Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Esprit
Old 09-10-2009, 05:14 PM   #1 (permalink)
Leaky cylinder liners
I've done a search on the forum but couldn't find an answer to this question ---- sorry if this is a re-post...............
I've heard mentioned that the early V8's had a problem with leaking cylinder liners, but this was later remedied by the factory at some point in production. Does anyone know the MY and VIN (serial) that marks the start of when the "bad sealant" issue was resolved in production?
finnerty is offline   Reply With Quote
Old 09-10-2009, 06:16 PM   #2 (permalink)
2/3 hp to the paws.
Simba's Avatar
They changed to the new sealant mid-2000. Never heard of an 00+ car with liner sealant issues. The earlier cars are hit and miss, though the vast majority are usually fine.
The condition of the oil is a dead giveaway of liner leaks. Check the oil regularly for any water (white froth, opaque oil, foam under the fill cap). You can also pressure test the cooling system, though that's generally somewhat inconclusive if there are other issues present.
Old 09-10-2009, 10:23 PM   #3 (permalink)
Interesting...
In your experience, does this problem tend to show up right out of the gate, or does the engine have to rack up some mileage before the leaking develops (on the cars which actually end up with the defect, of course)?
Old 09-11-2009, 12:06 AM   #4 (permalink)
Seb
<3 QR25DE
Seb's Avatar
I'm willing to bet any ring seal issues are due to an improper break in.
Newsflash: An 'easy' break in is not the correct way to achieve good ring seal.
Source: Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
Seb is online now   Reply With Quote
Old 09-11-2009, 04:32 AM   #5 (permalink)
98 Esprit V8 Calypso Red
E5PR1T's Avatar
Leaking liners usually happens when the car gets overheated. That's why some early V8 owners put in the larger and better Aluminum Radiator as a level of insurance. However, words are those cars that are not leaking by now, should not leak at all.
Lotus switched to the new sealant (Hylomar) in June, 2000.
Alan
E5PR1T is offline   Reply With Quote
Old 09-11-2009, 06:18 AM   #6 (permalink)
Grand Poobah
Feffman's Avatar
Alan is correct. Lotus used a different sealant (a Loctite product I believe) after using good old Hylomar for years on the 4-cylinder Esprits. The early V8s used this new sealant that needed to cure for 72 hours before getting it wet. Supposedly no one told the engine assembly guys about the 72 hours and if you got an engine that didn't sit over the weekend or a few days, chances are the liners leaked. Hylomar, which Lotus switched back to can be soaked immediately with no ill effects.
I owned a 1997 and 199 Esprit V8. Neither had any liner issues.
Feff
MVP Track Time
Feffman is offline   Reply With Quote
Old 09-11-2009, 02:12 PM   #7 (permalink)
s4s
If the car hasn't experienced the issue by now, I wouldn't worry about it. As someone else mentioned cheap insurance on the early cars is to install a better radiator with upgraded fans.
s4s is offline   Reply With Quote
Old 09-29-2009, 06:42 PM   #8 (permalink)
Cylinder Liner Sealants
Lotus went from Hylomar PL-32 (Universal Blue) in the 4-cylinder 9XX engines, to Loctite 572, to Hylomar 3400 (an anerobic, not the blue goo). So while they did go back to Hylomar the brand, they didn't go back to the original Hylomar sealant.
The problem with 572 was Lotus' engine assembly vendor's failure to follow the sealant's procedure, and not a failure of the sealant itself. If you have an early V8 that doesn't leak by now, then there's no particular reason to fear the 572. It's a good sealant, but perhaps the long cure time makes it a less than ideal choice for series production.
Hylomar 3400 has a cure time, but it's much shorter than 572's.
Hylomar PL-32 is ready to go right away... no cure time required since it never really cures.
Regards,
Tim Engel
Esprit2 is offline   Reply With Quote
