Battery Recommendation for 97 Exprit
Hey,
Looking to replace my battery, it is not cranking too well and it is pretty old, so time for a new one. So, the question is, what would you all recommend? I'm not racing the car or anything like that. Just your normal use and occational spirited drive ![]() I'm hoping the battery you a recommend would be available at normal auto parts stores, my car won't start without a batter booster as it stands, so need to do this quickly. Darin
Current cars: 2003 Dodge Durango R/T 5.9L & 1997 Lotus Esprit Former cars: 94 928 GTS 5spd, 96 BMW 840 Ci, 88 Feiro GT, 88 Conquest Tsi w/21psi turbo w/300HP RW dino'd) |
Alarmed & Dangerous
I don't know what group size battery the Esprit has, but this was put together for the Elise/Exige which uses a size 26. Battery Choices & Information
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 07-10-2009 at 01:42 PM. |
No, it's only an N/A
And if cost is no object you can certainly look at the VolkPhreaks. It is by far the lightest battery available and they have great customer service.
Voltphreaks - Lightweight Battery Systems
Useful links to vendors removed at Nadeem's request. "Nice avatar by the way, I doubt Colin Chapman would have followed the herd as I have seen many here do. --Nadeem" |
I don't know about the newer Esprits, but the battery in my '86 was an odd size and the height of the battery case was critical since the battery cover was part of the trunk floor. If you put a non OEM sized battery in the battery well, the battery cover would be at the wrong height which could cause problems when putting things in the trunk. In fact, when I got my Esprit it had a shorter in height battery than OEM in it and something placed in the trunk had broken the now poorly fitting cover which exposed the battery terminals. Fortunately nothing shorted those terminals which could have easily caused the car to burn to the ground. If your Esprit is the same with the battery location in the trunk floor, be sure to replace your battery with one of at least the same height dimension.
2/3 hp to the paws.
I use an optima yellow top. Plenty of juice, and as batteries go, not terribly heavy.
I wouldn't bother with the race batteries and super-expensive lightweight stuff. In an Elise, it makes a degree of sense, in an Esprit, not so much. |
#8 (permalink) |
Alarmed & Dangerous
FYI, the Yellow Top is a "deep cycle" battery and the Red Top is not and can't leak because it is an AGM.
