) as an option. The cost is approx 3000 pounds and 6 hours of labour..the worst this is that the tank bag has a life of around three years before it begins to breakdown (a plastic/fuel issue). ![]() |
Lateral-G Addict
That is the DEAL!!!!! Awesome job, please let us know when it's available.
08 SpaceGrey V8 "Arcadian, I've fought countless times, yet I've never met an adversary who could offer me what we Spartans call "A Beautiful Death." I can only hope, with all the world's warriors gathered against us, there might be one down there who's up to the task." Μολὼν λαβέ!! |
#7 (permalink) |
2008 XP National Champion
Yep. I had probably the worst known case of this with my auto-x car. My solution was to remove the tank and build a new one. The lotus fuel tank is a POS. Casey's fuel cell/2nd pump is the goods!
2008 X Prepared Solo National Champion |
#8 (permalink) | |
![]() Lotus says that they now have the fix, but all of the US Cup car owners are still waiting for the new and improved (anti-fuel starvation) fuel cell. ![]() I love my Lotus, but I think Lotus needs to do some more in depth testing before releasing some of these options. ![]() Last edited by Jack : 07-13-2008 at 05:08 PM. |
#9 (permalink) |
'07 Black Exige S
Per the afore-mentioned treads, I thought Lotus had acknowledged the problem and are covering it under warranty?
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, ForcedFed engine dampener, de-snorkle/ vel stack, cf side scoops/ mesh removed, algnmnt set up by Lucent in LA (machined control arms, etc), SS brake lines, 160 deg. thermo, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Stealth signal bulbs, blacked out turn side markers, 5 point harness |
#10 (permalink) | |
#11 (permalink) | |
'07 Black Exige S
#12 (permalink) |
right seat driver
Jack, is the ATL fuelcell your speaking of different than the Lotus Sport version in your cup 255? Have they always been ATLs? I made patterns and designed a cell with ATL for my blue car. Surgetank, bantam material, Bosch 44 in tank; I wonder if ATL is selling it now?
![]() How was Willow? In some of our racecars we have had problems with swirlpots/feed tanks pre-heating fuel, now all our cells have a in cell surgetank, thank helps in heat disipation. |
#13 (permalink) | |
What is the "fix"?, as Lotus have been aware of this problem for a while and they are still building the 2-11/Exige etc with the fuel pickup in the left side of the tank. The fix to me is relatively simple, dual outlets on the tank..one of the left, the other on the right and dual pumps. ![]() |
#14 (permalink) |
Q'vo!
Even though Cup Cars and 2-Elevens have no warranty, Lotus does try and step up to the plate and help customers, especially regarding the fuel starvation problem. That being said, if you have an Elise (N/A or 220hp) or Exige (N/A, 220hp or 240hp) ecountering this problem at the track, Lotus will not cover it under warranty however, if you can reproduce the same problem on city streets, than Lotus might cover it...case by case
#15 (permalink) | |
#16 (permalink) |
Form and Function
bump....has Casey finished developing the 2nd fuel system?
www.FaceNBody.com 2005 Lotus Elise: Larini SE exhaust,HID's,turn signals delete,rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,Gut Aero wing,Gut front splitter,CF 5-element diffusor,Exige mesh, Ohlins DA,RAC monolites,Toyo R888's,Pagid RS Blues,CO painted calipers,SS lines,Reverie XC CF seat, Reverie CF steering wheel,V force harness bar,Schroth Profi II 6 pt harness,shifter re-Enforcer, BWR key to BWR S/C! 2007 E63 M6 (many mods...) |
#17 (permalink) |
Curious: 2005 Elise with a full tank of gas is having a hesitation in sweeping left hand turns. Fuel starvation? This car is scheduled to become a dedicated track car and this issue is irritating and needs to be corrected. What's the fix? Thanks, Matt
#18 (permalink) |
Lotus Sales
We did indeed finish testing the fuel swirl tank....and it did indeed cure the issues we were having. We just aren't sure if we will offer the kit as a package due to the the difficulty it would create with al the different configurations(n/a...turbo...supercharged) and due to the availability of smaay's fuel rail.
00 Acura Integra...05 F250 Powerstroke diesel INTERNET FORUM BOARDS"A place where everyone seems to be an engineer" |
#19 (permalink) | |
However I'm looking at replacing the stock tank with a unit from Pro-alloy. I went down and had a look at their workshop and they are a really good bunch of guys (who also race in the Elise trophy). The unit is slightly larger at 54 litres and importantly has one way valves in the baffles to prevent the fuel moving away under left hand load. Under testing they claim no fuel surge down to 3 litres in their VX220 test car. It can also be foam filled improving saftey and also further helping the fuel surge issue. Pro Alloy Ltd - The UK's Number One for Alloy Racing Tanks, Radiators & Intercoolers... |
#20 (permalink) | |
never enough power!
Does the Pro-alloy unit fit the US spec 2-Eleven's?
![]() Quote:
Dan 08 2-Eleven Launch Edition
