Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Esprit
Old 05-27-2009, 03:09 PM   #1 (permalink)
Twisties Addict
Bgwilly31's Avatar
Lotus Esprit successor may feature Lexus V10
For Lotus fans, the next few years should prove to be very interesting times as the company pushes ahead with its five-year plan to update its model lineup, including successors to the Elise and Esprit. Lotus has already unveiled its new Evora, but rather than sitting still with this car, work on the new Elise and Esprit is already well underway at the company’s Hethel engineering center in the UK.
While the future Elise may be seen as early as 2011, of more interest is the flagship Esprit successor, which EVO is reporting could come with an optional V10 engine sourced from Lexus. While there has been no confirmation of such a move, Lotus CEO Mike Kimberley has revealed in the past that the car is being developed with “a very well respected prestige carmaker.”
Many predicted that BMW would supply one of its V8 engines for the new Esprit but Lotus' close ties with Toyota, from which it already sources a number of powerplants, could see advanced Lexus engines used instead. The 500hp (373kW) V10 engine, which is set to debut in the Lexus LF-A supercar next year, would likely be reserved for a range-topping model, while a mid-spec model would get the IS-F’s 420hp (312kW) V8 and an entry-level model would pick up a 300hp (225kW) version of the 3.5L Toyota V6 from the Evora.
To keep costs down and speed up its gestation, the new Esprit will likely share its chassis with the bonded and extruded aluminum unit underpinning the Evora. Rising development costs and changing requirements, however, have reportedly pushed back the original 2010 release date to 2012. The extra time, however, will allow for both coupe and convertible models - Lotus had originally planned to launch a hard-top only - as well as a possible ‘alternative’ model.
Lotus Esprit successor may feature Lexus V10 - MotorAuthority - Car news, reviews, spy shots
-White Rossion Q1
07 white Exige S--Sold
04' Lexus Turbo IS300 BSM "track car"
--SOLD
"Straight lines dont mean sh**"
Bgwilly31 is offline   Reply With Quote
Old 05-27-2009, 03:22 PM   #2 (permalink)
Denuo Volatilis
...m...'s Avatar
That. Would be. Epic.
Old 05-27-2009, 03:24 PM   #3 (permalink)
Nikki
Nikki's Avatar
I hope the part about offering some less exotic versions like a V8 or V6 is true, since that would make it more affordable to me, plus I don't need 500+ HP for my purposes at my old age.
Nikki is online now   Reply With Quote
Old 05-27-2009, 03:55 PM   #4 (permalink)
2/3 hp to the paws.
Simba's Avatar
Hope they will, chances are they won't.
Old 05-27-2009, 04:30 PM   #5 (permalink)
Highway Star
6_speed's Avatar
Agree. But they would simply point us to the Evora or Evora S instead
6_speed is offline   Reply With Quote
Old 05-27-2009, 04:38 PM   #6 (permalink)
There have been so many engine rumors (starting with the 5L V8 from the prior generation M5) for the Esprit, that I can't keep up anymore. I personally believe that the 5.7L V8 from the Tundra (another recent rumor) seems logical (unless the weight/dimensions of the engine are not acceptable). Close to 400hp, available supercharger through TRD (pushing it to 500hp) and relatively inexpensive.
2007 Carrera S
2007 Exige S
2007 CBR600RR
deddie is offline   Reply With Quote
Old 05-27-2009, 09:35 PM   #7 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
they should stick with the V10. I guess it wouldn't be bad to offer V8 also, but you don't want to water it down. Evora S should be enough to fill the gap.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 05-28-2009, 12:11 AM   #8 (permalink)
Double Trouble
Flash G's Avatar
I'll gladly take 500+ HP.
Turn your flatscreen TV into a work of art.
Modern Art DVD | Plasma Aquarium DVD | Widescreen Fireplace DVD
11 Esprit??? (Wish List)
07 Exige S - Ardent Red, Stage II Exhaust, LSD, Touring pack
06 Range Rover Sport - Java Black
05 Elise - Ardent Red, Stage II Exhaust, Touring pack
Flash G is offline   Reply With Quote
Old 05-28-2009, 02:33 AM   #9 (permalink)
Lotify
Soigne's Avatar
500+ hp in a 3000+ lb Lotus?! Colin would rollin' in his grave. Does that not go against all these cars stand for?
06' Elise, touring, twin oil coolers, ss, Hid low&high, Braille battery w/cutoff switch, Rear panel delete, stereo lite, K40 w/laser, Ohlins 2-way, RTV brace, 15/16 w/r888's, ss brake lines, motul fluid, Pagid Blues, FF cf front splitter and rear wing, Moroso oil pan, Accusump, Fidanza flywheel, ACT clutch and FF275 kit with Garett gt-28rs turbo and EFI Standalone, 234 whp 200 wtq on pump gas, 275 whp 240 wtq on 100 octane with race map.
Soigne is offline   Reply With Quote
Old 05-28-2009, 06:08 AM   #10 (permalink)
2/3 hp to the paws.
Simba's Avatar
As opposed to 350 hp in a 3000 lb Lotus?
I'd much rather see a 2500 lb Esprit, but I don't think that'll be possible unless they get extremely exotic (and hence expensive) in construction materials.
Old 05-28-2009, 10:41 AM   #11 (permalink)
Jamolah's Avatar
Let’s keep in my mind, when Colin was building cars it was a different time. Now with stricter emissions, crash safety, pedestrian safety and being more manufacturers becoming more environmentally friendly it’s changing the game. Cars have to get heavier as a result of these things, unless you are going carbon fiber and making small cars (i.e. Elise/Exige size).
When you get into the Evora, Esprit, F430, 911, Corvette, etc… size cars you are talking about 3000+lbs, no way around it unless you’re going very exotic materials and $500,000+ price range.
Even the Elise has gone up in weight from the original British unit. If memory serves me correctly the original Elise (S1) was around the 1500 – 1600 lbs, now it’s in the 1984 – 2100+. When you think about it that's a 300 to 400+lbs increase on such a small car. So imagine the added pounds on bigger cars.
2003 Corvette Z06
Jamolah is offline   Reply With Quote
Old 05-28-2009, 11:21 AM   #12 (permalink)
buzzy's Avatar
Images: 10
I love this comment on that site:
Tigersworld says
Damm that look's like a Delorian with a Japanese aero kit glued on!!!!
Gone to talk about lotus somewhere else.com
buzzy is offline   Reply With Quote
Old 05-28-2009, 11:24 AM   #13 (permalink)
g and the sauce's Avatar
I would love to see the Lexus V10 in the new Esprit.
One question, why would Lexus supply the engine when they have their own supercar coming out?
I feel like I am taking crazy pills!
2006 Land Rover LR3
Sold 2005 Elise
g and the sauce is offline   Reply With Quote
Old 05-28-2009, 07:03 PM   #14 (permalink)
Because they have a working relationship with Lotus and benefit greatly from Lotus Engineering...
1995 S4s
1994 S4 brg
Visit my website: http://sites.google.com/site/jkesprit/
lotus4s is offline   Reply With Quote
Old 05-29-2009, 10:08 AM   #15 (permalink)
I don't see a new Esprit as being competition for a Lexus. Different type of buyer.
A Lexus buyer thinks luxury and convenience first. An Esprit buyer is thinking about something completely different. Luxury and convenience are way down the list.
TrapperJohn is offline   Reply With Quote
Old 05-29-2009, 10:25 AM   #16 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
Originally Posted by TrapperJohn View Post
Luxury and convenience are not on the list.
fixed it for you
Dude, there's my car!
Monsi is offline   Reply With Quote
Old 06-08-2009, 03:16 PM   #17 (permalink)
DeanG's Avatar
Jalopnik says this
Jalopnik - New Lotus Esprit To Feature 500 HP Lexus LF-A 4.8-Liter V10 - 2012 Lotus Esprit
DeanG is online now   Reply With Quote
Old 06-08-2009, 05:17 PM   #18 (permalink)
now where was I...?
mikeyd's Avatar
I'm gonna get flamed for this but here goes...
Why doesn't Lotus just sign up for gen. V LS 500hp+ motors from GM for the Esprit (or whoever buys the engines division). It's reliable, 100lbs lighter than the Lexus LF-A, MUCH cheaper, could be geared to return relatively high MPG in a lighter more aerodynamic vehicle. More importantly an LS Esprit would inherit a massive fan base throughout the US and have access to huge aftermarket support/tuning.
Now I know I'm gonna get flamed for this but look past gut reactions and prejudices, how much better is a massively technical V10 with prohibitive servicing costs than a proven and much loved lump like the the LS?
Just because it's made in Detroit doesn't mean it's crap...
I would much prefer to see an Esprit with LS power and I reckon most of Esprit fans of old would too.
The Corvette isn't my cup of tea but the LS is a bloody good engine.
Lotus has as much a connection with GM as it does with Toyota (more so maybe).
My $0.02
I must not bet on the Top Gear board. I must not bet on the Top Gear board. I must not bet on the Top Gear board.
mikeyd is offline   Reply With Quote
Old 06-08-2009, 05:42 PM   #19 (permalink)
Denuo Volatilis
...m...'s Avatar
...torque...
Old 06-08-2009, 05:54 PM   #20 (permalink)
NOT ßANNED!
Demonized's Avatar
My $0.02
Then vette owners would have something to brag about...
