What model are you referring to? V8's run a little warmer than 4 cyl and ambient temp affects the temps as well.
As a vague generality, normal operating temp for a 4 cyl would be 85-95 degrees C. V8's approximately 10 degrees hotter. Are you having a specific problem? |
Depends on your location. Here in Georgia mine runs around 90 A/C on and driving. Creeps up to 100 in stop and go traffic I will usually beat the radiator to the punch and turn off the AC and open the windows and drops right back down if I am caught in traffic. Long winded answer, but I believe it should run between 85 and 95.
89 Esprit SE
on the 4pot - if your car is using stock ECU programming (non-chipped):
- thermostat opens at 90°C - fans come on at 92°C - tell light comes on at 105°C if I'm moving and it's 90°F or less - I never get over 85°C. This Texas summer was crazy hot (68 days over 100°F) so my SE spent a lot of time bouncing between 85°C and 95°C constantly up and down. it's common for the gauge to be a little off so check using Freescan.
_____________ Lou Senko, Austin, TX Click to see 'Quik LS' my mean Lincoln LS Click to see 'Quiker' my Lotus Esprit SE |
#5 (permalink) | |
The Man from L.E.O.
YMMV...I've replaced several t-stats during my 16 years of Esprit ownership. ![]() ++++++++++ Again we need to know what year Dere2000 is referring to. If he has a 2000 V8, they DO run warmer...but they are prone to coolant loss out of the overflow bottle in the RR wheel housing. Once the coolant gets low, a proper radiator bleed is often needed.
Atwell Haines '88 Esprit Succasunna, NJ USA Lotus Enthusiast's Organization, NJ/NYC Area www.LotusEnthusiasts.Org Last edited by carbuff : 09-09-2009 at 02:09 PM. |
