Wiper arm catching on itself 1984 - LotusTalk - The Lotus Cars Community
post #1 of 19 (permalink) Old 04-16-2013, 04:57 AM Thread Starter
Iím having a hard time trying to figure out what is up with my wiper arm. As you can see the angle of the blade is too steep and is causing it to sometimes catch on itself. It almost as if the lower arm is too long? If I lift the blade up 3 inches it pulls the arm to the position were it should be.
Jim 1984 Turbo
Uploaded with ImageShack.us
Mine is the lower one.
Touches hood lightly.
It this blade correct? Does it bow to much?
mcfly007 is offline
post #2 of 19 (permalink) Old 04-16-2013, 06:07 AM
s2mikey's Avatar
The wiper blade isnt too bent - thats how they all are.
Did your "fix" rectify the issue? It does seem like the fit isnt right...???
Page 65, Section LD - what ya wanna know?
s2mikey is offline
post #3 of 19 (permalink) Old 04-16-2013, 09:53 AM
It looks like the spindle on the wiper end is bent, is it?
Jim
1995 S4s
lotus4s is offline
post #4 of 19 (permalink) Old 04-16-2013, 10:16 AM
BANNED
Definitely looks like someone jacked it up good when trying to fix something. A PO issue, or CO issue?
lotusespritse is offline
post #5 of 19 (permalink) Old 04-16-2013, 10:31 AM Thread Starter
I don't think its bend almost like its sticking out to far?
mcfly007 is offline
post #6 of 19 (permalink) Old 04-16-2013, 12:44 PM
Vulcan Grey's Avatar
re-index the wiper up higher on the windshield so it doesn't park so low.
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is offline
post #7 of 19 (permalink) Old 04-16-2013, 01:31 PM
Type82's Avatar
Remove the wiper arm.
Turn the motor on and shut it off so it is in park position.
Take a sharp pick and dig the aluminium out of the spindle splines.
Align the arm in rest position and tighten it down.
When the arm comes loose the splines on the spindle chew the mounting point of the arm filling the splines with aluminium so the arm has no bite to the spindle which causes it to slip. From the last picture those splines are gunked up.
Doing this should fix the problem, I've done it many times on all makes of cars.
Type82 is offline
post #8 of 19 (permalink) Old 04-20-2013, 09:06 AM Thread Starter
The lower ring has notch in it but I dont see anything to line it up with?
mcfly007 is offline
post #9 of 19 (permalink) Old 04-20-2013, 09:08 AM Thread Starter
And the shaft looks like its leaning to the left.
mcfly007 is offline
post #10 of 19 (permalink) Old 04-20-2013, 09:31 AM
BANNED
You definitely need a pic of what it suppose to look like, and then you need to club the previous owner that did this.
post #11 of 19 (permalink) Old 04-21-2013, 10:35 AM
I was talking about the other end of the wiper arm being bent, the end with the wiper blade...
Jim
1995 S4s
lotus4s is offline
post #12 of 19 (permalink) Old 04-24-2013, 09:32 AM
deloreanz's Avatar
I took some pics of my wiper arm. The blade is gone and needs replacing as I don't use the wiper almost at all but it should give you an idea of how mine is setup.
https://plus.google.com/u/0/photos/1...66833004527729
1981 DeLorean DMC-12, #5086
1984 Lotus Turbo Esprit, back on the road! (rebuild thread)
deloreanz is offline
post #13 of 19 (permalink) Old 04-25-2013, 07:32 AM Thread Starter
Wow thanks for the photos. Every bit of information helps!
Jim
mcfly007 is offline
post #14 of 19 (permalink) Old 04-25-2013, 04:07 PM
Laser Bob's Avatar
Hopefully I'll be getting my car back early next week and I'll get some pics for you.
DD- '97 Ford E350 diesel van
Toy- '83 Esprit
Laser Bob is offline
post #15 of 19 (permalink) Old 05-02-2013, 10:00 AM
Laser Bob's Avatar
I just got my car back and am ready to take some pictures of the wiper arm for you. Is there anything in particular you want me to focus on, or just some pictures of the entire wiper assembly?
Toy- '83 Esprit
post #16 of 19 (permalink) Old 05-02-2013, 12:50 PM Thread Starter
How high up the blade sits on the windshield. Some cars the blade hidden and other cars have a lot of the blade is exposed. And I'd like to see with the hood down and see how much space is between the hood and where the arm gets screws down.
I bought blades refills by Amco I think it to tall and is causes it to lift the arm up and catches as it goes across. I ordered a blade from a Lotus parts seller ($80) so at least Iíll know I have one perfect piece to the puzzle soon.
mcfly007 is offline
post #17 of 19 (permalink) Old 05-03-2013, 02:41 PM
Laser Bob's Avatar
I hope these help
Toy- '83 Esprit
post #18 of 19 (permalink) Old 05-17-2013, 04:42 AM Thread Starter
I ended up tracking down a new wiper arm but the wrong style was shipped. The lower arm on this one has this nub where mine should have a ring.
Lucky they had correct arm with the ring. What is interesting is the mounting holes on both arms donít have any spines. They are totally smooth? I spoke to a Lotus parts vendor and they said when it get tighten down it makes its own groves and they are called ďwitness marksĒ.
I hope this new arm works.
Also what is this little silver peg there for?
mcfly007 is offline
post #19 of 19 (permalink) Old 05-20-2013, 09:14 AM Thread Starter
The new arm works and doesnít hit the hood. The trick was to put a pin in it to straighten the arm out and then tighten it down and removed the pin and it worked perfect. Since the previous owner had put a key in it to stop it from slipping the hole was to big so when it was tighten down it wasnít straight. So when the arm went across the windshield lower arm would catch on itself do to the angle.
Jim
mcfly007 is offline
Human Verification
