Engine paint - LotusTalk - The Lotus Cars Community
 3Likes
  • 1 Post By jtrealty
  • 1 Post By beinmymirror
  • 1 Post By carbuff
post #1 of 15 (permalink) Old 03-18-2017, 03:47 PM Thread Starter
Laser Bob's Avatar
Engine paint
I'd like to do a little touch up painting on the engine. Does anyone have the paint codes for the orange paint on the engine block?
Is it something that might be available at a local car parts store?
Thanks
DD- '97 Ford E350 diesel van
Toy- '83 Esprit
Laser Bob is offline
post #2 of 15 (permalink) Old 03-18-2017, 06:01 PM
I color matched the v8 plenum red/orange. You could do the same.
Guy
toomanyespritsguy is offline
post #3 of 15 (permalink) Old 03-19-2017, 06:26 AM
Wingless Wonder
carbuff's Avatar
You can get a very close approximation to the factory 'colour' by first painting with Chrysler Orange engine paint, then 'dusting' the result with Chevy Red Engine Paint. These are commonly available from Rust-Oleum, Krylon, or Dupli-Color at autoparts stores.
Or, buy the OEM "VHT" wrinkle paint off Amazon or eBay. MrD has posted links.
None of these paints last a long time on the valve covers, the engine oil ruins the finish after a number of years.
PS: One way to offset the constant cost of refinishing, is to position a container in the air scoop on the lower left side of your picture at car shows. Mark it "DONATIONS". LOL Jenna's going to do that at LOG. <DUCKS>
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #4 of 15 (permalink) Old 03-19-2017, 07:25 AM Thread Starter
Laser Bob's Avatar
Toy- '83 Esprit
post #5 of 15 (permalink) Old 03-19-2017, 07:48 AM Thread Starter
Laser Bob's Avatar
I just want to touch up some of the nicks and dings around the edges.
Speaking of oil, is the oil cap supposed to lock shut? I thought I read somewhere that it's not. The one I have doesn't lock and continually vibrates loose, which splashes oil onto the block which drips down into the plug wells, etc.
Toy- '83 Esprit
post #6 of 15 (permalink) Old 03-19-2017, 08:56 AM
mieczkow's Avatar
Bob,
The only way to get a really nice clean look for your painted engine components is to remove them, media blast them, and repaint. I use VHT wrinkle red and it's reasonably close to the OEM color to pass. If you do all your components they also will match. If you "touch up" the effect will be mottled - older sections will simply be different because of age and heat. The tricky one to paint is the back plate on the plenum - it is attached to the throttle bodies. On my car everything was removed, media blasted (walnut shells) then sprayed. After the paint is good and dry you use a sanding block on the raised lettering and ribbing to re-reveal the aluminum to recreate the OEM look.
Your oil filler cap should not be vibrating loose. It should fit snugly, have an o-ring or gasket, and should not be leaking oil on to the engine. That's a dangerous situation as the oil on the manifold will smoke, stink, and possibly ignite. Fix that situation first thing.
Tom Mieczkowski
1989 Turbo Esprit
mieczkow is offline
post #7 of 15 (permalink) Old 03-19-2017, 09:45 AM Thread Starter
Laser Bob's Avatar
Thanks Tom. I don't want to get that involved into it, was just wanting to touch up some paint nicks around the edges.
As for the oil cap, it's already being worked on, was just double checking on something I thought I heard somewhere.
BTW- I'm going to email you a picture of the new fan assembly on my engine lid this week. It's similar to yours but different. Thank you for your input and pictures
Toy- '83 Esprit
post #8 of 15 (permalink) Old 03-20-2017, 08:20 AM
Spreadthin
Spreadthin's Avatar
I just had paint matched for my '67 Commodore Blue Sunbeam Tiger, and the jobber had a device that could take a picture of a sample (at least 3 x 3") and computer match a color. Match looks spot on for touch ups. I'm satisfied! The paint on my car was a custom mix done almost 30 years ago. Worth looking into. Good luck, and let us know your results.
Rick McCurdy
Spreadthin is offline
post #9 of 15 (permalink) Old 03-20-2017, 08:37 AM
Touch-ups on the motor aren't going to blend in well. Once the heat gets to it, it will affect how it looks enough to discern a difference. It is also going to age differently. The only way to go is to repaint the whole part. Depends on how fussy you are and how noticeable the spot is.
David Teitelbaum
mieczkow likes this.
jtrealty is offline
post #10 of 15 (permalink) Old 03-20-2017, 09:19 PM
beinmymirror's Avatar
You might check out Dupli-color chevy orange red DE1607 since GM owned Lotus back in the early 90s.
Laser Bob likes this.
beinmymirror is offline
post #11 of 15 (permalink) Old 03-21-2017, 03:52 AM Thread Starter
Laser Bob's Avatar
thanks all
Toy- '83 Esprit
post #12 of 15 (permalink) Old 03-21-2017, 10:41 AM
Dreaded Prior Owner
snowrx's Avatar
Glad my '85 has the Black EZ-match engine paint. VHT wrinkle black and you're done!
Just a thought if you're getting ready to strip and paint a bunch of parts on a long term ownership- do ya really like red/red-orange??
1985 BRG Turbo Esprit
+ HC, CC, Megasquirt EFI
snowrx is offline
post #13 of 15 (permalink) Old 03-21-2017, 11:12 AM
Wingless Wonder
carbuff's Avatar
Who in the USA doesn't like Red engine accents, 'White' bare aluminum, and Blue timing belts and silicone hoses???
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #14 of 15 (permalink) Old 03-21-2017, 03:56 PM
Don't forget to add chrome bits, neon colored wire looms for the electrical harnesses with LED lights and an oversized air filter.
David Teitelbaum
jtrealty is offline
post #15 of 15 (permalink) Old 03-21-2017, 05:52 PM
Dreaded Prior Owner
snowrx's Avatar
I must of got beat down by one of those red/white/blue patriots , I'm black 'n blue
Now I can start on a Chrome wiring cover with neon backlighting.... Thanks for the tips!
snowrx is offline
Human Verification
