Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Esprit
Old 06-08-2009, 10:15 AM   #1 (permalink)
Speedo dead - need tach readings
My speedo in my 90 SE is officially bonkers.
Until I get it fixed, could some kind soul with a similar vintage Esprit get me the tach readings in 5th gear for 55 and 70 mph. I think it's 2300 and 3000 RPM, but want to be sure.
TrapperJohn is offline   Reply With Quote
Old 06-08-2009, 01:05 PM   #2 (permalink)
2/3 hp to the paws.
Simba's Avatar
Going from memory, but I believe it's around 2,500 at ~55, and 3,300 at ~70. (V8, fwiw, but I think the ratios are the same) I'll see if I can verify that later.
Old 06-08-2009, 06:09 PM   #3 (permalink)
Vulcan Grey's Avatar
the V8 ratios aren't the same.
I seriously don't remember what RPM's my Esprit runs in any gears... but LEW knows
Esprit Models
Ratios: Gear Ratio km/h/1000rpm
5th 0.82:1 37.2
4th 1.03:1 29.6
3rd 1.38:1 22.0
2nd 2.05:1 14.9
1st 3.36:1 9.0
so the math works out to 2379rpm at 55 in 5th
and 3029rpm at 70 in 5th
Travis
Vulcan Grey Esprit SE
http://vulcangrey.lotuscolorado.com/gallery
Vulcan Grey is offline   Reply With Quote
Old 06-09-2009, 06:36 AM   #4 (permalink)
Thanks, guys. I need to get that speedo fixed, tired of seeing that gaping hole.
Old 06-09-2009, 07:53 AM   #5 (permalink)
89 Esprit SE
Quicker's Avatar
What's your speedo doing?
I just fixed mine - it was bouncing all over then stopped..... had to take it all apart, glued the rotating weight back onto the end of the drive.
_____________
Lou Senko, Austin, TX
Click to see 'Quik LS' my mean Lincoln LS
Click to see 'Quiker' my Lotus Esprit SE
Quicker is offline   Reply With Quote
Old 06-10-2009, 12:08 PM   #6 (permalink)
With mine, the delrin bushing that held the two pins in alignment (one on the rotating magnet, one on the cup) came apart. The tin cup was hitting the magnet, causing the needle to jerk all over the place.
I'm experimenting with a glob of epoxy to replace the bushing. Have to taper the countersink just right.
Old 06-15-2009, 01:25 PM   #7 (permalink)
Lorenzo's Avatar
Question Speedo repair procedure
Hello everyone, This may be my 1st post here. Can't actually recall.... any way, I have a 93.5 that had a bouncy speed needle then it just stopped,
Lou Senko, Austin, TX wrote " I just fixed mine - it was bouncing all over then stopped..... had to take it all apart, glued the rotating weight back onto the end of the drive".
Hi Lou, have any pictures of your fix-it or the steps taken. I looked at the unit a while back but looks to be a sealed unit ... so how did you open it?
Actually like to know how fast I'm going.
Thanks,
Larry
Drive Well - Lorenzo!
Lorenzo is offline   Reply With Quote
Old 06-15-2009, 01:39 PM   #8 (permalink)
89 Esprit SE
Quicker's Avatar
here is what I needed to fix - you can see the rotating magnet worked its way up (and nearly off) the rotating drive. I put a drop of loc-tite on it and pressed it flush.
_____________
Old 06-15-2009, 04:11 PM   #9 (permalink)
Lorenzo's Avatar
Question
Have any problems getting the bezel off? It looks like the edges are rolled.
Old 06-15-2009, 04:34 PM   #10 (permalink)
TimMullen's Avatar
Images: 19
Don't know about the Esprit, but for my earlier instruments, you simply rotate the bezel on the instrument housing and it comes off.
94 Miata R Package - Black
Old 06-15-2009, 06:12 PM   #11 (permalink)
89 Esprit SE
Quicker's Avatar
it is rolled - I just used a small (jeweler's) screw driver and worked it around the edges.
_____________
Old 06-17-2009, 08:35 AM   #12 (permalink)
Lotus_cz's Avatar
if any1 interested i ve one digital 80mm spare
http://www.lotus-club.cz
Your 6 is my 12.
http://www.voodoo-world.cz
Lotus_cz is offline   Reply With Quote
