#21 (permalink) |
CASE CASTING FAILURES?
I'm wondering how many C35-s broke the case and/or developed an internal cracks due to a shock overloading.
What is the typical failure mode and area affected? The case can be reinforced by adding some ribs, but internals? Please chime in and post some pictures.
88 X330 __________________________________ http://www.thelotusforums.com/forums/garage/ Last edited by MRDANGERUS; 02-18-2013 at 05:55 PM. |
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) |
I have an 84 Turbo Esprit with the Citroen tranny being discussed and I've always wondered about swapping rear hubs, drive shafts, etc to use the later Renault tranny with outboard brakes. Surely this isn't cheap but with the Esprit being so similar over multiple years I was curious if anyone's tried this conversion?
I think I'd rather spend a little (or a lot) more doing this and not have to deal with the hassle of inboard brakes, and know that I can tune the engine for more power knowing the tranny can handle it.
1981 DeLorean DMC-12, #5086 1984 Lotus Turbo Esprit, back on the road! (rebuild thread) |
#23 (permalink) | |
For a company with so little resources, they were constantly tweaking the car, so I bet it's a very long list of things you would have to change to make that swap. Better just to send your box to someone like Harry Martens to get it renewed.
1998 Lotus Esprit V8, Calypso/Magnolia, Elise Airbag Steering Wheel, 02+ center Exhaust, Protech Dampers, Nova Wheels |
#24 (permalink) |
It is quite puzzling why everybody talks about conversions instead of implementing countermeasures. If it is broken-fix it!
I guess it would be a simple job welding ribs to reinforce the casing.
88 X330 __________________________________ http://www.thelotusforums.com/forums/garage/ Last edited by MRDANGERUS; 02-18-2013 at 05:56 PM. |
#25 (permalink) |
My point was that for someone like myself who isn't a purist or going for Concours, I'd rather put money into an upgraded solution (renault box) instead of fixing an inferior one. For someone not looking for more power, the Citroen is fine, but for those who are its already at its limit. Combine that with the headache that is the inboard brakes when trying to work with the engine, I'd rather have the modern setup with more breathing room to up the boost among other tweaks.
My tranny is fine, just talking hypothetically if it ever breaks. I'd love to find some good shots of the renault-era frame and suspension for comparison with mine.
#26 (permalink) | |
Eddie
FYI other considerations - your 84 uses a 5x120 bolt pattern -20mm offset wheels while the Renault-equipped cars used 5x108 positive offset wheels. At a minimum, you'd have to screw around with a rear wheel change too or at least some adapters.
Eddie B 88 Esprit 'SLEEK GT' |
#27 (permalink) | |
The better, more cost effective solution is to sell your car and buy a later one with a Renault transaxle. Regards, Tim Engel |
#28 (permalink) | |
#29 (permalink) |
My estimate for conversion from C35 to UN1 is $8-9K, assuming use of pre-owned parts. New brakes and clutch.
88 X330 __________________________________ http://www.thelotusforums.com/forums/garage/ Last edited by MRDANGERUS; 03-02-2013 at 08:16 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
