#42 (permalink) | |
I agree with Tim. I converted my +2 from Strombergs to Webers. The latter sure look nice but they are definitely less tractable than the Strombergs. Constant depression carbs such as Stromberg and SU have very good off-idle performance. That being said the Webers certainly are not terrible. You just have to keep reminding yourself how to drive with them. The idle transition on Webers is pretty poor. In normal driving I generally use one gear higher than instinct would otherwise tell me (i.e. 3rd instead of 2nd etc.). Doing this I have the throttles open wider and away from the idle transition ports. This smooths out the response. Lotus and Dellorto worked together on a special six-port idle transition circuit and were quite successful. Dellortos are probably the optimal carbs for Elans and Europas. Is there an unmodified Twin Cam anywhere in the world? Converting a fixed head Elan to a drop head is possible but quite a bit of work. You have to graft in the windscreen frame from a DHC for proper support and a place to anchor the folding top. There has been misinformation over the years about Lotus eventually laying up all Elans as FHC and then cutting the roof off to make a DHC. This is baloney. Can you imagine Chapman accepting that cost penalty? A great solution is to get a DHC and buying a removable hard top in the Lenham style. They have exactly the same shape as the FHC. Tony Thompson Racing has them in S1/S2 and S3/S4 styles in standard and lightweight versions for about 300 to 400 GBP depending on options. If you are thinking about an Elan be careful about Tony Thompson's catalog. Way too mouth watering. He has everything to build a 26R from scratch (except engine parts).
Russ Newton Elite (Type 14, 1962) Elan+2S (Type 50, 1971) |
#43 (permalink) |
fly on the wall
You guys are driving me nuts, but... I don't need much help, though. Just sold my Europa TCS two weeks ago, also sold my Europa S1 last year. And today thinking of buying another Europa. Should rent warehouse space, actually if I had rented space last year, I would still have the two Europas. Life is just too damn short to have only one Lotus... ARRRGGGHH!!
Ian 06 Elise BRiGit / 08 Accord V6 / 06 PT Tom Cruiser Ragtog... today 73 Europa TCS / 67 Europa S1 / 68 Europa S2 / 64 Seven S2 / 70 Citroen DS21 / 67 Mini Cooper S / 59 Imperial... yesterday |
#44 (permalink) |
Unattractive Nuisance
Careful tuning of the Webers, sometimes using an oscilloscope, sometimes not, resulted in no flat spots or off-idle issues. With a CO tester on the highway at steady speed, CO was <2%.
The Big Valve Stromberg engine was rated at about 126 hp. Having driven many of them, I would say actual output is more like 110. At the drag strip (don't ask) my friends rebuilt Stromberg car ran in the low 17s! Note that Lotus was notorious for hopping up press cars for better results. Still a great car tho. FunElan - If you have the dash out, I suggest removing the heater core and having it tested and (if nec) resoldered. It's old and hard to reach w/dash in place. Windshield & gasket can be removed/replaced in 40 minutes. The trick is to loosen the strut that runs from dash to top of w/s surround first. Use soap, not silicone if you need to lube the gasket, as soap disappears and silicone does not. Alii is right about the starter, but I would add than any Elan should have the crappy Lucas starter replaced. Make sure there is a good ground between engine and chassis. I got my started at RD enterprises in PA, Bean sells them too. This is all too painful and making me miss my Elan even more....
05 elise (PES chip, SSRs, Sirius, shift tower reinforcement, Multivex; HID low beams) 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "I can resist anything except temptation" O. Wilde. "Political language is designed to make lies sound truthful and murder respectable." G. Orwell, 1946. |
#45 (permalink) | |
goofn' with the bees
The white Europa looks fabulous, tell us more. Any more pictures?
________________ 2004 Caterham 7 Superlight R - 67 Lotus Elan www.morgansegal.com www.socalsportscar.com |
#46 (permalink) |
Here is a great Japanese (I type this from Japan BTW) website for old Lotus', they always have some really neat cars in their stock
http://www2s.biglobe.ne.jp/~ac-minds...prit.htm#6223B
#47 (permalink) | ||
I have never driven an Elan that does not have Webers, so I can't claim one is better than the other, but I have not experienced any of the issues you speak of (ignorance is bliss?). I have also not had to adjust my webers in 6 years. The mechanic I use who has over 30 years experience with building and racing Elans (he currently has 5 Elans in various states including 26r, a series 2 racer, and a cosworth powered Elan) considers the Webers the best combination with the TC. I guess, like most things, it is a matter of opinion Quote:
#48 (permalink) | |
--Moderator--
FYI - 1964 S1.5 (officially an S2, but with S1 mechanicals). All original car, with grey crashpad, door panels and gator-hide mats, uncrazed dash and even original oval pipe exhaust system! Cheers, Kiyoshi
life is better behind the wheel of a Lotus... |
#50 (permalink) |
Well I have one ... but it got modified over the years. I took off the original Stromberg head and replaced with a big valve equipped with Dellortos. I never noticed any problems with them and did not touch them after initially putting them on the car. I did spend a lot of time working on the car but, as Tim says, it's easy to do. It was my only form of transportation for many years living in Washington DC and Boston and is now waiting for me to retire and rebuild it.
The one mod that made my car everyday reliable was probably having it completely rewired at one point and installing MSD ignition. Fired up every time after that and no wierd ground problems anywhere. Bye bye Mr Lucas ![]() I seem to remember it came with a generator which I switched out for an alternator very early on. They are really great fun to drive and are good looking cars. Get one if you don't mind working on a car now and then. |
#52 (permalink) | |
Do you have two Elans Kiyoshi?
#53 (permalink) | |
fly on the wall
#54 (permalink) | |
--Moderator--
It's a chronic illness. Now, you know why I don't get out much! Cheers, Kiyoshi P.S. Hint - see my avatar
#55 (permalink) | |
#56 (permalink) | |
--Moderator--
For more tips on Elan ownership heres a link to an article that I wrote for "Classic Motorsports" magazine... http://www.gglotus.org/ggtech/elan-guide/elan-guide.htm Cheers, Kiyoshi
#57 (permalink) |
Elan
Well folks, I own an Elan. 1965 S2 DHC. Currently undergoing its first restoration. History known from new.
You'd be mad not to own one if finances would afford it. This is the same advice I received earlier this year, when posting on lotuselan.com, when I asked the question if I should plump for an Elise. So, do it. You won't regret it. Cheers, Bill Tebbutt |
