Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Esprit
Old 11-01-2009, 01:33 PM   #1 (permalink)
lotusdriver2001's Avatar
Strange coolant leak. Any suggestions?
The car is a 2003 - V8. There is a cooling leak and the coolant seems to be coming out the bottom of the bell housing. The way I found this is by putting a hand-powered pressure bleeder on the header tank in place of the overflow tank hose. I pressurize the system to about 10 -12 lbs (based on the car having a 15 lb. cap) and coolant drips out at the bottom of the bell housing.
Are there freeze plugs in the back of the engine? Is there a pathway for coolant to get in there from the top?
Any ideas?
lotusdriver2001 is offline   Reply With Quote
Old 11-01-2009, 06:07 PM   #2 (permalink)
2/3 hp to the paws.
Simba's Avatar
Check the turbo coolant lines along the top of the transmission.
There's also an aluminum crossover pipe in the same area, could have developed a crack, or a cracked hose.
Old 11-01-2009, 08:34 PM   #3 (permalink)
Did that one...
Thanks but I did check the turbo lines, and just about any other lines I could see, find, and reach. Did discover that when the shop did my timing belt they appear to have removed the hoses for the coolant pipes in the front of the engine, both of them, for access. They were loose and leaking. I had to reach up there and tighten them. Just a benefit of chasing this problem.
The coolant appears to be coming from inside the bell housing. I'm wondering if maybe there is a freeze plug under the fly wheel that could be leaking. Perhaps a head gasket leaking into the center of the engine and running down somehow inside the bell housing? I'm really sort of hoping of something easy that I'm missing. Neither of the two options I mention are exceptionally pleasant.
Old 11-01-2009, 08:45 PM   #4 (permalink)
Seb
<3 QR25DE
Seb's Avatar
There should be no freeze plug on the transmission side of the engine from what I'm aware of. I would start from the top of the engine and work down. Gravity is a great tool to diagnose fluid leaks.
Seb is online now   Reply With Quote
Old 11-02-2009, 06:44 AM   #5 (permalink)
2/3 hp to the paws.
Simba's Avatar
There's no freeze plug, but the thermostat housing is on the top of the engine under the intake manifold, it's possible they didn't seal that properly and it's pooling and leaking out through the rear of the engine.
The only other possibility in that area would indeed be a head gasket, however were it leaking badly enough for you to notice it dripping, you'd be pegging the temp gauge and crop dusting the neighborhood with white smoke.
I'd say pull the trunk floor out, start it up, and watch. When the system pressurizes you'll see anything that amounts to drips of coolant.
Old 11-03-2009, 06:08 AM   #6 (permalink)
Assuming fluid is coming from the bell housing weep hole you can plug it then release after runing to see if this is true. I believe it's a small leak from elsewhere as only tranny grease or engine oil would come from the weep hole. It must be a very small leak or your "add coolant" light would have come on by now. If you've checked all the lines then look closely at the water pump.
billt is offline   Reply With Quote
