Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Esprit
Old 10-16-2008, 06:29 PM   #1 (permalink)
1997 V8 Fuel pump replacement???
Anybody out there have any thoughts on a fuel pump replacement for a 1997 V8?
The factory OEM units seem fairly pricey.
What is an equivalent aftermarket pump(s) that will work?
Does anybody have a procedure on how to go about replacing the pump?
Any info would be great!
Feel free to e-mail me directly.....jlipper@ptd.net
jlipper is offline   Reply With Quote
Old 10-17-2008, 02:31 PM   #2 (permalink)
2/3 hp to the paws.
Simba's Avatar
You could likely replace it with a walbro or other aftermarket pump. You'll need to figure out what the stock flow capacity of the pump is, however. I believe it's around 50 gph. A walbro 255 should flow plenty, for example.
Old 10-31-2009, 01:37 PM   #3 (permalink)
What were the symptoms that your car had to make you want to change the pump?
traknut is offline   Reply With Quote
