Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Elan
Old 09-27-2008, 12:07 AM   #1 (permalink)
Images: 5
Thumbs up 1972 Lotus Elan +2 S130 (Brian Mullan N.I)
My late father, BRIAN MULLAN, BALLYMONEY’S 1972 Lotus Elan +2 S130
Yet another of my fathers much prized restorations….
He acquired the car in 1982, at which time, it was a non runner… sporting a rather sad looking dark brown paintwork, with a gold roof.
It was purchased in Ballymena by dad, after I noticed her sitting looking rather neglected, and informed him about her whereabouts. Dad being dad, said nothing, and the next thing I knew, I spotted him going through Ballymena, with the Lotus on the back of his trusty Range Rover.
After work, I rushed out to see her…, she was remarkably original inside, and although the paintwork wasn’t in bad condition, the tell tale signs of fibreglass stressing was evident.
She was a non runner, as I’ve said, but was complete non the less. So dad starting to strip her down, in preparation for her full restoration to her present glorious condition. He took great care in ensuring that as many original parts were retained as possible.
Before stripping commenced though, dad decided to get her running, and assess the condition of the engine, gearbox, axles etc….
He managed to get the engine running, but it was running roughly, and on closer inspection, it emerged that it was showing markedly lower compression readings on two of the cylinders. My big brother Joe, had built an engine to fit into a brand new Mk2 Mexico shell he had bought, and intended building into a road going rally car, however due to plans to build a new house, it had been shelved, so he gave the engine to dad, for his Elan.
The engine Joe had built was a 1760cc Twin Cam, but hadn’t the big valve head, and even though it had been built by a so called ‘racing engine specialist’.. dad stripped it down again to check its condition. Was a good job he did, as the big end bearings were badly scored, as grit had been left on the bearings, and had ruined them, and the engine had only been turned over by hand.
Dad fitted Joe’s 1760cc bottom end, and fitted it with the Lotus’s own Big Valve head, complete with twin Dellorto’s etc.. image how surprised he was to find that it was still showing light of compression on the same two cylinders..!
The reason for this was that the linkage between the two Dellortos had slipped, and she was able to draw in more air into two of the cylinders, than the others with the closed carb butterflies… he wasn’t impressed!
After satisfying himself with the mechanical requirements of the car, dad set about the restoration process, removing the body from the chassis, and systematically dissembling the components for refurbishment and reassembly.
The chassis, which was in remarkably original condition, was shot blasted and resprayed, all bushings, mountings, and bearings were replaced, every seal replaced, and all the components were afforded the same meticulous attention, to restore them to better than new condition. My dad spent an unbelievable amount of hours every day, restoring this wee car… working sometimes from 5.30 am until 2am the next day, such was his interest and dedication.
The engine, gearbox, back end, suspension arms etc were all refurbished, and refitted to the repainted chassis… it looked perfect (haven’t found the pix yet)…
Wolfrace spin on rims were polished up and fitted with 205/60 x 13’s on the rear, and 185/60 x13’s on the front, to clear the arches..
Having completed the rolling chassis, dad then started into the shell…
He stripped the old paint off it with a Stanley blade and paint strippers, doing a very small section at a time. Such was his patience and skill, that he was able to remove the existing paint to reveal the original ‘metal flake’ paintwork on the cars roof.
After stripping the paint off down to the original bodywork, (a painstaking labour of love), dad set about reinforcing the areas on the cars shell, which were prone to stress fractures, i.e. around the headlamps, rear boot hinges etc…
This was done by using fibreglass matting and resin, a skill dad had taught himself from completing an 18ft Norman offshore cruiser, which he bought as a bare shell, and fitted out to completion on his own.. ( the only time he was beat he wasn’t there..).
Having contented himself that all the required strengthening was completed, he set about repainting the car, leaving the original roof, and painting the rest of the car in ’Opel Ochre’… the colour of the new Mk1 Manta, which he bought new in 1973, from Culcrow Service Station, Aghadowey. I personally think it’s the best looking Elan I’ve ever seen.
He rebuilt the car, and fabricated his own exhaust system, which entailed two separate pipes emerging from the manifold, and continuing down the length of the car, to two separate silencers (made by himself), emerging from the centre of the car at the rear.
The chrome strip, which usually was fitted at the top of the sill area, he decided would be better utilised, in covering the scewheads along the lower sill area, so he placed it there… (good decision)
On completion, the +2 looked and was immaculate.. A real testimony to dads skill, dedication and abilities.
Himself and my sister Jenifer, attended loads of Lotus shows and charity events around the UK, lifting many awards for the car, although dad did it for his own pleasure, not notoriety…
I however wish to have him applauded for his interest, and contribution to the classic car fans of the future generations… if it weren’t for his like, the past would be simply a memory…
I intend to ensure that the Lotus remains in immaculate condition, is shown as often and as widely as possible, and in our families hands until I’m no longer here…
God bless you Brian Mullan (daddy), you were one in a million….
Love you dad… Paul xxxxx
corserrep is offline   Reply With Quote
Old 09-27-2008, 12:28 AM   #2 (permalink)
goofn' with the bees
mopho's Avatar
Beautiful!!!!
Car seems to attract Subaru's (last pic) LOL
________________
2004 Caterham 7 Superlight R -
67 Lotus Elan
www.morgansegal.com
www.socalsportscar.com
mopho is offline   Reply With Quote
Old 09-27-2008, 01:20 AM   #3 (permalink)
Images: 5
Thanx... was at a Performance Car Show, don't know the reason for the Subarus being there though.... lol
Old 09-27-2008, 06:42 AM   #4 (permalink)
Ex-Brit
TheViper's Avatar
Back in the 70's, I thought that after needing a larger "family" car, after my Elans, I would get a +2S, but it did not happen. I have some original magazine tests from the 70,s in the UK press, if interested I can post them.
Great car,
A/C Improvement Modifications
http://www.lotustalk.com/forums/f3/e...ent-mod-59938/
1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat.
2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up.
3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose.
Old 09-27-2008, 07:52 AM   #5 (permalink)
Images: 5
Dad and myself 3 weeks before his passing....
His own creation (handbuilt)... 1937 Ford Model Y Special (Falcon).
I've produced a similar tribute on this car, if anyones interested..
Old 09-27-2008, 08:44 AM   #6 (permalink)
Ex-Brit
TheViper's Avatar
For your Dad and you
Old 09-27-2008, 09:07 AM   #7 (permalink)
Images: 5
Thanx viper... thats excellent mate..
Old 09-27-2008, 10:43 AM   #8 (permalink)
Genius!
qball's Avatar
Images: 2
The underside of my desk is sticky!
That's gorgeous!
qball is offline   Reply With Quote
Old 09-27-2008, 01:13 PM   #9 (permalink)
Images: 5
That's gorgeous!
dirty old habit that, put your gum in the bin like everyone else..
thanx..
Old 09-30-2008, 07:33 PM   #10 (permalink)
55mini's Avatar
Paul what testitment to your dad! Simply can't be said in words and his attention to detail was wonderful. I hope you had the opportunity to work along side in the process as this would be a lifetime of memories.
Would love to see the chasis photo if you can locate it.
I helped my son on his 16th birthday rebuild from boxes a 72+2S, well it took over a year to build but he has had many miles of enjoyment since, about 20k miles.
Again it is a wonderful example and oh yes keep it in the family!
Mark
55mini is offline   Reply With Quote
Old 10-01-2008, 01:37 AM   #11 (permalink)
Images: 5
Thanx Mark, am happy to say I was involved in the restoration with my dad.... will try and locate the build pics, and add them to the feature..
Old 10-06-2008, 05:38 AM   #12 (permalink)
Images: 5
Lightbulb
Heres the link to a memorial site for my dad, if anyones interested in knowing a bit more about the history of this very talented man...
you are more than welcome to read it...
Brian Mullan's Memorial Site on InLovingMemory.ie
Old 10-13-2008, 07:44 AM   #13 (permalink)
Images: 5
Thumbs up Brian Mullan Classic Vehicle Club (N. Ireland)
All welcome...
The BRIAN MULLAN Classic Vehicle Club (N.I)
Old 10-20-2008, 03:21 PM   #14 (permalink)
What a wonderful legacy. Your Dad was a talented man.
Hawk is offline   Reply With Quote
Old 11-12-2008, 06:35 PM   #15 (permalink)
Wonderful car, Paul.
I had a 1968 +2S many years ago, in nowhere near as good a condition as yours, and it was a lovely car to drive. Handling was so benign. The car was really refined with not too much engine noise and a good ride. They are probably better than the baby Elan. And you had to love the aircraft-style dash layout. I would love another but they are pretty rare in the States.
I hope you are using it and enjoying it as a tribute to your father who was obviously a true craftsman.
Chev is offline   Reply With Quote
Old 11-13-2008, 08:35 AM   #16 (permalink)
Chicks dig it..
Interceptor's Avatar
Beautiful, you're dad was a true artist when it came to restoring the car. Did he leave a signature somewhere on the Elan?
2005 Lotus Elise <Halloween 2008>
2007 Honda VFR800A
2004 Mitsubishi Sportback
1993 Ford Ranger
2000 Husqvarna (British Lawn Mower Racing)
Interceptor is online now   Reply With Quote
HTML code is On
